For what it’s worth, an official project have been open under gce-electronics github.
Hi GCE & Patrick
Any news on the progress ?
Not really,
we sent RF Devices some weeks ago.
This is more slow than expected because there is only one french developper working on this project.
RF Pplayer is a complex product so this is a long work.
I hope we can give some news about this project before the end of year !
Wanted to give it a try, but even after copying custom_component/rfplayer to config directory, i don’t have GCE RFPlayer in my integrations Any idea ?
Copy the custom_component/rfplayer
folder in your config directory.
Go to Home-Assistant UI, Configuration > Integrations, button (+ Add Integration) and search GCE RFPlayer
Select the USB device in the list and valid.
has anyone tried out the RFPlayer integration and can give some feedback?
Does it work well or is it still in an early development stage?
I am considering to buy a RFPlayer but would be interested in some experience how well it works with HA.
Boris
Well it is still in early stage and not really actively developed. So far SOMFY RTS works with one caveat… Not sure if it is me but I couldn’t add my SOMFY RTS using the integration, instead I have used the java application from GCE to register them. Once done you can plug the USB stick and use it in HA.
I have seen an email from @Doubledom with a beta version that should support OWL, EDISIO, & OREGON (thx Doubledom by the way)
Would be Nice if we could get @frenck to help
Thanks @Vincha for your quick reply.
Can I control “dumb” 433 or 868 Mhz devices like sockets and sensors out of the box or does it need additional development if the RFPlayer integration?
Thanks,
Boris
Hi, @Vincha @DonZeZe @Zwordi @rom1 @HollyFredD
For “simple” devices the integration of the “beta version” allows it.
For those who can, please log the information provided.
Here or on the Fr forum
Slt, @Vincha @DonZeZe @HollyFredD @gcee @Zwordi
Pour des appareils “simples” l’intégration de la “version beta” le permet.
Pour ceux qui le peuvent merci de donner log des infos remontées.
Ici ou sur le forum Fr
Hi @Doubledom, maybe i didn’t explain well, here is a screenshot Even after copying files to config folder, the integration never appears…
I might have missed something but can’t see it, any idea ?
Il me semblait bien avoir loupé un truc… en fait j’avais testé comme ca aussi mais j’avais mis “componants” avec un “a” Merci en tout cas je vais pouvoir avancer dans mes tests.
Bonjour.
Merci de l ‘intégration !
Cela serrait merveilleux de pouvoir intégrer mes senseurs Visonic dans mon système.
J’ai tout installé et 70 entités ont été créés.
Surtout mes senseurs Visonic 868.
Malheureusement rient ne bouge c’est à dire que si ouvre ou ferme les contacts cela n’est pas reporté en HA.
Seulement des 0 ou des 1 sont affichés.
Quesque j’ai raté ?
Merci.
Salut
Montre moi les logs lors des changements, pour voir ce qui peut être fait …
Visonic je n’ai pas les infos … voir “qualifier”
Hi Show me the logs during the changes, to see what can be done… Visonic I don’t have the info… see “qualify”
@+DOM
Salut,
Excuse mon retard mais j’ai été pris par le travail.
Je ne comprends pas bien de quels log tu parles et «qualifier».
Ou se trouvent-ils ?
J’ai regardé dans le logs en configuration et j’ai trouvé un seul erreur en cherchant « GCE » : dropping invalid data:…
Merci encore pour ton aide.
Salut
Est-ce que tu vois le log /config/home-assistant.log, si tu as configuré correctement le Yaml avec le debug du Rfplayer
logger
logger:
–default: info
–logs:
----custom_components.rfplayer: debug
Je suis en train de remodifier le prog surtout la partie dans Rflib pour avoir des ident correct et j’ai commencé la modif de visionic, je vois des remontées de type 0 1 2 8 11 12 13 14 15
Version en cours Beta 12
PS passe sur forum Fr
Bonjour,
hélas non. Je n’avais pas configuré le log.
