I had the same need actually, So I have made what we both needed.
you can find it in the Gist mentioned a few posts earlier.
Looks like just the thing I’m after - thanks for your input.
I have the above error coming up. Thoughts?
Cheers.
Reminder for me to do a dry-run on the import.
it is fixed now.
Someone on the discord server asked for a version of this that sets the color to white every time it turns it on, so I made a quick tweak for them. I figured I’d share it here too. I don’t actually have one to test, so I’m assuming this will work. If it doesn’t let me know and I’ll take it down in shame lol.
blueprint:
name: ZHA - IKEA Tradfri on/off switch
description: |
"Control your light(s) with IKEA Tradfri on/off switch
Select the Tradfri remote and your lights.
You can turn the lights On / Off, or hold the buttons to dim the lights"
domain: automation
input:
remote:
description: The remote that will control the lights
selector:
device:
integration: zha
manufacturer: 'IKEA of Sweden'
model: 'TRADFRI on/off switch'
light:
description: The lights that will be controlled
selector:
entity:
domain: light
color:
name: Turn on Color
description: What color should it turn on as? (Use a Color Name)
default: white
mode: restart
- platform: event
event_type: zha_event
event_data:
device_id: !input 'remote'
- variables:
command: "{{ trigger.event.data.command }}"
cluster_id: "{{ trigger.event.data.cluster_id }}"
endpoint_id: "{{ trigger.event.data.endpoint_id }}"
- choose:
- conditions:
- "{{ command == 'on' }}"
- "{{ cluster_id == 6 }}"
- "{{ endpoint_id == 1 }}"
sequence:
- service: light.turn_on
target: !input 'light'
color_name: !input color
transition: 1
- conditions:
- "{{ command == 'off' }}"
sequence:
- service: light.turn_off
transition: 1
- conditions:
- "{{ command == 'move_with_on_off' }}"
- "{{ cluster_id == 8 }}"
sequence:
repeat:
while:
- condition: template
value_template: "{{ repeat.index < 10 }}"
sequence:
transition: 1
brightness_step_pct: 10
- delay: 1
- conditions:
- "{{ command == 'move' }}"
sequence:
repeat:
while:
sequence:
transition: 1
brightness_step_pct: -10
- delay: 1
- conditions:
- "{{ command == 'stop' }}"
sequence:
Have not tested it, but the color_name should be in the data:
sequence:
transition: 1
I made a Blueprint based on this that allows any of the actions of the 4 types of presses (on/off/hold-on/hold-off) to be overridden with custom actions. I wanted a light control button that mostly behaved like normal, but could use a long-press to turn the light on to full brightness instead of the last value. It can be found here: ZHA - Ikea Tradfri wireless dimmer with options for custom actions
Hi All!
After adding on of these switches to an automation controlling a Philips Hue light everything works flawlessly. However, when I add a second switch for a different Philips Hue light that second automation does not work, only the first one.
Have anyone of you run into this issue?
Thank you for this blueprint.
I wanted to control a set of lights connected to an Aeotec Z-Wave Nano Dimmer module and observed that On and Off commands work fine. Dimming up and down also work, but as soon as the long press is stopped, the lights return back to their original brightness.
I figured this was due to the “stop” command interfering with persisting the state in the Nano Dimmer module, so I removed this part from the Blueprint YAML file and restarted HA.
This is the section I removed:
Works flawlessly now!
Thanks again and hope this helps anyone having the same issue.
I just tried to add a second switch today and am having the same issue. Did you ever fix it?
Is there another Blueprint for this button that allow independent assignment of the UP(on) and DOWN(off) buttons as well as exposing all of HA’s actions and not just light-based ones?
Hello poolcactus,
I used your blueprint for a switch of another vendor. For Ikea switch, the blueprint worked fine for me, but with my Paulmann 501.34 switch, I can’t dimm down the lights. It’s always dimming up - independent which button I press. Do you have any idea, why the the dimming down is not working or how I can find the reason by myself?
The commands generated by the Paulmann switch are most likely different than used by the Ikea switch. It would have surprised me if it would have worked.
