ZHA - IKEA Tradfri On/Off Switch
What did you change in the yaml?
I would be grateful if you could post it here. I can’t get it to work.
  • choose:
    • conditions:
      • ‘{{ command == ‘‘on’’ }}’
        sequence: !input ‘button_on_short’
    • conditions:
      • ‘{{ command == ‘‘off’’ }}’
        sequence: !input ‘button_off_short’
    • conditions:
      • ‘{{ command == ‘‘move_with_on_off’’ }}’
        sequence: !input ‘button_on_long’
    • conditions:
      • ‘{{ command == ‘‘move’’ }}’
        sequence: !input ‘button_off_long’
Hi
See the section choose,I deleted the middle sections of each conditions and then restarted HA.
@Eddie46848
Thank you. It is working again.
Here is the whole updated blueprint file.
blueprint:
  name: ZHA - IKEA wireless on/off switch
  description: Control anything using IKEA wireless on/off switch
  domain: automation
  input:
    remote:
      description: IKEA wireless on/off switch to use
      selector:
        device:
          integration: zha
          manufacturer: IKEA of Sweden
          model: TRADFRI on/off switch
    button_on_short:
      name: On button press
      description: Action to run on press of On button
      default: []
      selector:
    button_off_short:
      name: Off button press
      description: Action to run on press of Off button
      default: []
      selector:
    button_on_long:
      name: On button hold
      description: Action to run on long press of On button
      default: []
      selector:
    button_off_long:
      name: Off button hold
      description: Action to run on long press of Off button
      default: []
      selector:
mode: restart
max_exceeded: silent
  - platform: event
    event_type: zha_event
    event_data:
      device_id: !input remote
  - variables:
      command: "{{ trigger.event.data.command }}"
      cluster_id: "{{ trigger.event.data.cluster_id }}"
      endpoint_id: "{{ trigger.event.data.endpoint_id }}"
      args: "{{ trigger.event.data.args }}"
  - choose:
      - conditions:
          - "{{ command == 'on' }}"
        sequence: !input button_on_short
      - conditions:
          - "{{ command == 'off' }}"
        sequence: !input button_off_short
      - conditions:
          - "{{ command == 'move_with_on_off' }}"
        sequence: !input button_on_long
      - conditions:
          - "{{ command == 'move' }}"
        sequence: !input button_off_long
Hey guys,
Same issue with the long press,
So how do import a blueprint without the blueprint button LOL?
EDIT
I just created a new file in a subfolder under blueprints and copy paste the YAML there.
Thanks boradwell :slight_smile:
Im using this to control Spotify, and for some reason (no matter what template ive tried) the volume is not a constant up and down :frowning:
Anyone have an idea of why that is?
Thanks - a huge help! These edits also worked with another related blueprint, ZHA - IKEA wireless on/off switch
Hello thank you for this blueprint, it looks very clean. But for some reason I cannot get one use case working. I wanted to turn light on, wait some time and turn it off.
But then I mapped those actions in this blueprint to any button press light never turn off
button_on_short:
      - service: light.turn_on
          device_id: 36164ac7b7536bc1a0ef04f74af8e534
          rgb_color:
            - 255
            - 0
            - 0
      - delay:
          hours: 0
          minutes: 0
          seconds: 20
          milliseconds: 0
      - service: light.turn_off
        data: {}
I even tried it with custom script with those 3 actions and cashed from blueprint but with no luck.
I tried to edit your blueprint but I am quite noob in it still.
I got it working with different blueprint (Controller - IKEA E1743 TRÅDFRI On/Off Switch & Dimmer | Awesome HA Blueprints)
But that have different issue (long press not working and not maintained)
If you could help me it would be wonderful.
