ZHA: User code management on Zigbee door locks
You can use Dev Tools UI to set/clear/enable/disable the codes:
Yep. That’s awesome. I was hoping to be able to view them. But for the meantime, I can just keep notes on slots.
I’ve finally been able to unplug my SmartThings hub! Thank you!
Is there any way to create automations yet when certain codes are used?
edit: n/m I was able to figure this out. Great excuse for me to finally try out the native HA automations. :smiley:
Does lock manager support ZHA yet? I’ve been happy with setting them manually via the developer tools, but it also lacks any feedback or advanced features I like in lock manager
Hi, i am new into HA so please bear with me. Does it mean that with this new addition for ZHA, i can just get a zigbee lock and connected to ZHA and i can lock/unlock already?
You can (I think) now do everything with zigbee locks that you can with zwave, its just much more cumbersome.
Thanks so much for this - added both my Schlage zigbee locks today and was able to easily set codes via the dev panel.
Can someone give me a pointer on how to detect what code is used to unlock these? @flyize mentioned figuring this out when creating automation, I assume through state changes, care to share?
This isn’t pretty, but it works. Basically, you’ll have to go into Dev Tools > Events and listen for zha_events. When the door is unlocked, you’ll see an event like this (screenshot taken from Automations).
Once you have the device id, under args, you’ll see also see a slot parameter. Each unlock code is a slot. You’ll just have to tie together the unlock codes to a slot. Then it’s just a matter of finishing the automation.
Apologies for the screenshots, I should probably learn how to share native HA Automations (I normally just use NR).
I don’t know what’s this worth to you guys, but the wife really likes to be able to manage and see the lock codes for the front door and was the last thing i need to migrate from smartthings
 Im still really new to hass so if there was a better way please let me know!
The lock code table is just markdown, so you will have to add / remove entries there as needed.
here is what i did.
  1. Grab GitHub - gadgetchnnel/lovelace-text-input-row: A custom Lovelace text input row for use in entities cards and install it
  2. Enable input_text on your configuration
  3. Enable scripts on your configuration (if not already)
Create a new dashboard with the following example
Lovelace template
  - title: Home
    cards:
      - type: vertical-stack
        cards:
          - type: entities
            header:
              image: >-
                https://www.ryadel.com/wp-content/uploads/2017/11/IT-Security.jpg
              type: picture
            show_header_toggle: false
            entities:
              - type: custom:text-input-row
                entity: input_text.codeslot
                entity: input_text.usercode
              - entity: script.add_code
                icon: mdi:key-plus
              - entity: script.clear_code
                icon: mdi:key-minus
            title: Code Details
          - type: markdown
            content: >
              | ID | User               |
              Lockcode                                |
              |1     | User1           | <details>1111</details>    |
              |2     | User2            | <details>2222</details>     |
              |3     | User3         | <details>33333</details>     |
            title: Lock Codes
Create the add / clear scripts
Scripts
add_code:
  alias: Add Lock Code
  variables:
    codeslot: '{{ states(''input_text.codeslot'') | int }}'
    usercode: '{{ states(''input_text.usercode'') | int }}'
    lock: YOUR.LOCK_DEVICE
  mode: single
  sequence:
  - service: logbook.log
      name: Lock code added
      message: 'slot: {{ codeslot }} was updated with a new code: {{ usercode }}'
  - service: zha.set_lock_user_code
      device_id: YOUR LOCK ID
      entity_id: YOUR LOCK ENTITY
      code_slot: '{{ codeslot }}'
      user_code: '{{ usercode }}'
  - service: notify.mobile_app_YOURPHONE
      message: USER REMOVE
      title: FOOBAR
clear_code:
  alias: Clear Lock Code
  variables:
  mode: single
  sequence:
  - service: zha.clear_lock_user_code
      title: FOOBAR
Add the following to your input_text section
input_text:
  codeslot:
    initial: 0
  usercode:
    initial: 0
Here is what it looks like
No need for the extra steps in your Actions when you can just add code_slot: {code slot} under the operation: Unlock argument.
I just implemented it and it works pretty well.
In my case the next step is to notify my HA app. But you certainly don’t have to!
A couple of quick questions on your script.
Is that an entity or device ID?
And I feel like a total newb for this one, but what the heck is a device_id and where do I find it?
@flyize Configuration → Devices → /choose your lock/, then you’ll see it’s ID in the URL
@vilord I just found a bug, related to ZHA Yale locks - actual user code slots on the lock are shifted by 1, compared to what is handled by ZHA functions. I.e. if I set up a code for user #1 via yale keypad (master code, 1, 2, 1 /user slot #/, code) - it actually corresponds to slot #2 handled via zha calls (clear, set, enable, disable).
As a side node - I also have one Z-wave Yale lock, where it handles all the slots correctly (i.e. slot #1 on the lock = slot #1 in zwave lock calls).
Hey Vlad, is that bug still a thing?
I just installed my first zigbee lock, a yale assure SL (branded as a lockwood tlock here in australia)
I set up the first few codes via the panel itself and then found this thread. Managed to get @jkuntz805 dashboard working without too much trouble and have configured 2 more codes through home assistant using it.
It seems the codes created from the panel started at 1 for the master code and counted up. on the surface, (to a noob like me) it seems okay. maybe i’m missing something? Just wanted to check I didn’t have to watch out for a gotcha.
Master code is NOT the same as User1 code. I have 3 Zigbee + 1 Zwave Yale locks and initially configured all of them via keypad. Master as master, User1 for me, User2 for my wife etc.
