### Problem description
The Plant Monitor can be paired but doesn't show any en…tities
It shows up as a TS0601 _TZE284_aao3yzhs
Link: https://www.aliexpress.com/item/1005007330089764.html
### Solution description
Add a custom quirk to display Soil moisture and temperature
### Screenshots/Video
<details><summary>Screenshots/Video</summary>
[Paste/upload your media here]
</details>
### Device signature
<details><summary>Device signature</summary>
```json
"node_descriptor": {
"logical_type": 2,
"complex_descriptor_available": 0,
"user_descriptor_available": 0,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 4417,
"maximum_buffer_size": 66,
"maximum_incoming_transfer_size": 66,
"server_mask": 10752,
"maximum_outgoing_transfer_size": 66,
"descriptor_capability_field": 0
"endpoints": {
"1": {
"profile_id": "0x0104",
"device_type": "0x0051",
"input_clusters": [
"0x0000",
"0x0004",
"0x0005",
"0xed00",
"0xef00"
"output_clusters": [
"0x000a",
"0x0019"
"manufacturer": "_TZE284_aao3yzhs",
"model": "TS0601",
"class": "zigpy.device.Device"
</details>
### Diagnostic information
<details><summary>Diagnostic information</summary>
```json
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2024.8.2",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.12.4",
"docker": true,
"arch": "x86_64",
"timezone": "Europe/Amsterdam",
"os_name": "Linux",
"os_version": "6.6.44-haos",
"supervisor": "2024.08.0",
"host_os": "Home Assistant OS 13.0",
"docker_version": "26.1.4",
"chassis": "vm",
"run_as_root": true
"custom_components": {
"average": {
"documentation": "https://github.com/Limych/ha-average",
"version": "2.3.4",
"requirements": []
"knmi": {
"documentation": "https://github.com/golles/ha-knmi/blob/main/README.md",
"version": "2.2.0",
"requirements": []
"philips_airpurifier_coap": {
"documentation": "https://github.com/kongo09/philips-airpurifier-coap",
"version": "0.18.5",
"requirements": [
"aioairctrl==0.2.5",
"getmac==0.9.4"
"hacs": {
"documentation": "https://hacs.xyz/docs/configuration/start",
"version": "1.34.0",
"requirements": [
"aiogithubapi>=22.10.1"
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"after_dependencies": [
"onboarding",
"usb"
"codeowners": [
"dmulcahey",
"adminiuga",
"puddly",
"TheJulianJES"
"config_flow": true,
"dependencies": [
"file_upload"
"documentation": "https://www.home-assistant.io/integrations/zha",
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp",
"zha",
"universal_silabs_flasher"
"requirements": [
"universal-silabs-flasher==0.0.22",
"zha==0.0.31"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "10C4",
"pid": "EA60",
"description": "*slzb-07*",
"known_devices": [
"smlight slzb-07"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "0403",
"pid": "6015",
"known_devices": [
"Conbee III"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"type": "_zigstar_gw._tcp.local.",
"name": "*zigstar*"
"type": "_uzg-01._tcp.local.",
"name": "uzg-01*"
"type": "_slzb-06._tcp.local.",
"name": "slzb-06*"
"type": "_xzg._tcp.local.",
"name": "xzg*"
"type": "_czc._tcp.local.",
"name": "czc*"
"is_built_in": true
"setup_times": {
"null": {
"setup": 7.1326969191432e-05
"eccd7b20eecde60a7a4b75548536550c": {
"wait_import_platforms": -0.016558641975279897,
"wait_base_component": -0.0007912219734862447,
"config_entry_setup": 12.98326518398244
"data": {
"ieee": "**REDACTED**",
"nwk": 32106,
"model": "TS0601",
"name": "_TZE284_aao3yzhs TS0601",
"quirk_applied": false,
"quirk_class": "zigpy.device.Device",
"quirk_id": null,
"power_source": "Battery or Unknown",
"lqi": 100,
"rssi": -75,
"last_seen": "2024-08-19T13:34:24",
"available": false,
"device_type": "EndDevice",
"signature": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"endpoints": {
"1": {
"input_clusters": [
"0x0000",
"0x0004",
"0x0005",
"0xed00",
"0xef00"
"0x000a",
"0x0019"
"model": "TS0601"
"active_coordinator": false,
"entities": [
"entity_id": "update.tze284_aao3yzhs_ts0601_firmware",
"entity_id": "update.plant_monitor_1_firmware",
"neighbors": [],
"routes": [],
"endpoint_names": [
"name": "SMART_PLUG"
"user_given_name": "Plant Monitor 1",
"device_reg_id": "dd581646b6c8df6f29d816b4d4835118",
"area_id": "bedroom",
"cluster_details": {
"1": {
"device_type": {
"name": "SMART_PLUG",
"id": 81
"profile_id": 260,
"in_clusters": {
"0x0004": {
"endpoint_attribute": "groups",
"attributes": {},
"unsupported_attributes": {}
"0x0005": {
"endpoint_attribute": "scenes",
"attributes": {},
"0xef00": {
"endpoint_attribute": null,
"attributes": {},
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {
"0x0004": {
"attribute_name": "manufacturer",
"value": "_TZE284_aao3yzhs"
"0x0005": {
"attribute_name": "model",
"value": "TS0601"
"0xed00": {
"attributes": {},
"out_clusters": {
"0x0019": {
"endpoint_attribute": "ota",
"attributes": {
"0x0002": {
"attribute_name": "current_file_version",
"value": 77
"0x000a": {
"endpoint_attribute": "time",
"attributes": {},
</details>
### Logs
<details><summary>Logs</summary>
```python
[Paste the logs here]
</details>
### Custom quirk
<details><summary>Custom quirk</summary>
```python
[Paste your custom quirk here]
</details>
### Additional information
_No response_
