Home Assistant has built-in features to produce consumption stats:
To get total consumption in kWh (from power), use the integration platform sensor.
Here is an example for my washing machine, connected to a Sengled plug (which gives me sensor.washing_machine_power)
You will now have a sensor named: sensor.washing_machine_electric_consumed_kwh
Additionally, if you want to track daily, monthly, yearly consumption (using sensor.washing_machine_electric_consumed_kwh), that is a job for the utility meter integration. Here is the example for the washing machine in configuration.yaml
This is encouraging. I just ordered a couple of boxes of these sengled outlet warts (4 per box) to replace a number of random wifi-only plugs I’d collected over the years. Looking to use these to sprinkle around the house to round out my zigbee coverage.
Hi buddy,
I saw your thread and was just about to buy some Sengled wall warts to extend my Zigbee network and found a comment on Amazon by a user that contacted Sengled support directly and said their outlets, like their bulbs, so not act as repeaters.
If you were to look in the ZHA or deconz map visualization on your HA instance, can you see if the outlets are working as repeaters please?
I would greatly appreciate it. I already have 4 Ikea range extenders and would much rather have a functioning outlet.
Thanks so much
Like most support lines, they don’t know what they are talking about. The linked plugs act as routers.
To be fair, it could be Amazon’s fault, they are notorious for mixing/matching/merging reviews and comments for similar items. Very possible the prior version did not route.
I can also confirm that the Sengled wall warts (Sengled E1C-NB7, also found on amazon) DO act as zigbee routers. I have several of them and they’ve been working very well.
I wonder what happens if you flash an S31ZB (S31 Lite ZigBee) firmware on a S31TPB(US) device with Tasmotizer (or whatever is used these days)? Or maybe you can’t actually do that.
I just ordered a Lite to find out; I have tons of the S31TPB devices and the energy info is critical to me. Would be cool if it worked on ZigBee.
Hey thanks for the info. Can you link me? I’m one of those need-to-see-it-myself people. The urge to tear something open and solder wires is overwhelming sometimes .
Completly different microcontroller/radio-chips so there is no compatibility whatsoever. If you flash a binary firmware image meant for one microcontroller/radio-chip onto any other chip you will brick it.
