Thanks for the information.
Thanks for the information. I have couple of questions though.
- Is there any reason why you plug to other USB port other than the previous zigbee stick port?
- Are you using USB 2.0 or USB 3.0 port?
Nope, no specific reason to change the USB port, I just thought, it might be giving trouble and I had one unused left, why not change. Normally it shoudnāt matter, as long as the port is correctly configured in Z2M.
I used the USB2.0 ports on the rPi4, for the old and new dongle.
I just tried to upgrade my CC2531 stick to CC2652P today by following your instructions. Unfortunately, my zigbee devices doesnāt joining to the new stick. How long does you have to wait actually for the device to join to the new stick?
Also, when I plug back my old CC2531 stick, all the devices rejoin instantly.
Regarding the pan_id, are you saying the zigbee2mqtt will actually update pan_id by itself when starts with the new stick? My pan_id is 6754 and when I notice it didnāt change when I start the zigbee2mqtt with the new stick. According to zigbee2mqtt doc, it seems we have to increment the pan_id when moving to new stick. Can you please confirm?
Thanks.
hello @nonyhaha, @francisp and everyone,
anybody can help me verify whether after upgrading the zigbee stick, oneās network is on 3.0?
thanks!
if your coordinator is zStack3xx, youāre on Zigbee 3
thanks a lot @francisp !! that is precisely what I see, however I canāt seem to be able to pair the few zigbee 3.0 devices that I have. I created an issue with z2M in github and I hope I will be following it up with Koenkk soon.
If you have the time, your feedback would be great: Lidl smart plug HG06337 not detected Ā· Issue #6714 Ā· Koenkk/zigbee2mqtt (github.com)
What Zigbee2MQTT version are you on ?
I can only offer my troubleshooting way with pairing issues :
- restart Zigbee2MQTT
- immediately after the restart pair very close to the coordinator.
Will try that leter when Iām back home. I do the pairing sitting next by the coordinator, but I will restart the add-on first!!
Im having the same issue. Did you end up getting yours to work? or did you end up having to re-pair?
If you are using the latest zigbee2mqtt (>1.21.0), it will auto backup all the zigbee devices when you stopped the addon and it will load the configuration into the new stick.
I didnāt re-pair my zigbee devices. All the zigbee devices will re-join and it will take little longer at the first time. So just need to be patient. Also, the new CC2652P draw more current than the CC2531, so you have to make sure you are using a decent power supply. Or put the CC2652P stick into USB powered hub.
Thanks for the fast reply. I believe I have done all of this, and after 20 minutes the devices still arent connected. I am coming from a CC2531 running 1.2 firmware and going to the sonoff zibgee stick 3.0 which is CC2652P, which i have flashed with CC1352P2_CC2652P_launchpad_coordinator_20210708. Z2M is running version 1.22 and there are no errors in the log other than when I try to turn a light off and it times out on receiving a signal.
In your first post you mentioned that it didnt work, was it just a case of waiting?
Are all devices also failing or it is particular device? Did the zigbee2mqtt actually able to talk to your new stick? Maybe you can share some z2m logs when starting the zigbee2mqtt addon here with the new stick.
Thanks for replying, none of the devices seem to connect even after 20 minutes. I try to update the map to ping all the devices and they all return errors. It looks like Z2M is communicating with the stick as it brings up the firmware version.
