Zigbee2Mqtt 2.0 - IKEA five button remote
The Zigbee2MQTT team lead has just confirmed that the reaction from the users have made him postpone the removal for a very long time. Especially the Node Red users are in trouble.
If you want an example of the 5 button remote here is mine using the new actions
alias: Tradfri PH Dimmer
triggers:
  - trigger: state
    entity_id: event.ph_dimmer_action
    not_from: unavailable
actions:
  - choose:
      - conditions:
          - condition: template
            value_template: "{{trigger.to_state.attributes.event_type == 'toggle'}}"
          - condition: state
            entity_id: light.ph
            state: "off"
        sequence:
          - data:
              entity_id:
                - light.ph
              brightness_pct: 80
            action: light.turn_on
      - conditions:
          - condition: state
            entity_id: light.ph
            state: "on"
        sequence:
          - data:
              entity_id:
                - light.ph
            action: light.turn_off
      - conditions:
          - "{{trigger.to_state.attributes.event_type == 'brightness_up_hold'}}"
        sequence:
          - action: mqtt.publish
            metadata: {}
              topic: zigbee2mqtt/PH/set
              payload: "{\"brightness_move\": 50 }"
      - conditions:
          - "{{trigger.to_state.attributes.event_type == 'brightness_down_hold'}}"
        sequence:
            metadata: {}
              payload: "{\"brightness_move\": -50 }"
      - conditions:
            {{trigger.to_state.attributes.event_type in
            ('brightness_up_release', 'brightness_down_release')}}
        sequence:
            metadata: {}
              payload: "{\"brightness_move\": 0 }"
      - conditions:
          - "{{trigger.to_state.attributes.event_type == 'arrow_right_click'}}"
        sequence:
          - data:
              topic: blinds/step/left
              payload: "10"
          - data:
              topic: blinds/step/right
              payload: "10"
      - conditions:
            value_template: "{{trigger.to_state.attributes.event_type == 'arrow_left_click'}}"
        sequence:
          - data:
              payload: "-10"
          - data:
              payload: "-10"
      - conditions:
            value_template: "{{trigger.to_state.attributes.event_type == 'arrow_right_hold'}}"
        sequence:
          - data:
              topic: blinds/set/left
              payload: "50"
          - data:
              topic: blinds/set/right
              payload: "50"
      - conditions:
            value_template: "{{trigger.to_state.attributes.event_type == 'arrow_left_hold'}}"
        sequence:
          - data:
              payload: "0"
          - data:
              payload: "0"
initial_state: "on"
mode: queued
max_exceeded: silent
Just to be clear, the updated blueprint does not use legacy triggers
z2m 2.0.0.2 and latest HA with blueprint “Controller - IKEA E1524/E1810 TRÅDFRI Wireless 5-Button Remote” there is no entity ((Zigbee2MQTT) Controller Entity) for Ikea remote. My z2m does not use legacy option. Am I doing something wrong?
Download blueprint again, there’s been a update few days ago.
Same here, removed and repaired the contrroller and it is i NOT in HA
I think you’re using the old blueprint. It should say “Device” not “Entity”
this is what I use, imported it today
it shows device for ZHA… but not for Zigbee2MQTT
it is a BP from here
Sorry, that’s a different blueprint than mine. I suppose they have not updated to use Device Entities yet. Feel free to import my blueprint with the forum link:
in your BP, the lights entiuty is neccessary? I use the button to switch random stuff.
Remember
If you are happy with things from before 2.0 and your old blueprint or automation works fine. Just reenable the Home Assistant legacy sensors
The Zigbee2MQTT team has admitted the new event actions are not ready and the deprecation of the old is postponed with no known deadline.
In the screenshot I have enabled both the new and the old legacy sensors. It is easier to set in the UI than editing the config.
it worked, seems I had to add some light although I`m not using the button to control light , but buttons now work to trigger switches I need to
Yes, that’s the primary use for this blueprint. Setting the lights entity (or entities) enables the brightness up and down buttons to work as brightness up/down on the lights. I actually used the blueprint you referenced with another remote a while ago.
thanks starbuck93, works fine.
Although I do miss the default option to change from warm white to cool white (color temp, which should also be adjusted to use color temp kelvin).
Maybe that is a different blueprint? Don’t know.
How to set when I turn on and off lights to go imediatly ON and OFF not smothly ON OFF , how to edit this when i already add blueprint.
Update - Solved - I edited file to transition form 1 to 0 on toggle.
One more question:
To me this blueprint works perfect but I am getting errors in code:
domain: automation
input:
remote:
description: IKEA remote to use
selector:
device:
integration: mqtt — HERE IS ERROR: String is not matching patern - LEGACY_SYNTAX
manufacturer: IKEA — HERE IS ERROR: String is not matching patern - LEGACY_SYNTAX
How to solve this to not be red, or just to leave everything if all works perfect ?
thanks for the great blueprint.
just the toggle of the light with the middle button does not work for me. i can turn of the light with the middle button, but to turn the light back on, i have to press the dim up button which is not nice. any idea what i am doing wrong?
thanks
@TheSpirit I would look at the trace logs and see what’s happening when you push the toggle to turn the light back on
Good job, work fine. :clap:
Just remeber to enable experimental_event_entities and legacy_action_sensor in Zigbee2MQTT Settings → “Home Assistant Integration”
