Thanks - I haven’t had to use the addon stuff for Z2M in a long time and forgot where that was. You also helped me inadvertently with my zwave. I didn’t notice it because I only really use zwave for my pool pump automations and I have the pool turned off because the liner and the filter is leaking and I’m not one of those “polar bear” swimmers. I would’ve been looking for that this summer when I fix the pool - or remove it and put a bunker with a man cave in.
I think auto updating add-ons is bad.
Auto updating containers is bad when you are on vacation.
Sorry but that was a terrible response
Thank you for editing my post into the correct format and for providing a constructive response. As you might have noticed, I’m hesitant about posting on these forums and, for that reason, I rarely do.
That said, could you teach me how to format my posts correctly? I’m not trying to be critical here—I genuinely appreciate your help—but wouldn’t it be more beneficial to guide me on how to do it properly rather than simply pointing out that I did it wrong?
3 backticks before and after your code will format it.
e.g.
spacing:
retained:
on american keyboards, backtick is shift + tilda (~).
Well, if you check the forums faq, it’s point 11. The faq is stickied at the top of everyone’s page unless you dismissed it.
It would have been here:
You must have dismissed it at some point.
Pop up? Would an ad-blocker prevent it? I probably dismissed it as a distraction . You live and learn.
it’s not a pop up, it’s more like a dismissable banner.
In the forums here, that also formats as code from the editor.
Just a little update for those who are interested.
Today I setup the SLZB-06m I purchased to replace the Sonoff dongle p that I was using up until my recent issues. Z2M is now working again and I highly recommend the SLZB-06. Everything is working again, the only downside was that I had to re-pair all my devices again.
Apologies if I upset anyone on this thread and next time I’ll make sure I read the rules first . Just go easy if I miss something.
Don’t read rules. Be what you are and don’t apologize for then to anyone.