These are the logs when i start
> node index.js
Zigbee2MQTT:info 2021-11-17 21:21:59: Logging to console and directory: '/config/zigbee2mqtt/log/2021-11-17.21-21-58' filename: log.txt
Zigbee2MQTT:info 2021-11-17 21:21:59: Starting Zigbee2MQTT version 1.22.0 (commit #unknown)
Zigbee2MQTT:info 2021-11-17 21:21:59: Starting zigbee-herdsman (0.13.164)
Zigbee2MQTT:info 2021-11-17 21:21:59: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2021-11-17 21:21:59: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"}'
Zigbee2MQTT:info 2021-11-17 21:21:59: Currently 12 devices are joined:
Zigbee2MQTT:info 2021-11-17 21:21:59: 0x00178801086dd9de (0x00178801086dd9de): 324131092621 - Philips Hue dimmer switch (EndDevice)
Zigbee2MQTT:info 2021-11-17 21:21:59: 0x00178801086ddb37 (0x00178801086ddb37): 324131092621 - Philips Hue dimmer switch (EndDevice)
Zigbee2MQTT:info 2021-11-17 21:21:59: 0x00158d00032ca98e (0x00158d00032ca98e): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
Zigbee2MQTT:info 2021-11-17 21:21:59: 0x001788010343d126 (0x001788010343d126): 8718696548738 - Philips Hue white ambiance E26/E27 (Router)
Zigbee2MQTT:info 2021-11-17 21:21:59: 0x0017880104eaafdc (0x0017880104eaafdc): 8718696548738 - Philips Hue white ambiance E26/E27 (Router)
Zigbee2MQTT:info 2021-11-17 21:21:59: 0x588e81fffe3ec41c (0x588e81fffe3ec41c): LED1732G11 - IKEA TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white (Router)
Zigbee2MQTT:info 2021-11-17 21:21:59: 0x00158d0004528f9f (0x00158d0004528f9f): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
Zigbee2MQTT:info 2021-11-17 21:21:59: 0x00158d0003931b71 (0x00158d0003931b71): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
Zigbee2MQTT:info 2021-11-17 21:21:59: 0x588e81fffe3ec345 (0x588e81fffe3ec345): LED1732G11 - IKEA TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white (Router)
Zigbee2MQTT:info 2021-11-17 21:21:59: 0x00124b001cd6a51b (0x00124b001cd6a51b): YSR-MINI-01_wwcw - YSRSAI Zigbee LED controller (WW/CW) (Router)
Zigbee2MQTT:info 2021-11-17 21:21:59: 0x00124b0022cd49da (0x00124b0022cd49da): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:info 2021-11-17 21:21:59: 0x00124b0022e8f687 (0x00124b0022e8f687): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:info 2021-11-17 21:21:59: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2021-11-17 21:22:00: Connecting to MQTT server at mqtt://192.168.1.38:1883
Zigbee2MQTT:info 2021-11-17 21:22:00: Connected to MQTT server
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Zigbee2MQTT:warn 2021-11-17 21:22:00: Using experimental new availability feature
Zigbee2MQTT:info 2021-11-17 21:22:00: Started frontend on port 0.0.0.0:8099
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"unknown","coordinator":{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"},"log_level":"info","network":{"channel":25,"extendedPanID":"0xdddddddddddddddd","panID":6754},"permit_join":false,"version":"1.22.0"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/sensor/0x00178801086dd9de/battery/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00178801086dd9de"],"manufacturer":"Philips","model":"Hue dimmer switch (324131092621)","name":"0x00178801086dd9de","sw_version":"Zigbee2MQTT 1.22.0"},"device_class":"battery","enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/0x00178801086dd9de","name":"0x00178801086dd9de battery","state_class":"measurement","state_topic":"zigbee2mqtt/0x00178801086dd9de","unique_id":"0x00178801086dd9de_battery_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.battery }}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/sensor/0x00178801086dd9de/action/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00178801086dd9de"],"manufacturer":"Philips","model":"Hue dimmer switch (324131092621)","name":"0x00178801086dd9de","sw_version":"Zigbee2MQTT 1.22.0"},"enabled_by_default":true,"icon":"mdi:gesture-double-tap","json_attributes_topic":"zigbee2mqtt/0x00178801086dd9de","name":"0x00178801086dd9de action","state_topic":"zigbee2mqtt/0x00178801086dd9de","unique_id":"0x00178801086dd9de_action_zigbee2mqtt","value_template":"{{ value_json.action }}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/sensor/0x00178801086dd9de/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00178801086dd9de"],"manufacturer":"Philips","model":"Hue dimmer switch (324131092621)","name":"0x00178801086dd9de","sw_version":"Zigbee2MQTT 