ZHA - Tuya TS0043 3 button remote
the buttons go up in action but there are systematically 2 actions which go up at the same time.
One empty and another for example 1_single.
Except that the automation sees only one, either the empty one or the other (1_single) when it sees the empty one then nothing happens.
so you can press the button and see nothing happen. it’s quite random.
I couldn’t find a way to resolve this.
Here’s a blueprint for the six button Tuya remote (TS0046; _TZ3000_iszegwpd), also sold by brands like Loratap:
blueprint:
  name: ZHA - Tuya TS0046 6 button remote
  description: Automate your Tuya TS0046 6 button remote using ZHA events.
  domain: automation
  input:
    tuya_ts0046:
      name: Tuya TS0046 6 button remote
      description: Tuya TS0046 6 button remote to use
      selector:
        device:
          integration: zha
          manufacturer: _TZ3000_iszegwpd
          model: TS0046
          multiple: false
    button_one_single_press:
      name: Button 1 (single press)
      description: Action to run on button 1 single press
      default: []
      selector:
        action: {}
    button_one_double_press:
      name: Button 1 (double press)
      description: Action to run on button 1 double press
      default: []
      selector:
        action: {}
    button_two_single_press:
      name: Button 2 (single press)
      description: Action to run on button 2 single press
      default: []
      selector:
        action: {}
    button_two_double_press:
      name: Button 2 (double press)
      description: Action to run on button 2 double press
      default: []
      selector:
        action: {}
    button_three_single_press:
      name: Button 3 (single press)
      description: Action to run on button 3 single press
      default: []
      selector:
        action: {}
    button_three_double_press:
      name: Button 3 (double press)
      description: Action to run on button 3 double press
      default: []
      selector:
        action: {}
    button_four_single_press:
      name: Button 4 (single press)
      description: Action to run on button 4 single press
      default: []
      selector:
        action: {}
    button_four_double_press:
      name: Button 4 (double press)
      description: Action to run on button 4 double press
      default: []
      selector:
        action: {}
    button_five_single_press:
      name: Button 5 (single press)
      description: Action to run on button 5 single press
      default: []
      selector:
        action: {}
    button_five_double_press:
      name: Button 5 (double press)
      description: Action to run on button 5 double press
      default: []
      selector:
        action: {}
    button_six_single_press:
      name: Button 6 (single press)
      description: Action to run on button 6 single press
      default: []
      selector:
        action: {}
    button_six_double_press:
      name: Button 6 (double press)
      description: Action to run on button 6 double press
      default: []
      selector:
        action: {}
  source_url: https://community.home-assistant.io/t/zha-tuya-ts0043-3-button-remote/260589
mode: restart
max_exceeded: silent
- platform: event
  event_type: zha_event
  event_data:
    device_id: !input tuya_ts0046
- variables:
    command: '{{ trigger.event.data.command }}'
    endpoint_id: '{{ trigger.event.data.endpoint_id }}'
- choose:
  - conditions:
    - '{{ command == ''remote_button_short_press'' and endpoint_id == 1 }}'
    sequence: !input button_one_single_press
  - conditions:
    - '{{ command == ''remote_button_double_press'' and endpoint_id == 1 }}'
    sequence: !input button_one_double_press
  - conditions:
    - '{{ command == ''remote_button_short_press'' and endpoint_id == 2 }}'
    sequence: !input button_two_single_press
  - conditions:
    - '{{ command == ''remote_button_double_press'' and endpoint_id == 2 }}'
    sequence: !input button_two_double_press
  - conditions:
    - '{{ command == ''remote_button_short_press'' and endpoint_id == 3 }}'
    sequence: !input button_three_single_press
  - conditions:
    - '{{ command == ''remote_button_double_press'' and endpoint_id == 3 }}'
    sequence: !input button_three_double_press
  - conditions:
    - '{{ command == ''remote_button_short_press'' and endpoint_id == 4 }}'
    sequence: !input button_four_single_press
  - conditions:
    - '{{ command == ''remote_button_double_press'' and endpoint_id == 4 }}'
    sequence: !input button_four_double_press
  - conditions:
    - '{{ command == ''remote_button_short_press'' and endpoint_id == 5 }}'
    sequence: !input button_five_single_press
  - conditions:
    - '{{ command == ''remote_button_double_press'' and endpoint_id == 5 }}'
    sequence: !input button_five_double_press
  - conditions:
    - '{{ command == ''remote_button_short_press'' and endpoint_id == 6 }}'
    sequence: !input button_six_single_press
  - conditions:
    - '{{ command == ''remote_button_double_press'' and endpoint_id == 6 }}'
    sequence: !input button_six_double_press
I wanna share my configuration for the TS0046 but with zigbee2mqtt integration. I had to troubleshoot this one a long while and this is the one that finally worked for me. Hope it helps someone.