When I tried to reset the code for me (User1) via the above dashboard. I was able to get with new code to Zwave lock, but not to any Zigbee. When I reset code for User2, it propagated to User2 on Zwave lock (as expected), but to User1 instead of User2 on all Zigbee locks.
I ended up with the following workaround for Yale Zigbee locks (+1 increment while calling zha functions)
add_code:
  variables:
    codeslot: "{{ states('input_text.codeslot') | int }}"
    usercode: "{{ states('input_text.usercode') | int }}"
  sequence:
  - service: zwave_js.set_lock_usercode
      device_id: <yale_zwave_lock_id>
      usercode: '{{ usercode }}'
      code_slot: '{{ codeslot+1 }}'
      device_id:
        - <yale1_zigbee_lock_id>
        - <yale2_zigbee_lock_id>
        - <yale3_zigbee_lock_id>
  - service: notify.my_mobile
      title: 'YALE LOCKS - USER CODE UPDATED'
      message: 'Slot #{{ codeslot }} was updated with user code {{ usercode }}'
  mode: single
clear_code:
  variables:
    usercode: "{{ states('input_text.usercode') | int }}" # Unused
  sequence:
  - service: zwave_js.clear_lock_usercode
      device_id:
      title: 'YALE LOCKS - USER CODE DELETED'
      message: 'User code was deleted from slot #{{ codeslot }}'
  mode: single
Just to contribute with something quite easy, but useful (at least for me).
It’s a single use code. Meaning it gets cleared after a single use.
Considering you installed the custom Lovelace text input row* mentioned by @jkuntz805:
Create an input text for your single use code
Input Text - Single Use Code
In your configuration.yaml, add this input_text.
input_text:
##Input do cĂłdigo temporĂĄrio da porta
  singleusecode:
    name: Single Use Code
    initial: 0000
Create a script that sets the user code and notifies you
Script - Set new lock code and notify
Important: I’m using codeslot 100, since I probably won’t create 100 codes in this lifetime. Which also means in this workflow, only 1 single use code is possible. Please check your lock max number of codes to see if 100 is usable.
alias: Add Single Use Code
sequence:
#Easiest way to locate your device ID is through the Call Service on Developer Tools, selecting zha.set_lock_user_code, selecting your device and checking the YAML editor
      device_id: yourDeviceID
      code_slot: '100'
      user_code: '{{ states(''input_text.singleusecode'') | int }}'
  - service: notify.your_phone_goes_here
      message: Um cĂłdigo de uso Ășnico foi criado.
      title: Novo cĂłdigo - Porta da Frente
#This part is only valid for Android devices. For some reason, I need this or the notification won't show unless I unlock my phone. This sets the notification priority as urgent. In case you need it, check documentation for iOS settings on priority.
        ttl: 0
        priority: high
mode: single
icon: mdi:key-plus
Create a card to input your single use code and run the script
Lovelace Card
You can place this in a lovelace card, editing it in YAML mode.
cards:
  - type: entities
    header:
      image: https://www.ryadel.com/wp-content/uploads/2017/11/IT-Security.jpg
      type: picture
    entities:
        entity: input_text.singleusecode
      - entity: script.add_single_use_code
        icon: mdi:key-plus
Create an automation that deletes the code when used and notifies you
Automation to delete used code and send notification
This was created for a Yale YRD256 lock with Zigbee. It’s probably the same for a few other Yale Locks with Zigbee. For your lock, you might want to check which args you should use to detect Unlocking on the trigger and the code slot args to use on the condition. You can check this by listening to zha_event on Developer Tools and unlocking your door through the keypad to check for the event info.
alias: Fechadura - Deleta Single Use Code
  - platform: event
    event_type: zha_event
    event_data:
#You can find the device_ieee on your Zigbee integration.
      device_ieee: 00:00:00:00:00:00:00:00
      args:
        operation: Unlock
condition:
  - condition: template
    value_template: '{{ trigger.event.data.args.code_slot == 100 }}'
      code_slot: '100'
      title: Porta da Frente
      message: Código de Uso Único foi utilizado e apagado.
        ttl: 0
        priority: high
mode: single
That’s it. I made a few comments along the way to help people that - like me - are noobs.
Hope someone finds it helpful.
** btw if you didn’t install the custom elements, easiest way is through HACS. It’s available there.
Hi all, @VladStar sorry for that bug
 it seems like kwikset vs yale handles the slot numbers differently, I didn’t run into that with my kwikset locks.
@Bruno_Dantas this is great! Glad to see you’re able to leverage all the functions and put them together into this! A perfect use for the integration.
Thanks @jkuntz805 ! I was able to implement this card in my dashboard and update the scripts to reflect service calls to Hubitat, so it’s easy-peasy to add new codes and looks pretty too!
Background: I use Hubitat to connect to all my Zigbee and Zwave devices, so the usual OTS integrations like KeyMaster probably won’t work to manage locks without significant effort since I don’t have any Zwave services in HA. My Yale Zigbee lock was the last thing still on SmartThings, as the Hubitat UI for lock code management isn’t very wife friendly. But now I’m off ST and wife will be content.
For any other Hubitat users who come through this thread, I am using the Hubitat integration to HA through Maker API. It’s fairly trivial to add/remove codes for any lock in Hubitat using this card, with only slight modification of the associated scripts (I’m not a developer).
Feature Request: Ideally, all codes added through these scripts get logged to a file, which is then read by the Lock Codes display section of the card to reflect current users/codes without having to manually update a static list.