1.22.0"},"enabled_by_default":false,"icon":"mdi:signal","json_attributes_topic":"zigbee2mqtt/0x00178801086dd9de","name":"0x00178801086dd9de linkquality","state_class":"measurement","state_topic":"zigbee2mqtt/0x00178801086dd9de","unique_id":"0x00178801086dd9de_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/sensor/0x00178801086dd9de/update_state/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00178801086dd9de"],"manufacturer":"Philips","model":"Hue dimmer switch (324131092621)","name":"0x00178801086dd9de","sw_version":"Zigbee2MQTT 1.22.0"},"enabled_by_default":false,"icon":"mdi:update","json_attributes_topic":"zigbee2mqtt/0x00178801086dd9de","name":"0x00178801086dd9de update state","state_topic":"zigbee2mqtt/0x00178801086dd9de","unique_id":"0x00178801086dd9de_update_state_zigbee2mqtt","value_template":"{{ value_json['update']['state'] }}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/binary_sensor/0x00178801086dd9de/update_available/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00178801086dd9de"],"manufacturer":"Philips","model":"Hue dimmer switch (324131092621)","name":"0x00178801086dd9de","sw_version":"Zigbee2MQTT 1.22.0"},"enabled_by_default":false,"json_attributes_topic":"zigbee2mqtt/0x00178801086dd9de","name":"0x00178801086dd9de update available","payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/0x00178801086dd9de","unique_id":"0x00178801086dd9de_update_available_zigbee2mqtt","value_template":"{{ value_json.update_available}}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/sensor/0x00178801086ddb37/battery/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00178801086ddb37"],"manufacturer":"Philips","model":"Hue dimmer switch (324131092621)","name":"0x00178801086ddb37","sw_version":"Zigbee2MQTT 1.22.0"},"device_class":"battery","enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/0x00178801086ddb37","name":"0x00178801086ddb37 battery","state_class":"measurement","state_topic":"zigbee2mqtt/0x00178801086ddb37","unique_id":"0x00178801086ddb37_battery_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.battery }}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/sensor/0x00178801086ddb37/action/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00178801086ddb37"],"manufacturer":"Philips","model":"Hue dimmer switch (324131092621)","name":"0x00178801086ddb37","sw_version":"Zigbee2MQTT 1.22.0"},"enabled_by_default":true,"icon":"mdi:gesture-double-tap","json_attributes_topic":"zigbee2mqtt/0x00178801086ddb37","name":"0x00178801086ddb37 action","state_topic":"zigbee2mqtt/0x00178801086ddb37","unique_id":"0x00178801086ddb37_action_zigbee2mqtt","value_template":"{{ value_json.action }}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/sensor/0x00178801086ddb37/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00178801086ddb37"],"manufacturer":"Philips","model":"Hue dimmer switch (324131092621)","name":"0x00178801086ddb37","sw_version":"Zigbee2MQTT 1.22.0"},"enabled_by_default":false,"icon":"mdi:signal","json_attributes_topic":"zigbee2mqtt/0x00178801086ddb37","name":"0x00178801086ddb37 linkquality","state_class":"measurement","state_topic":"zigbee2mqtt/0x00178801086ddb37","unique_id":"0x00178801086ddb37_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/sensor/0x00178801086ddb37/update_state/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00178801086ddb37"],"manufacturer":"Philips","model":"Hue dimmer switch (324131092621)","name":"0x00178801086ddb37","sw_version":"Zigbee2MQTT 1.22.0"},"enabled_by_default":false,"icon":"mdi:update","json_attributes_topic":"zigbee2mqtt/0x00178801086ddb37","name":"0x00178801086ddb37 update state","state_topic":"zigbee2mqtt/0x00178801086ddb37","unique_id":"0x00178801086ddb37_update_state_zigbee2mqtt","value_template":"{{ value_json['update']['state'] }}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/binary_sensor/0x00178801086ddb37/update_available/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00178801086ddb37"],"manufacturer":"Philips","model":"Hue dimmer switch (324131092621)","name":"0x00178801086ddb37","sw_version":"Zigbee2MQTT 1.22.0"},"enabled_by_default":false,"json_attributes_topic":"zigbee2mqtt/0x00178801086ddb37","name":"0x00178801086ddb37 update available","payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/0x00178801086ddb37","unique_id":"0x00178801086ddb37_update_available_zigbee2mqtt","value_template":"{{ value_json.update_available}}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/sensor/0x00158d00032ca98e/battery/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00158d00032ca98e"],"manufacturer":"Xiaomi","model":"Aqara vibration sensor (DJT11LM)","name":"0x00158d00032ca98e","sw_version":"Zigbee2MQTT 1.22.0"},"device_class":"battery","enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/0x00158d00032ca98e","name":"0x00158d00032ca98e battery","state_class":"measurement","state_topic":"zigbee2mqtt/0x00158d00032ca98e","unique_id":"0x00158d00032ca98e_battery_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.battery }}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/sensor/0x00158d00032ca98e/action/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00158d00032ca98e"],"manufacturer":"Xiaomi","model":"Aqara vibration sensor (DJT11LM)","name":"0x00158d00032ca98e","sw_version":"Zigbee2MQTT 1.22.0"},"enabled_by_default":true,"icon":"mdi:gesture-double-tap","json_attributes_topic":"zigbee2mqtt/0x00158d00032ca98e","name":"0x00158d00032ca98e action","state_topic":"zigbee2mqtt/0x00158d00032ca98e","unique_id":"0x00158d00032ca98e_action_zigbee2mqtt","value_template":"{{ value_json.action }}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/sensor/0x00158d00032ca98e/strength/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00158d00032ca98e"],"manufacturer":"Xiaomi","model":"Aqara vibration sensor (DJT11LM)","name":"0x00158d00032ca98e","sw_version":"Zigbee2MQTT 1.22.0"},"enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/0x00158d00032ca98e","name":"0x00158d00032ca98e strength","state_topic":"zigbee2mqtt/0x00158d00032ca98e","unique_id":"0x00158d00032ca98e_strength_zigbee2mqtt","value_template":"{{ value_json.strength }}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/sensor/0x00158d00032ca98e/sensitivity/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00158d00032ca98e"],"manufacturer":"Xiaomi","model":"Aqara vibration sensor (DJT11LM)","name":"0x00158d00032ca98e","sw_version":"Zigbee2MQTT 1.22.0"},"enabled_by_default":false,"icon":"mdi:tune","json_attributes_topic":"zigbee2mqtt/0x00158d00032ca98e","name":"0x00158d00032ca98e sensitivity","state_topic":"zigbee2mqtt/0x00158d00032ca98e","unique_id":"0x00158d00032ca98e_sensitivity_zigbee2mqtt","value_template":"{{ value_json.sensitivity }}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/select/0x00158d00032ca98e/sensitivity/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"command_topic":"zigbee2mqtt/0x00158d00032ca98e/set/sensitivity","device":{"identifiers":["zigbee2mqtt_0x00158d00032ca98e"],"manufacturer":"Xiaomi","model":"Aqara vibration sensor (DJT11LM)","name":"0x00158d00032ca98e","sw_version":"Zigbee2MQTT 1.22.0"},"enabled_by_default":false,"icon":"mdi:tune","json_attributes_topic":"zigbee2mqtt/0x00158d00032ca98e","name":"0x00158d00032ca98e sensitivity","options":["low","medium","high"],"state_topic":"zigbee2mqtt/0x00158d00032ca98e","unique_id":"0x00158d00032ca98e_sensitivity_zigbee2mqtt","value_template":"{{ value_json.sensitivity }}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/sensor/0x00158d00032ca98e/angle_x/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00158d00032ca98e"],"manufacturer":"Xiaomi","model":"Aqara vibration sensor (DJT11LM)","name":"0x00158d00032ca98e","sw_version":"Zigbee2MQTT 1.22.0"},"enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/0x00158d00032ca98e","name":"0x00158d00032ca98e angle x","state_topic":"zigbee2mqtt/0x00158d00032ca98e","unique_id":"0x00158d00032ca98e_angle_x_zigbee2mqtt","value_template":"{{ value_json.angle_x }}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/sensor/0x00158d00032ca98e/angle_y/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00158d00032ca98e"],"manufacturer":"Xiaomi","model":"Aqara vibration sensor (DJT11LM)","name":"0x00158d00032ca98e","sw_version":"Zigbee2MQTT 1.22.0"},"enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/0x00158d00032ca98e","name":"0x00158d00032ca98e angle y","state_topic":"zigbee2mqtt/0x00158d00032ca98e","unique_id":"0x00158d00032ca98e_angle_y_zigbee2mqtt","value_template":"{{ value_json.angle_y }}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/sensor/0x00158d00032ca98e/angle_z/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00158d00032ca98e"],"manufacturer":"Xiaomi","model":"Aqara