just got this blueprint working with a WRS-R02 directly connect via ZHA in HA. Did had to change the commands in the blueprints after listening to the events as liviumac stated.
These are the commands for the 1st button that are working for me that i adjusted in the my locally saved blueprint:
These steps are only tested with the wireless switch (lumi.remote.b28ac1)
When you use the zha event listener
(Developer tools > Events > Listens to event fill in zha_event and start listening)
Do you get single press events even when you double triple press or hold?
If so,
Do the following
1: Home Assistant > Configuration > Devices & Services > Zigbee > Click on your Aqara H1 switch
2: Click next to reconfigure on the 3 dots > Manage zigbee device
(Make sure on Clusters that AqaraRemoteManuSpecificCluster (endpoint id:1, Id: 0xfcc00, Type: in) is selected
3: Select on attributes click_mode (id 0x0125)
3.1 value fill in 2
3.2 fill in Manufacturer code override 4447
Write attribute (if its fails make sure that you press the Aqara button 5 times in quick succession to get it out of sleep mode)
3.3 Select on attributes operation mode (id: 0x0009)
3.4 value fill in 1
3.5 fill in Manufacturer code override 4447
(Same story if its fails make sure that you press the Aqara button 5 times in quick succession to get it out of sleep mode)
Now that’s done go back to the ZHA listener and verify that double pressed etc is registered.