Excuse-moi.
J’ai tout désinstallé, et réinstallé la dernière BETA.
Activé le log.
Ça va beaucoup mieux ! Mes compliments.
Les Oregons maintenant marchent même si beaucoup ne s’affichent pas. Comme si la réception était faible. Mais j’ai, au même endroit une Vera avec un RFX 433 qui reçoit tout sans problèmes.
Maintenant les VISONIC affichent « 8 » ou « 10 ».
J’ai cherché « qualifier » et voici les logs :
2022-05-07 11:41:49 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-81", "floorNoise": "-93", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "9", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x2A19", "id_PHYMeaning": "PCR800", "adr_channel": "512", "adr": "2", "channel": "0", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "total rain", "value" : "3162.3", "unit" : "mm"}, {"type" : "current rain", "value" : "0.00", "unit" : "mm/h"}]}}}
2022-05-07 11:41:58 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-91", "floorNoise": "-106", "rfQuality": "3", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868950"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "1627161904", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}}}}
2022-05-07 11:41:58 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: : "0", "dataFlag": "1", "rfLevel": "-58", "floorNoise": "-103", "rfQuality": "10", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868950"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "4210726176", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}}}}
2022-05-07 11:42:21 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-77", "floorNoise": "-94", "rfQuality": "4", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0xFA28", "id_PHYMeaning": "THGR810", "adr_channel": "37633", "adr": "147", "channel": "1", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.8", "unit" : "Celsius"}, {"type" : "hygrometry", "val
2022-05-07 11:42:36 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-80", "floorNoise": "-94", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "9", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x2A19", "id_PHYMeaning": "PCR800", "adr_channel": "512", "adr": "2", "channel": "0", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "total rain", "value" : "3162.3", "unit" : "mm"}, {"type" : "current rain", "value" : "0
2022-05-07 11:43:01 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-85", "floorNoise": "-95", "rfQuality": "2", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x0000", "id_PHYMeaning": "ProbeV1", "adr_channel": "513", "adr": "2", "channel": "1", "qualifier": "16", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.4", "unit" : "Celsius"}, {"type" : "hygrometry", "value"
2022-05-07 11:43:14 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-79", "floorNoise": "-92", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0xFA28", "id_PHYMeaning": "THGR810", "adr_channel": "37633", "adr": "147", "channel": "1", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.8", "unit" : "Celsius"}, {"type" : "hygrometry", "val
2022-05-07 11:43:23 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-80", "floorNoise": "-94", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "9", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x2A19", "id_PHYMeaning": "PCR800", "adr_channel": "512", "adr": "2", "channel": "0", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "total rain", "value" : "3162.3", "unit" : "mm"}, {"type" : "current rain", "value" : "0
2022-05-07 11:43:46 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-99", "floorNoise": "-106", "rfQuality": "2", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868950"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "1574757152", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}}}}
2022-05-07 11:44:07 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-78", "floorNoise": "-95", "rfQuality": "4", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0xFA28", "id_PHYMeaning": "THGR810", "adr_channel": "37633", "adr": "147", "channel": "1", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.8", "unit" : "Celsius"}, {"type" : "hygrometry", "val
2022-05-07 11:44:10 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-82", "floorNoise": "-94", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "9", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x2A19", "id_PHYMeaning": "PCR800", "adr_channel": "512", "adr": "2", "channel": "0", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "total rain", "value" : "3162.3", "unit" : "mm"}, {"type" : "current rain", "value" : "0
2022-05-07 11:44:14 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-79", "floorNoise": "-105", "rfQuality": "6", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868950"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "2499511584", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}}}}
2022-05-07 11:44:21 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-81", "floorNoise": "-106", "rfQuality": "6", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868950"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "3730991408", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}}}}
2022-05-07 11:44:45 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ster": "0", "dataFlag": "1", "rfLevel": "-59", "floorNoise": "-106", "rfQuality": "10", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868950"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "3026219808", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}}}}
