I’ve had the same problem as people above - and I discovered the problem. The automation has this as a trigger:
- platform: state
entity_id: !input "switch"
attribute: action
But (and I’m not sure if this is a change in zigbee2mqtt or HA since this blueprint was written), but the sensor attribute which changes state to mark the MQTT even doesn’t have and attribute called ‘action’; it only has a state. Therefore, the automation is watching a non-existent attribute and never fires.
Removing the attribute: action line makes the automation work.
That doesn’t explain why it works like a charm on my end. I’ll try to do the change on my side when I get out of work and test it. Then I’ll publish the template edited if everything works all right.
From playing around more, I think this depends on whether you have “Home Assistant legacy entity attributes” set in the zigbee2mqtt config. If you do, you have an action attribute; if not, it’s kept purely in the state. I think.
If you want to eliminate the null triggers from firing the automation thus causing errors in the log, add a condition to only allow the ‘good’ triggers to get into the blueprint guts and screen out the nulls and everything else in the condition…
this might be a really dumb newbie question but I hope you don’t throw tomatoes at me now:
I imported this blueprint. I have an Opple WXCJKG12LM joined over deCONZ and showing up under “devices” and I can actually use it to trigger stuff (but without a blueprint of course rather unstructured).
But if I want to create an automation with this blueprint here, I can not select the Opple switch - the dropdown shows “no matching entities found”.
How can that be - the device is visible under “devices”?
I have the same thing also with another Aqara Switch (WXKG11LM) and it’s respective blueprint…
It seems my HA doesn’t recognize those devices as being what the blueprints are for.
Am I missing something here?
Thanks for your help!
“There are no stupid questions” Quoting someone that is surely cleverer than me.
The Z2M at the beginning of the blueprint, stands for Zigbee2MQTT. When you mention deConz, you are talking about the AddOn right?
In that case, it’s probably the cause of your issue. You need to find a blueprint compatible with that app… which doesn’t seem to exist… or I’m really bad at searching