vibration sensor (DJT11LM)","name":"0x00158d00032ca98e","sw_version":"Zigbee2MQTT 1.22.0"},"enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/0x00158d00032ca98e","name":"0x00158d00032ca98e angle z","state_topic":"zigbee2mqtt/0x00158d00032ca98e","unique_id":"0x00158d00032ca98e_angle_z_zigbee2mqtt","value_template":"{{ value_json.angle_z }}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/sensor/0x00158d00032ca98e/voltage/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00158d00032ca98e"],"manufacturer":"Xiaomi","model":"Aqara vibration sensor (DJT11LM)","name":"0x00158d00032ca98e","sw_version":"Zigbee2MQTT 1.22.0"},"device_class":"voltage","enabled_by_default":false,"json_attributes_topic":"zigbee2mqtt/0x00158d00032ca98e","name":"0x00158d00032ca98e voltage","state_class":"measurement","state_topic":"zigbee2mqtt/0x00158d00032ca98e","unique_id":"0x00158d00032ca98e_voltage_zigbee2mqtt","unit_of_measurement":"mV","value_template":"{{ value_json.voltage }}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/sensor/0x00158d00032ca98e/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00158d00032ca98e"],"manufacturer":"Xiaomi","model":"Aqara vibration sensor (DJT11LM)","name":"0x00158d00032ca98e","sw_version":"Zigbee2MQTT 1.22.0"},"enabled_by_default":false,"icon":"mdi:signal","json_attributes_topic":"zigbee2mqtt/0x00158d00032ca98e","name":"0x00158d00032ca98e linkquality","state_class":"measurement","state_topic":"zigbee2mqtt/0x00158d00032ca98e","unique_id":"0x00158d00032ca98e_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/light/0x001788010343d126/light/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"brightness":true,"brightness_scale":254,"color_mode":true,"command_topic":"zigbee2mqtt/0x001788010343d126/set","device":{"identifiers":["zigbee2mqtt_0x001788010343d126"],"manufacturer":"Philips","model":"Hue white ambiance E26/E27 (8718696548738)","name":"0x001788010343d126","sw_version":"Zigbee2MQTT 1.22.0"},"effect":true,"effect_list":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"json_attributes_topic":"zigbee2mqtt/0x001788010343d126","max_mireds":500,"min_mireds":150,"name":"0x001788010343d126","schema":"json","state_topic":"zigbee2mqtt/0x001788010343d126","supported_color_modes":["color_temp"],"unique_id":"0x001788010343d126_light_zigbee2mqtt"}'
Zigbee2MQTT:info 2021-11-17 21:22:00: MQTT publish: topic 'homeassistant/sensor/0x001788010343d126/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x001788010343d126"],"manufacturer":"Philips","model":"Hue white ambiance E26/E27 (8718696548738)","name":"0x001788010343d126","sw_version":"Zigbee2MQTT 1.22.0"},"enabled_by_default":false,"icon":"mdi:signal","json_attributes_topic":"zigbee2mqtt/0x001788010343d126","name":"0x001788010343d126
I might have figured out what i did wrong. I might have missed the step where when you flash the new device you are supposed to flash it with the old mac address. Is this a required step as it just says recommended.
I have the same problem, i am on zigbee2mqtt 1.22, and trying to migrate from a cc2531 to a sleash stick.
So i stopt z2m replaced in de config the new path for the new stick and started z2m.
I have 19 devices, 6 report back, aqara devices that report are working good, but the most do not report.
Af few blitzwolf plugs do report, only i can not turn them on of off, the reported values for energie usage are good tho.
Waited for 2 hours but still the same.
Put back a backup of the data folder and am Now back on the cc2531 stick.
Anyone an idee what goes wrong?
Hey guys, I just tried to flash my sonoff coordinator to latest version as I was one behind. I had understood that everything was supposed to be automatic now so I just flashed the new version. Except that when I start z2m I donāt have any device now ⦠Iām sweating a bit with 80 devices Iāve got, including some in my walls (for controlling the lights). Itād be massively painful to repair everythingā¦
I guess I shouldāve gone with the safe way of doing a backup first, rookie mistake Any hope I can get it to work fine as before knowing that I do have my file
configuration.yaml
, coordinator_backup.json
, database.db
and state.json
or should I just start repairing all of them ?
Ok took me 2 hours⦠but eventually I got it working. Mostly lucky I think⦠But hereās what Iāve done in case