2022-05-07 11:44:57 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-80", "floorNoise": "-94", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "9", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x2A19", "id_PHYMeaning": "PCR800", "adr_channel": "512", "adr": "2", "channel": "0", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "total rain", "value" : "3162.3", "unit" : "mm"}, {"type" : "current rain", "value" : "0
2022-05-07 11:45:00 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-79", "floorNoise": "-94", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0xFA28", "id_PHYMeaning": "THGR810", "adr_channel": "37633", "adr": "147", "channel": "1", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.8", "unit" : "Celsius"}, {"type" : "hygrometry", "val
2022-05-07 11:45:01 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-87", "floorNoise": "-93", "rfQuality": "2", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x0000", "id_PHYMeaning": "ProbeV1", "adr_channel": "513", "adr": "2", "channel": "1", "qualifier": "16", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.4", "unit" : "Celsius"}, {"type" : "hygrometry", "value"
2022-05-07 11:45:44 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-80", "floorNoise": "-93", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "9", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x2A19", "id_PHYMeaning": "PCR800", "adr_channel": "512", "adr": "2", "channel": "0", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "total rain", "value" : "3162.3", "unit" : "mm"}, {"type" : "current rain", "value" : "0
2022-05-07 11:45:53 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-77", "floorNoise": "-94", "rfQuality": "4", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0xFA28", "id_PHYMeaning": "THGR810", "adr_channel": "37633", "adr": "147", "channel": "1", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.8", "unit" : "Celsius"}, {"type" : "hygrometry", "val
2022-05-07 11:45:55 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-82", "floorNoise": "-106", "rfQuality": "6", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868950"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "1224197152", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}}}}
2022-05-07 11:46:00 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-84", "floorNoise": "-95", "rfQuality": "2", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x0000", "id_PHYMeaning": "ProbeV1", "adr_channel": "513", "adr": "2", "channel": "1", "qualifier": "16", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.4", "unit" : "Celsius"}, {"type" : "hygrometry", "value"
2022-05-07 11:46:31 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-80", "floorNoise": "-94", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "9", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x2A19", "id_PHYMeaning": "PCR800", "adr_channel": "512", "adr": "2", "channel": "0", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "total rain", "value" : "3162.3", "unit" : "mm"}, {"type" : "current rain", "value" : "0
2022-05-07 11:46:46 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-79", "floorNoise": "-94", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0xFA28", "id_PHYMeaning": "THGR810", "adr_channel": "37633", "adr": "147", "channel": "1", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.8", "unit" : "Celsius"}, {"type" : "hygrometry", "val
2022-05-07 11:47:01 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-86", "floorNoise": "-94", "rfQuality": "2", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x0000", "id_PHYMeaning": "ProbeV1", "adr_channel": "513", "adr": "2", "channel": "1", "qualifier": "16", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.4", "unit" : "Celsius"}, {"type" : "hygrometry", "value"
2022-05-07 11:47:07 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-96", "floorNoise": "-106", "rfQuality": "2", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868950"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "1226163488", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}}}}
2022-05-07 11:47:10 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-60", "floorNoise": "-106", "rfQuality": "10", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868950"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "2521590048", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}}}}
2022-05-07 11:47:18 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-81", "floorNoise": "-95", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "9", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x2A19", "id_PHYMeaning": "PCR800", "adr_channel": "512", "adr": "2", "channel": "0", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "total rain", "value" : "3162.3", "unit" : "mm"}, {"type" : "current rain", "value" : "0
2022-05-07 11:47:39 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-79", "floorNoise": "-95", "rfQuality": "4", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0xFA28", "id_PHYMeaning": "THGR810", "adr_channel": "37633", "adr": "147", "channel": "1", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.8", "unit" : "Celsius"}, {"type" : "hygrometry", "val
