Works perfect for me, rhanks! I use the double press for a broadcast to media players, but I would like to add a condition based on time to prevent broadcasting late in the evening. I know how conditions work in HA but I wonder if I’m able to add it myself and where in a blueprint automation.
Hi, Did you manage to cycle between scenes with this set up? My search was not that successfully till now
I think I ended up just catching the events in NodeRED and doing it myself.
But, I switched to Zigbee2mqtt and decided to just keep all my Hue devices on the Hue bridge. Easier to set it all up and keep it working.
Hello, after the last update to 2022.7.0 this script does not work any more with my remote control Philips RWL021.
In the debug automation trace:
Step Detail:
Executed: July 7, 2022 at 5:04:55 PM
Error: UndefinedError: ‘dict object’ has no attribute ‘event’
Step Config:
variables:
command: ‘{{ trigger.event.data.command }}’
Anyone can help me with this issue?
Thanks!
I had a similar problem, however I was about to update the ConBee II firmware to the latest version and that solved the problem. It could have been that just unplugging the conbee stick and plugging it back in would have solved the problem.
I don’t know what really helped.