blueprint:
  name: Zigbee2MQTT - Tuya 6-Button Scene Switch Topics
  description: Automate your Tuya 6-Button Scene Switch via Zigbee2MQTT Topics.
  domain: automation
  input:
    switch:
      name: Tuya 6-Button Scene Switch
      description: Tuya 6-Button Scene Switch to use
      selector:
        entity:
          integration: mqtt
          domain:
            - sensor
          multiple: false
    button_one_short_press:
      name: Single Press - Button 1
      description: Action to run on button 1 (upper-left) single press
      default: []
      selector:
        action: null
      name: Double Press - Button 1
      description: Action to run on button 1 (upper-left) double press
      default: []
      selector:
        action: {}
    button_one_long_press:
      name: Long Press - Button 1
      description: Action to run on button 1 (upper-left) long press
      default: []
      selector:
        action: {}
    button_two_short_press:
      name: Single Press - Button 2
      description: Action to run on button 2 (upper-right) single press
      default: []
      selector:
        action: {}
      name: Double Press - Button 2
      description: Action to run on button 2 (upper-right) double press
      default: []
      selector:
        action: {}
    button_two_long_press:
      name: Long Press - Button 2
      description: Action to run on button 2 (upper-right) long press
      default: []
      selector:
        action: {}
    button_three_short_press:
      name: Single Press - Button 3
      description: Action to run on button 3 (middle-left) single press
      default: []
      selector:
        action: {}
      name: Double Press - Button 3
      description: Action to run on button 3 (middle-left) double press
      default: []
      selector:
        action: {}
    button_three_long_press:
      name: Long Press - Button 3
      description: Action to run on button 3 (middle-left) long press
      default: []
      selector:
        action: {}
    button_four_short_press:
      name: Single Press - Button 4
      description: Action to run on button 4 (middle-right) single press
      default: []
      selector:
        action: {}
      name: Double Press - Button 4
      description: Action to run on button 4 (middle-right) double press
      default: []
      selector:
        action: {}
    button_four_long_press:
      name: Long Press - Button 4
      description: Action to run on button 4 (middle-right) long press
      default: []
      selector:
        action: {}
    button_five_short_press:
      name: Single Press - Button 5
      description: Action to run on button 5 (lower-left) single press
      default: []
      selector:
        action: {}
      name: Double Press - Button 5
      description: Action to run on button 5 (lower-left) double press
      default: []
      selector:
        action: {}
    button_five_long_press:
      name: Long Press - Button 5
      description: Action to run on button 5 (lower-left) long press
      default: []
      selector:
        action: {}
    button_six_short_press:
      name: Single Press - Button 6
      description: Action to run on button 6 (lower-right) single press
      default: []
      selector:
        action: {}
      name: Double Press - Button 6
      description: Action to run on button 6 (lower-right) double press
      default: []
      selector:
        action: {}
    button_six_long_press:
      name: Long Press - Button 6
      description: Action to run on button 6 (lower-right) long press
      default: []
      selector:
        action: {}
mode: single
variables:
  command: "{{ trigger.payload }}"
  topic: "{{ trigger.topic }}"
  switch_name: !input "switch"
  deviceName: "{{ state_attr(switch_name, 'friendly_name') }}"
  - platform: mqtt
    topic: zigbee2mqtt/+/action
  - choose:
      - conditions:
          - "{{ topic.split('/')[1].replace('/', '') == deviceName.split(' ')[0]