2022-05-07 11:48:01 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: 0", "cluster": "0", "dataFlag": "1", "rfLevel": "-90", "floorNoise": "-106", "rfQuality": "4", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868950"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "4133676064", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}}}}
2022-05-07 11:48:05 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-82", "floorNoise": "-93", "rfQuality": "2", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "9", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x2A19", "id_PHYMeaning": "PCR800", "adr_channel": "512", "adr": "2", "channel": "0", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "total rain", "value" : "3162.3", "unit" : "mm"}, {"type" : "current rain", "value" : "0
2022-05-07 11:48:09 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-55", "floorNoise": "-106", "rfQuality": "10", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868950"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "2142683936", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}}}}
2022-05-07 11:48:32 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-78", "floorNoise": "-95", "rfQuality": "4", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0xFA28", "id_PHYMeaning": "THGR810", "adr_channel": "37633", "adr": "147", "channel": "1", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.8", "unit" : "Celsius"}, {"type" : "hygrometry", "val
2022-05-07 11:48:52 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-81", "floorNoise": "-95", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "9", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x2A19", "id_PHYMeaning": "PCR800", "adr_channel": "512", "adr": "2", "channel": "0", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "total rain", "value" : "3162.3", "unit" : "mm"}, {"type" : "current rain", "value" : "0
2022-05-07 11:49:00 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-86", "floorNoise": "-94", "rfQuality": "2", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x0000", "id_PHYMeaning": "ProbeV1", "adr_channel": "513", "adr": "2", "channel": "1", "qualifier": "16", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.4", "unit" : "Celsius"}, {"type" : "hygrometry", "value"
2022-05-07 11:49:20 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-61", "floorNoise": "-106", "rfQuality": "10", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868950"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "1727890720", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}}}}
2022-05-07 11:49:25 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: " :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-78", "floorNoise": "-94", "rfQuality": "4", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0xFA28", "id_PHYMeaning": "THGR810", "adr_channel": "37633", "adr": "147", "channel": "1", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.8", "unit" : "Celsius"}, {"type" : "hygrometry", "value" : "56", "
2022-05-07 11:49:39 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: r": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-80", "floorNoise": "-94", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "9", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x2A19", "id_PHYMeaning": "PCR800", "adr_channel": "512", "adr": "2", "channel": "0", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "total rain", "value" : "3162.3", "unit" : "mm"}, {"type" : "current rain", "value" : "0.00", "unit" : "mm/h"}]
2022-05-07 11:50:00 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"he
2022-05-07 11:50:00 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ader": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-85", "floorNoise": "-94", "rfQuality": "2", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x0000", "id_PHYMeaning": "ProbeV1", "adr_channel": "513", "adr": "2", "channel": "1", "qualifier": "16", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.4", "unit" : "Celsius"}, {"type" : "hygrometry", "value" : "0", "unit" : "%"}
2022-05-07 11:50:18 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: Type": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-78", "floorNoise": "-94", "rfQuality": "4", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0xFA28", "id_PHYMeaning": "THGR810", "adr_channel": "37633", "adr": "147", "channel": "1", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.8", "unit" : "Celsius"}, {"type" : "hygrometry", "value" : "56", "unit" : "%"}]}}}
2022-05-07 11:50:26 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: 3{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-80", "floorNoise": "-94", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "9", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x2A19", "id_PHYMeaning": "PCR800", "adr_channel": "512", "adr": "2", "channel": "0", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "total rain", "value" : "3162.3", "unit" : "mm"}, {"type" : "current rain", "value" : "0.00"
2022-05-07 11:50:31 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-85", "floorNoise": "-106", "rfQuality": "5", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868950"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "3472655648", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}}}}
2022-05-07 11:50:32 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-76", "floorNoise": "-107", "rfQuality": "7", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868950"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "3489915936", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}}}}
