Nice, glad it’s working!
This is FANTASTIC! Thank you all for the hard work. For some reason, the blueprint/script did not work right away for me. Double checked the requirements, etc. All options were selected, but when I changed the Effect from blink to solid a few times, the script started working.
I have been looking for something like this. Thanks much!
@zanixmechanix Just wanted to give you a heads up that this blueprint is broken after updating to Zigbee2MQTT version 1.36. This appears to be due to a change in the Inovelli device model name.
Previous model name:
Inovelli 2-in-1 switch + dimmer (VZM31-SN)
New model name:
I just checked and it works. I am on Z2M 1.36.0 and Home Assistant 2024.2.5
The last updates to the blueprint were fixes for the model IDs that just use the model number.
2023.10.2
Update model filter to only model numbers
- This fixes the fan switch not working with the latest Zigbee herdsman converters
2023.10.3
Model ID fix
- Fix changing the model IDs in the last update that broke the script
You might have an older version, have you tried re-importing the blueprint?
good moring.
i seem to have an issue where only Aurora effect works. no other effect works the bar is just off. i have tried different colors.
also if i want to reset the ‘on’ bright blue ‘off’ dim blue do i just set that in another script with the 'LED Color When On (non-effect)" ‘LED Color When Off (non-effect)’?
I just checked all of the effects against my office switch and they are working.
What fields are you setting in the script?
As for LED Color When Off/On, this script does not control those parameters.
i am setting
Device.
Duration of effect.
Effect.
Effect Brightness.
Effect Color.
i do have on/off set in the config of the switch it just doesn’t revert after the script runs. it just turns the led bar off.
Can you turn the debug option on and copy what is output in the notifications?
Just wanted to say thank you for continuing to support this blueprint and making this change. Reimporting the blueprint, which I hadn’t done to date, corrected my issues without needing to do anything else.
sorry for the late response. how do i go about doing that? is that something in traces?
We should back up a bit and check if the LED effect works in Z2M.
If the effects work in Z2M, then we can check the script.
First, check the MQTT command path.
- Settings > Devices > MQTT (click on “## Devices”) > DEVICE
- Click on “MQTT Info” and expand “Payload”
- Find the Light device in the list (mine shows as “Family Room Light (
light.family_room)”) - Copy and paste the contents of “Payload” here
This is what mine looks like
availability:
- topic: zigbee2mqtt/bridge/state
value_template: '{{ value_json.state }}'
- topic: zigbee2mqtt/Family Room Light/availability
availability_mode: all
brightness: true
brightness_scale: 254
command_topic: zigbee2mqtt/Family Room Light/set
device:
identifiers:
- zigbee2mqtt_0x385000000000002d
manufacturer: Inovelli
model: 2-in-1 switch + dimmer (VZM31-SN)
name: Family Room Light
sw_version: '2.15'
via_device: zigbee2mqtt_bridge_0x385000000000002d
Make sure the name in command_topic matches the friendly name of the device.
If not, then you will need to edit the Comand Path Map option.
Next, you can find the debug option when calling the script.
Once the script is run, it will create a notification. This will display what values are sent to the switch.
2024.4.0
Floor and Label Support
- Add support for Floors and Labels
- Use device identifier instead of device name for Z2M
- This should fix needing to use command path map for oddly named devices
- Command path map is still available if needed
- Add Command base path
- This is used when the base MQTT path for Z2M has been changed
- Command base path and command path map are available as blueprint inputs
- This allows setting a “default” value for these settings
Follow Re-importing a blueprint to update
Getting this warning with 2024.8.0:
Deprecated
payload_templateoption used in MQTT publish action call to topiczigbee2mqtt/Lights/setfrom payload template{"led_effect": {"color": 170, "duration": 60, "effect": "pulse", "level": 100}}. Use thepayloadoption instead. In automations templates are supported natively. Update the automation or script to use thepayloadoption instead and restart Home Assistant to fix this issue.
I believe this line just needs to be changed from
payload_template: '{{ payload }}'
to
payload: '{{ payload }}'
That looks right. I haven’t updated to 2024.8.0 yet but once I do I will confirm this works and update the blueprint.
2024.8.0
Payload Template Deprecation
- Change
payload_templatetopayloadinmqtt.publishcall
Thanks to @nmbgeek for the pull request
Thanks for creating this blueprint! I just started using it today and it works great… as long as I’m controlling a single switch. When I try to use a label, nothing happens on any of the switches with that label. Any thoughts on how I can troubleshoot this?
Are the labels on the device or the light entity?
They’re on the switch devices. Do I need to have them on the entities instead? (When I successfully use this for individual switches, that’s also on devices)
The label filter is only looking for entities that have the label, it doesn’t parse the entities under areas or devices. I assumed that label_entities(label_name_or_id) got all of the entities whether the label was applied to a device or area.
I am working on updating the label filter to work with areas and devices.
So for now, set the label on the light/fan switch entity.
That worked! Thanks!
