Amazing Blueprint, thanks @Shawsky. I have a bit different setting:
- i use picoreplayers which are behind a powerplug which are turned off when not used, so i added that the plug is turned on whenever anything is pressed and it is off
- i made the group volume configurable since another setup i have is that i have grouped squeezeplayers with one of them running but set to off, in which case the volume does not change after press
blueprint:
name: Z2M - IKEA Symfonisk sound controller GEN2 for media
description:
'Control the selected media player (and any joined to it) with an IKEA
Symfonisk sound controller GEN2 via Zigbee2MQTT (Z2M)
Supports single press on media buttons and single, double and long press for the
"dot" buttons.'
domain: automation
input:
remote:
description: The IKEA Symfonisk controller GEN2 to use
selector:
device:
filter:
- integration: mqtt
manufacturer: IKEA
model: SYMFONISK sound remote gen2 (E2123)
- integration: mqtt
manufacturer: IKEA
model: SYMFONISK sound remote, gen 2 (E2123)
multiple: false
base_topic:
name: Zigbee2MQTT Base mqtt topic
description:
The base topic configured in Zigbee2MQTT. If you haven't changed
this, leave the default here ("zigbee2mqtt")
default: zigbee2mqtt
media_player:
description: The media player to control with this automation
selector:
entity:
domain:
- media_player
multiple: false
power_plug:
name: Power Plug (Optional)
description: Select the power plug to check and turn on before performing any actions. If left empty, no check will be performed.
selector:
entity:
domain: switch
default: null # Default to null if not configured
volume_steps:
name: Volume number of steps
description:
Controls the volume scale. The default of 25 is the same scale
as the Sonos app.
default: 25
selector:
number:
min: 5.0
max: 100.0
step: 5.0
unit_of_measurement: Num
mode: slider
group_volume:
name: Group Volume Control
description: Enable or disable volume control for the entire group. If off, only the selected media player will be affected.
default: false
selector:
boolean: {}
single_dot:
name: Single Dot (Single)
description: Action to run on single dot press
default: []
selector:
action: {}
single_dot_double_press:
name: Single Dot (Double)
description: Action to run on single dot double press
default: []
selector:
action: {}
single_dot_long_press:
name: Single Dot (Long)
description: Action to run on single dot long press
default: []
selector:
action: {}
double_dot:
name: Double Dot (Single)
description: Action to run on double dot press
default: []
selector:
action: {}
double_dot_double_press:
name: Double Dot (Double)
description: Action to run on double dot double press
default: []
selector:
action: {}
double_dot_long_press:
name: Double Dot (Long)
description: Action to run on double dot long press
default: []
selector:
action: {}
source_url: https://community.home-assistant.io/t/z2m-ikea-symfonisk-gen2-e2123-media-control/559523
mode: restart
max_exceeded: silent
trigger_variables:
base_topic: !input base_topic
controller: !input remote
- platform: mqtt
topic: "{{ base_topic }}/+/action"
condition:
- condition: template
value_template:
"{{ trigger.topic == base_topic+'/'+device_attr(controller, 'name')+'/action'
- variables:
controllertopic: "{{ base_topic }}/{{ device_attr(controller, 'name') }}/action"
player: !input media_player
plug: !input power_plug
steps: !input volume_steps
stepsize: "{{ 1.0 / steps }}"
# Check if the power plug is configured and off, and turn it on if necessary
- choose:
- conditions:
- "{{ plug is not none and states(plug) == 'off' }}"
sequence:
- service: switch.turn_on
entity_id: "{{ plug }}"
- choose:
- conditions:
- "{{ trigger.payload != ''}}"
- "{{ trigger.topic == controllertopic }}"
sequence:
- choose:
- conditions:
"{{ trigger.payload == 'toggle' or trigger.payload == 'play_pause'
sequence:
- service: media_player.media_play_pause
entity_id: !input media_player
- conditions: "{{ trigger.payload == 'track_next' }}"
