@boheme61 On a good note, there is no Wifi inside the cabinet, and no USB 3.0 devices. The only device emitting RF is a GLEDOPTO led controller so that my cabinet lights up red when you open the door. I am guessing there is some amount of EMI from all the equipment, but it is also all grounded and the cabinet itself should act as a shield to some extent… well except on the front ;).
The metal cabinet it surely going to block or impair signal coming from the opposite side of the cabinet from the antennas perspective (when the metal is in between), but a mesh should not care and should simply route accordingly. In the media room, where the cabinet is, are at least 4 zigbee routers, with 3 more right above it (in the attic) and a ton below it, and on its sides. As mentioned prior, the Conbee was rock solid other than the occasional meltdown which got me to upgrade. The past 7 years prior to HA, I was using a SmartThings hub sitting on top of this rack and my zigbee devices worked flawlessly.
While I concur with many of the objections on the placement, especially those regarding its location (top floor, side of house, instead of ground floor in the middle which I consider the best spot), I have 8 years of flawless zigbee mesh network… most of which with that rack.
I am not discounting any of the feedback and suggestions… they are all making me think.
I do like your suggestion of using an ethernet to zigbee interface with the exception that where it would be best for me to put the coordinator I do not have the option to bring wired ethernet. This also means that when I update, reboot, etc my networking gear (20 switches, 5 APs, etc you get the idea) I would bring down part of my automation as well. That was the case with ST and I was enjoying the fact it was no longer the case with HA.
It’s all food for thought… thank you for the flow of suggestions everyone!
Edit: Correction… the networking gear does emit Bluetooth (so 2.4GHz) at least during setup. I’ll check but I believe it is off, as it would have no use, after the gear is setup. The ethernet to RF interface for my Chamberlain garage opener is also in there but that operates at 3xx/4xx MHz so should not be an issue… mentioning for completeness as I forgot it was even there.
Edit2: The core systems of the house are in there so that they can all connect to the core switch to minimize points of failure. Once I update my UDMP (router) to the newer version, I will likely move some of those critical devices, such as DNS, VPN, and possibly HA to be connected directly to the embedded switch on the newer UDMP (the old one does not have POE that I use to power some of that gear). HA is running on one of the 2 Lenovo m920q (i7-8700T, 32GB, SSD, etc) so it needs to be in the cabinet for direct connectivity to the core switch and for the UPS that is in there too… plus other important VMs run on it too.
