I created a zigbee2mqtt version of the script since I dont use ZHA. You dont need to create any helper variables in this version. Select the siren_x_Alarm switch in the entity dropdown.
alias: Siren Control
sequence:
- service: mqtt.publish
topic: >-
zigbee2mqtt/{{ state_attr(entity_id, 'friendly_name').split(' ')[0]
}}/set/melody
payload: "{{ melody }}"
topic: >-
}}/set/duration
payload: "{{ duration }}"
topic: >-
}}/set/volume
payload: >-
{% if volume == '0' %}low {% elif volume == '1' %}medium {% else
%}high{% endif %}
topic: >-
}}/set/alarm
payload: "true"
description: Tuya Siren Z2M
fields:
melody:
default: "1"
description: >-
Melody that will be played based on ID from
https://zigbee.blakadder.com/Neo_NAS-AB02B2.html
example: 1-18
selector:
select:
mode: dropdown
options:
- label: Doorbell Chime
value: "0"
- label: Fur Elise
value: "1"
- label: Westminster Chimes
value: "2"
- label: Fast double door bell
value: "3"
- label: William Tell Overture
value: "4"
- label: Turkish March
value: "5"
- label: Safe/Security Alarm
value: "6"
- label: Chemical Spill Alert
value: "7"
- label: Piercing Alarm Clock
value: "8"
- label: Smoke Alarm
value: "9"
- label: Dog Barking
value: "10"
- label: Police Siren
value: "11"
- label: Doorbell Chime (reverb)
value: "12"
- label: Mechanical Telephone
value: "13"
- label: Fire/Ambulance
value: "14"
- label: 3/1 Elevator
value: "15"
- label: Buzzing Alarm Clock
value: "16"
- label: School Bell
value: "17"
duration:
default: 3
description: Duration melody will be played for
selector:
number:
min: 0
max: 100
mode: box
unit_of_measurement: seconds
volume:
default: "1"
description: Volume of the melody
selector:
select:
options:
- label: Low
value: "0"
- label: Medium
value: "1"
- label: High
value: "2"
entity_id:
required: true
selector:
entity:
domain: switch
description: The switch entity for the siren (should end in Alarm)
mode: parallel
icon: mdi:bullhorn-variant
