I wish I could still build this from scratch using your instructions versus using SNAP but this is what I get:
yarn install
Cloning into ‘zwave-js-ui’…
remote: Enumerating objects: 16868, done.
remote: Counting objects: 100% (4225/4225), done.
remote: Compressing objects: 100% (778/778), done.
remote: Total 16868 (delta 3856), reused 3563 (delta 3441), pack-reused 12643
Receiving objects: 100% (16868/16868), 36.43 MiB | 17.87 MiB/s, done.
Resolving deltas: 100% (12133/12133), done.
yarn install v1.22.22
info No lockfile found.
warning package-lock.json found. Your project contains lock files generated by tools other than Yarn. It is advised not to mix package managers in order to avoid resolution inconsistencies caused by unsynchronized lock files. To clear this warning, remove package-lock.json.
[1/5] Validating package.json…
[2/5] Resolving packages…
warning [email protected]: Please use another csrf package
warning native-url > [email protected]: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
warning [email protected]: Vue 2 has reached EOL and is no longer actively maintained. See Vue.js for more details.
warning @types/[email protected]: This is a stub types definition. extract-zip provides its own type definitions, so you do not need this installed.
warning vite-plugin-pwa > workbox-build > [email protected]: This package has been deprecated and is no longer maintained. Please use @rollup/plugin-terser
warning vite-plugin-pwa > workbox-build > [email protected]: It is not compatible with newer versions of GA starting with v4, as long as you are using GAv3 it should be ok, but the package is not longer being maintained
warning vite-plugin-pwa > workbox-build > @rollup/plugin-replace > magic-string > [email protected]: Please use @jridgewell/sourcemap-codec instead
[3/5] Fetching packages…
error @homebridge/[email protected]: The engine “node” is incompatible with this module. Expected version “^18 || ^20”. Got “21.7.3”
error Found incompatible module.
info Visit yarn install | Yarn for documentation about this command.
pi@zpi5-2:~/zwave-js-ui $ yarn run build
yarn run v1.22.22
$ npm-run-all ‘build:*’
/bin/sh: 1: npm-run-all: not found
error Command failed with exit code 127.
info Visit yarn run | Yarn for documentation about this command.