2022-05-07 11:51:11 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-80", "floorNoise": "-95", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0xFA28", "id_PHYMeaning": "THGR810", "adr_channel": "37633", "adr": "147", "channel": "1", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.8", "unit" : "Celsius"}, {"type" : "hygrometry", "val
2022-05-07 11:51:13 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: rameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-81", "floorNoise": "-95", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "9", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x2A19", "id_PHYMeaning": "PCR800", "adr_channel": "512", "adr": "2", "channel": "0", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "total rain", "value" : "3162.3", "unit" : "mm"}, {"type" : "current rain", "value" : "0.00", "unit" : "mm/h"}]}}}
2022-05-07 11:51:28 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: me" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-86", "floorNoise": "-105", "rfQuality": "4", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868950"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "3469714208", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}}}}
2022-05-07 11:51:42 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-81", "floorNoise": "-106", "rfQuality": "6", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868950"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "258204704", "qualifier": "8", "qualifierMeaning": { "flags": ["Supervisor/Alive"]}}}}
2022-05-07 11:52:00 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-81", "floorNoise": "-95", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "9", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x2A19", "id_PHYMeaning": "PCR800", "adr_channel": "512", "adr": "2", "channel": "0", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "total rain", "value" : "3162.3", "unit" : "mm"}, {"type" : "current rain", "value" : "0
2022-05-07 11:52:01 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: 0", "cluster": "0", "dataFlag": "0", "rfLevel": "-86", "floorNoise": "-95", "rfQuality": "2", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x0000", "id_PHYMeaning": "ProbeV1", "adr_channel": "513", "adr": "2", "channel": "1", "qualifier": "16", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.4", "unit" : "Celsius"}, {"type" : "hygrometry", "value" : "0", "unit" : "%"}]}}}
2022-05-07 11:52:04 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-79", "floorNoise": "-92", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0xFA28", "id_PHYMeaning": "THGR810", "adr_channel": "37633", "adr": "147", "channel": "1", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.8", "unit" : "Celsius"}, {"type" : "hygrometry", "val
2022-05-07 11:52:30 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-85", "floorNoise": "-95", "rfQuality": "2", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x0000", "id_PHYMeaning": "ProbeV1", "adr_channel": "513", "adr": "2", "channel": "1", "qualifier": "16", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.4", "unit" : "Celsius"}, {"type" : "hygrometry", "value"
2022-05-07 11:52:47 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: 3{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-81", "floorNoise": "-94", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "9", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x2A19", "id_PHYMeaning": "PCR800", "adr_channel": "512", "adr": "2", "channel": "0", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "total rain", "value" : "3162.3", "unit" : "mm"}, {"type" : "current rain", "value" : "0.00"
2022-05-07 11:52:57 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ", "cluster": "0", "dataFlag": "0", "rfLevel": "-80", "floorNoise": "-94", "rfQuality": "3", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0xFA28", "id_PHYMeaning": "THGR810", "adr_channel": "37633", "adr": "147", "channel": "1", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.8", "unit" : "Celsius"}, {"type" : "hygrometry", "value" : "56", "unit" : "%"}]}}}
2022-05-07 11:53:34 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: rameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-82", "floorNoise": "-92", "rfQuality": "2", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "9", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0x2A19", "id_PHYMeaning": "PCR800", "adr_channel": "512", "adr": "2", "channel": "0", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "total rain", "value" : "3162.3", "unit" : "mm"}, {"type" : "current rain", "value" : "0.00", "unit" : "mm/h"}]}}}
2022-05-07 11:53:50 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: rame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-77", "floorNoise": "-94", "rfQuality": "4", "protocol": "5", "protocolMeaning": "OREGON", "infoType": "4", "frequency": "433920"},"infos": {"subType": "0", "id_PHY": "0xFA28", "id_PHYMeaning": "THGR810", "adr_channel": "37633", "adr": "147", "channel": "1", "qualifier": "48", "lowBatt": "0", "measures" : [{"type" : "temperature", "value" : "+13.8", "unit" : "Celsius"}, {"type" : "hygrometry", "value" : "56
Ok pour toi, pour les Oregons il faut que je vérifie le test sur “id_PHYMeaning” pour récupérer le type et sa value, est-ce que je vois sur tes Oregon vient du rfplayer ?