sequence:
- service: media_player.media_next_track
- conditions: "{{ trigger.payload == 'track_previous' }}"
sequence:
- service: media_player.media_previous_track
- conditions: >
{{ trigger.payload == 'volume_up' and ((is_group_volume and state_attr(player, 'group_members') != none and state_attr(player, 'group_members') != [])) }}
sequence:
- repeat:
for_each: "{{ state_attr(player, 'group_members') }}"
sequence:
- service: media_player.volume_set
entity_id: "{{ repeat.item }}"
volume_level: >
{% set volume = state_attr(repeat.item, "volume_level") + stepsize %}
{{ 1.0 if volume > 1.0 else volume }}
# Volume Down Press (Group or Single)
- conditions: >
{{ trigger.payload == 'volume_down' and ((is_group_volume and state_attr(player, 'group_members') != none and state_attr(player, 'group_members') != [])) }}
sequence:
- repeat:
sequence:
volume_level: >
{% set volume = state_attr(repeat.item, "volume_level") - stepsize %}
{{ 0.0 if volume < 0.0 else volume }}
# Volume Up for individual player
- conditions: >
{{ trigger.payload == 'volume_up' and ((not is_group_volume or state_attr(player, 'group_members') == none or state_attr(player, 'group_members') == [])) }}
sequence:
entity_id: "{{ player }}"
volume_level: >
{% set volume = state_attr(player, "volume_level") + stepsize %}
# Volume Down for individual player
- conditions: >
{{ trigger.payload == 'volume_down' and ((not is_group_volume or state_attr(player, 'group_members') == none or state_attr(player, 'group_members') == [])) }}
sequence:
volume_level: >
{% set volume = state_attr(player, "volume_level") - stepsize %}
- conditions:
"{{ trigger.payload == 'volume_up_hold' and state_attr(player,
sequence:
- repeat:
sequence:
- service: media_player.volume_up
- conditions:
"{{ trigger.payload == 'volume_down_hold' and state_attr(player,
sequence:
- repeat:
sequence:
- service: media_player.volume_down
- conditions:
"{{ trigger.payload == 'volume_up' and (state_attr(player, 'group_members')
== none or state_attr(player, 'group_members') == []) }}"
sequence:
volume_level:
'{% set volume = state_attr(player, "volume_level") + stepsize
%} {{ 1.0 if volume > 1.0 else volume }}'
- conditions:
"{{ trigger.payload == 'volume_down' and (state_attr(player,
sequence:
volume_level:
'{% set volume = state_attr(player, "volume_level") - stepsize
%} {{ 0.0 if volume < 0.0 else volume }}'
# Volume Up Hold (Group or Single)
- conditions: >
{{ trigger.payload == 'volume_up_hold' and ((is_group_volume and state_attr(player, 'group_members') != none and state_attr(player, 'group_members') != [])) }}
sequence:
- repeat:
sequence:
# Volume Down Hold (Group or Single)
- conditions: >
{{ trigger.payload == 'volume_down_hold' and ((is_group_volume and state_attr(player, 'group_members') != none and state_attr(player, 'group_members') != [])) }}
sequence:
- repeat:
sequence:
# Volume Up Hold for individual player
- conditions: >
{{ trigger.payload == 'volume_up_hold' and ((not is_group_volume or state_attr(player, 'group_members') == none or state_attr(player, 'group_members') == [])) }}
sequence:
# Volume Down Hold for individual player
- conditions: >
{{ trigger.payload == 'volume_down_hold' and ((not is_group_volume or state_attr(player, 'group_members') == none or state_attr(player, 'group_members') == [])) }}
sequence:
- conditions: "{{ trigger.payload == 'dots_1_short_release' }}"
sequence: !input single_dot
- conditions: "{{ trigger.payload == 'dots_1_double_press' }}"
sequence: !input single_dot_double_press
- conditions: "{{ trigger.payload == 'dots_1_long_press' }}"
sequence: !input single_dot_long_press
- conditions: "{{ trigger.payload == 'dots_2_short_release' }}"
sequence: !input double_dot
- conditions: "{{ trigger.payload == 'dots_2_double_press' }}"
sequence: !input double_dot_double_press
- conditions: "{{ trigger.payload == 'dots_2_long_press' }}"
sequence: !input double_dot_long_press
Feel free to improve, add or ignore my code additions
