Zigbee flower and plant sensors for soil moisture + light + temperature + humidity?
It looks very nice. I was thinking to do exactly the same. ZigBee, e-ink screen and solar panel were properly working. I just got stuck in getting reliable moisture measurements compared to a professional moisture meter.
It is possible to change the reporting time for Tuya zigbee soil sensor direct from zigbee2mqtt in Home Assistant?
@Giex if you are a representative of the company that engineered this sensor, please consider the above request in a future firmware update.
Every use case is different, so the ideal solution would be to be able to configure the reporting period by the Zigbee coordinator side. There are not so much Tuya-based devices that allow such reporting period configurations, and it would be great if you could add configuration commands in this TS0601 _TZE200_myd45weu device.
For other users - i tried old and new-version Giex devices and they are not worth buying.
Data is poor and battery dies within days.
Has anyone contacted the GiEX representative via email? Any word back from the manufacturer?
I was able to contact them via their Ali Express store. Very helpful, quick responses.
Did it become clear whether GiEX have any control on the firmware, or they are just a reseller / white label like the most of the AliExpress and Amazon sellers?
I was contacting them about some version/firmware irregularities on an irrigation controller. It has different capabilities exposed to z2m depending on where it was purchased.
They were able to clarify how to identify the different versions, which one was newer, and also that they cannot upgrade the firmware ota in that device. They did seem fairly knowledgable.
Ok, thank you!
I was in contact with Raul from Giex for sending a test replacement for my sensor. He asked me to place an order on Aliexpress for a “sample free of charge” that has to be paid via PayPal? Why to pay as long as is free of charge? Propose him a different solution, link for replacement or extra fee, but in the end nothing happened. Got no reply for him.
Hi there!
I have four of these devices ( _TZE200_myd45weu / TS0601_soil ). Can you tell me if this is the ‘new’ batch?
When i’m watering my border, 3 of 4 devices show this:
capped on 70% and it’s immidiately going up.
The other one:
It hasn’t rained for days now (outdoor temp: ±15C), but the percentage isn’t lowering that much.
Same issue here. The sensor is stuck at 70%. Removing it from the ground, and sticking it in 5 minutes later fixes the issue. But this behaviour renders the sensor useless for irrigation control
After watering, the sensor immediately stuck to the 70% again.
I bought the sensor about 14 days ago. So either it’s an old batch or the issue hasn’t been fixed yet
Hi, I’ve bought ZIGBEE Plant Monitor by Tuya and connected through z2m but it only exposes these data:
Schermata 2023-05-30 alle 17.24.31
I instead need these data, how can I fix it?
@fdrcti Zigbee2MQTT has a webpage about adding support for devices here → Support new devices | Zigbee2MQTT
Those using the ZHA integration should instead read and follow → https://www.home-assistant.io/integrations/zha#how-to-add-support-for-new-and-unsupported-devices
The issue was related to the device itself, it only exposes that data. I’ve bought a bluetooth sensor (i think is the xiaomi flora) but is only exposes these data
I really do not understand which device exposes also the other data as in the screen before.
@Giex is there any change you’ll may look at my post from 12 days ago? :slight_smile:
Thanks in advance!
Hi, has anyone tried these Zigbee sensors?
https://www.aliexpress.com/item/1005005457579746.html
Came here to ask the same thing, will try it out after summer holiday if no one else has.
Great, let us know how you get on if you do. They look quite promising: looks like a capacitive sensor and much smaller than the other ones.
I can confirm the latest hardware version of Giex ts0601_soil sensors are working well for me and I’m not experiencing the faults seen in the earlier versions.
You’ll need to confirm with the seller which version they are sending you.
The only visual difference I can see is on the newer version I have there is black Giex text printed on the top of the unit whereas the original had grey Giex text.