Regarde dans le log les infos du décodage s’il t’en manque …
une partie de log
2022-05-06 21:15:46 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: ZIA33{ “frame” :{“header”: {“frameType”: “0”, “cluster”: “0”, “dataFlag”: “0”, “rfLevel”: “-46”, “floorNoise”: “-100”, “rfQuality”: “10”, “protocol”: “5”, “protocolMeaning”: “OREGON”, “infoType”: “4”, “frequency”: “433920”},“infos”: {“subType”: “0”, “id_PHY”: “0x1A2D”, “id_PHYMeaning”: “THGR122/228/238/268,THGN122/123/132”, “adr_channel”: “49412”, “adr”: “193”, “channel”: “4”, “qualifier”: “32”, “lowBatt”: “0”, “measures” : [{“type” : “temperature”, “value” : “+22.8”, “unit” : “Celsius”}
2022-05-06 21:15:46 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] received data: , {“type” : “hygrometry”, “value” : “60”, “unit” : “%”}]}}}
2022-05-06 21:15:46 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] decoded packet: {‘node’: ‘gateway’, ‘protocol’: ‘OREGON’, ‘id’: ‘49412temperature’, ‘hardware’: ‘THGR122/228/238/268,THGN122/123/132’, ‘command’: ‘+22.8’, ‘state’: ‘+22.8’, ‘unit’: ‘Celsius’, ‘type’: ‘temperature’}
2022-05-06 21:15:46 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] f:node,v:gateway
2022-05-06 21:15:46 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] f:protocol,v:OREGON
2022-05-06 21:15:46 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] f:id,v:49412temperature
2022-05-06 21:15:46 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] f:hardware,v:THGR122/228/238/268,THGN122/123/132
2022-05-06 21:15:46 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] f:command,v:+22.8
2022-05-06 21:15:46 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] f:state,v:+22.8
2022-05-06 21:15:46 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] f:unit,v:Celsius
2022-05-06 21:15:46 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] f:type,v:temperature
2022-05-06 21:15:46 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] event: command → +22.8
2022-05-06 21:15:46 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpparser] packet_events, sensor:command,value:+22.8
2022-05-06 21:15:46 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] ignore_event
2022-05-06 21:15:46 DEBUG (MainThread) [custom_components.rfplayer.rflib.rfpprotocol] got event: {‘id’: ‘OREGON_49412temperature_cmd’, ‘sensor’: ‘command’, ‘value’: ‘+22.8’, ‘unit’: ‘Celsius’}
2022-05-06 21:15:46 DEBUG (MainThread) [custom_components.rfplayer] event of type sensor: {‘id’: ‘OREGON_49412temperature_cmd’, ‘sensor’: ‘command’, ‘value’: ‘+22.8’, ‘unit’: ‘Celsius’}
2022-05-06 21:15:46 DEBUG (MainThread) [custom_components.rfplayer] passing event sensor.oregon_49412temperature
ICI il faut regarder
On voit les données récupérées dans les lignes [custom_components.rfplayer.rflib.rfpparser] f:
C’est ce qui est ensuite envoyé dans ton ident existant ou pas (donc créé) avec event of type sensor: et ensuite passing event to sensor.oregon_49412temperature
Pour les Visonic ( je récupère ceux des voisins) il faut voir a quoi correspond les valeurs et faire une modif dans un Yaml ( pour l’instant)
PS si tu peux passe sur la version Fr du Forum HA pour le Rfplayer , ici aime pas trop que j’écrive en Français
Désolé les modérateurs
@+Dom
Hello tout le monde. Quelqu’un a t’il essayé avec une alarme delta dore ?