        sequence:
  - choose:
      - conditions:
          - "{{ command == '1_single' }}"
        sequence: !input button_one_short_press
      - conditions:
          - "{{ command == '2_single' }}"
        sequence: !input button_two_short_press
      - conditions:
          - "{{ command == '3_single' }}"
        sequence: !input button_three_short_press
      - conditions:
          - "{{ command == '4_single' }}"
        sequence: !input button_four_short_press
      - conditions:
          - "{{ command == '5_single' }}"
        sequence: !input button_five_short_press
      - conditions:
          - "{{ command == '6_single' }}"
        sequence: !input button_six_short_press
      - conditions:
          - "{{ command == '1_double' }}"
      - conditions:
          - "{{ command == '2_double' }}"
      - conditions:
          - "{{ command == '3_double' }}"
      - conditions:
          - "{{ command == '4_double' }}"
      - conditions:
          - "{{ command == '5_double' }}"
      - conditions:
          - "{{ command == '6_double' }}"
      - conditions:
          - "{{ command == '1_hold' }}"
        sequence: !input button_one_long_press
      - conditions:
          - "{{ command == '2_hold' }}"
        sequence: !input button_two_long_press
      - conditions:
          - "{{ command == '3_hold' }}"
        sequence: !input button_three_long_press
      - conditions:
          - "{{ command == '4_hold' }}"
        sequence: !input button_four_long_press
      - conditions:
          - "{{ command == '5_hold' }}"
        sequence: !input button_five_long_press
      - conditions:
          - "{{ command == '6_hold' }}"
        sequence: !input button_six_long_press
thanks for your blueprint - worked perfectly for me. attached please find my version for the TS0046 now also integrating commands for long press of all six buttons.
(ir’s my first-ever sharing of a blueprint, I hope I’ve done everything right…)
blueprint:
  domain: automation
  input:
    tuya_ts0046:
      selector:
        device:
          integration: zha
          model: TS0046
          multiple: false
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      name: Button 1 (long press)
      description: Action to run on button 1 long press
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      name: Button 2 (long press)
      description: Action to run on button 2 long press
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      name: Button 3 (long press)
      description: Action to run on button 3 long press
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      name: Button 4 (long press)
      description: Action to run on button 4 long press
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      name: Button 5 (long press)
      description: Action to run on button 5 long press
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      name: Button 6 (long press)
      description: Action to run on button 6 long press
      default: []
      selector:
        action: {}
mode: restart
- platform: event
  event_data:
- variables:
- choose:
  - conditions:
  - conditions:
  - conditions:
    - '{{ command == ''remote_button_long_press'' and endpoint_id == 1 }}'
  - conditions:
  - conditions:
  - conditions:
    - '{{ command == ''remote_button_long_press'' and endpoint_id == 2 }}'
  - conditions:
  - conditions:
  - conditions:
    - '{{ command == ''remote_button_long_press'' and endpoint_id == 3 }}'
  - conditions:
  - conditions:
  - conditions:
    - '{{ command == ''remote_button_long_press'' and endpoint_id == 4 }}'
  - conditions:
  - conditions:
  - conditions:
    - '{{ command == ''remote_button_long_press'' and endpoint_id == 5 }}'
  - conditions:
  - conditions:
  - conditions:
    - '{{ command == ''remote_button_long_press'' and endpoint_id == 6 }}'
    sequence: !input button_six_long_press```
