For anyone interested I have managed to get the older RES001 sensor mostly working with Z2M. Using the below external converter. It is not 100% - looks like some issues with the lux reporting. Maybe someone who knows more than me can get 100% complete.
const constants = require('zigbee-herdsman-converters/lib/constants');
const fz = require('zigbee-herdsman-converters/converters/fromZigbee');
const tz = require('zigbee-herdsman-converters/converters/toZigbee');
const exposes = require('zigbee-herdsman-converters/lib/exposes');
const reporting = require('zigbee-herdsman-converters/lib/reporting');
const extend = require('zigbee-herdsman-converters/lib/extend');
const globalStore = require('zigbee-herdsman-converters/lib/store');
const utils = require('zigbee-herdsman-converters/lib/utils')
const e = exposes.presets;
const ea = exposes.access;
const definition = {
zigbeeModel: ['RES001'],
model: 'KMPCIL',
vendor: 'KMPCIL',
description: 'Environment Sensor',
fromZigbee: [fz.temperature, fz.humidity, fz.pressure, fz.illuminance], // <-- added here all clusters reported from zigbee
toZigbee: [], // <-- add here all clusters to send commands to zigbee
exposes: [e.temperature(), e.humidity(), e.pressure(), e.illuminance().withAccess(ea.STATE_GET), e.illuminance_lux().withAccess(ea.STATE_GET)], // <-- this will de>
configure: async (device, coordinatorEndpoint, logger) => {
const endpoint = device.getEndpoint(8);
const binds = ['genPowerCfg', 'msTemperatureMeasurement', 'msRelativeHumidity', 'msPressureMeasurement',
'msIlluminanceMeasurement', 'genBinaryInput', 'genBinaryOutput'];
await reporting.bind(endpoint, coordinatorEndpoint, binds);
await reporting.temperature(endpoint);
await reporting.humidity(endpoint);
const payload = [{attribute: 'measuredValue', minimumReportInterval: 5, maximumReportInterval: constants.repInterval.HOUR,
reportableChange: 200}];
await endpoint.configureReporting('msIlluminanceMeasurement', payload);
const payloadPressure = [{
// 0 = measuredValue, override dataType from int16 to uint16
// https://github.com/Koenkk/zigbee-herdsman/pull/191/files?file-filters%5B%5D=.ts#r456569398
attribute: {ID: 0, type: 33}, minimumReportInterval: 2, maximumReportInterval: constants.repInterval.HOUR,
reportableChange: 3}];
await endpoint.configureReporting('msPressureMeasurement', payloadPressure);
const options = {disableDefaultResponse: true};
await endpoint.write('genBinaryInput', {0x0051: {value: 0x01, type: 0x10}}, options);
await endpoint.write('genBinaryInput', {0x0101: {value: 25, type: 0x23}}, options);
const payloadBinaryInput = [{
attribute: 'presentValue', minimumReportInterval: 0, maximumReportInterval: 30, reportableChange: 1}];
await endpoint.configureReporting('genBinaryInput', payloadBinaryInput);
await endpoint.write('genBinaryOutput', {0x0051: {value: 0x01, type: 0x10}}, options);
const payloadBinaryOutput = [{
await endpoint.configureReporting('genBinaryOutput', payloadBinaryOutput);
module.exports = definition;
