I have managed to get an amazing HA automated hydroponic grow system working 100% reliably for about a year, even though I have no programing abilities We had a major power outage last night and now I cannot communicate with any Zigbee devices in Z2MQTT. I rebooted Z2MQTT is set for auto turn on after reboot and always has. The ERROR message say "SOCAT not enabled " I am not sure what step to take next.
[12:51:13] INFO: Preparing to start...
[12:51:14] INFO: Socat not enabled
[12:51:15] ERROR: Got unexpected response from the API: Service not enabled
[12:51:15] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2023-03-10 12:51:21: Logging to console and directory: '/config/zigbee2mqtt/log/2023-03-10.12-51-21' filename: log.txt
Zigbee2MQTT:info 2023-03-10 12:51:21: Starting Zigbee2MQTT version 1.30.2 (commit #unknown)
Zigbee2MQTT:info 2023-03-10 12:51:21: Starting zigbee-herdsman (0.14.96)
Zigbee2MQTT:info 2023-03-10 12:51:22: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2023-03-10 12:51:22: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20220219,"transportrev":2},"type":"zStack3x0"}'
Zigbee2MQTT:info 2023-03-10 12:51:22: Currently 29 devices are joined:
Zigbee2MQTT:info 2023-03-10 12:51:22: Pump 1-f (0x00124b00226cb487): BASICZBR3 - SONOFF Zigbee smart switch (Router)
Zigbee2MQTT:info 2023-03-10 12:51:22: T-H Flower (0x00124b00251ec44c): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:info 2023-03-10 12:51:22: CO2-Meter (0xf4ce36de85abd142): Alab-CO2-1.0 - Alab [DiY CO2 Sensor](https://github.com/9zigen/) (Router)
Zigbee2MQTT:info 2023-03-10 12:51:22: pH (0xf4ce363b6f08b298): Alab-PhSensor-1.0 - Alab [DiY Wireless PH Sensor](https://github.com/9zigen/zigbee-ph-sensor) (EndDevice)
Zigbee2MQTT:info 2023-03-10 12:51:22: CO2 RELAY (0x00124b00226c90e7): BASICZBR3 - SONOFF Zigbee smart switch (Router)
Zigbee2MQTT:info 2023-03-10 12:51:22: Main Pump and aeration (0x00124b0022631839): BASICZBR3 - SONOFF Zigbee smart switch (Router)
Zigbee2MQTT:info 2023-03-10 12:51:22: Humidifier Relay (0x00124b0022d2e9ee): SA-003-Zigbee - eWeLink Zigbee smart plug (Router)
Zigbee2MQTT:info 2023-03-10 12:51:22: Airconditioner (0x00124b0022d2f71a): SA-003-Zigbee - eWeLink Zigbee smart plug (Router)
Zigbee2MQTT:info 2023-03-10 12:51:22: Roof Fan (0x00124b0022d2f379): SA-003-Zigbee - eWeLink Zigbee smart plug (Router)
Zigbee2MQTT:info 2023-03-10 12:51:22: Flower Light relay N-2-a (0x00124b0022d2e791): SA-003-Zigbee - eWeLink Zigbee smart plug (Router)
Zigbee2MQTT:info 2023-03-10 12:51:22: Flower Light relay N-1-a (0x00124b0022d2ef56): SA-003-Zigbee - eWeLink Zigbee smart plug (Router)
Zigbee2MQTT:info 2023-03-10 12:51:22: Flower Light relay S-3-w (0x00124b0022d2e2c2): SA-003-Zigbee - eWeLink Zigbee smart plug (Router)
Zigbee2MQTT:info 2023-03-10 12:51:22: Flower Light relay S-3-e (0x00124b0022d2e096): SA-003-Zigbee - eWeLink Zigbee smart plug (Router)
Zigbee2MQTT:info 2023-03-10 12:51:22: Flower Light relay S-1-w (0x00124b0022d2f374): SA-003-Zigbee - eWeLink Zigbee smart plug (Router)
Zigbee2MQTT:info 2023-03-10 12:51:22: Flower Light relay S-2-e (0x00124b0022d2ed81): SA-003-Zigbee - eWeLink Zigbee smart plug (Router)
Zigbee2MQTT:info 2023-03-10 12:51:22: T-H-cure (0x00124b0025155bee): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:info 2023-03-10 12:51:22: T-H Vent (0x00124b002515750c): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:info 2023-03-10 12:51:22: T-H Veg (0x00124b0025155501): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:info 2023-03-10 12:51:22: Loading dock door motion (0x00124b00244507fb): SNZB-03 - SONOFF Motion sensor (EndDevice)
Zigbee2MQTT:info 2023-03-10 12:51:22: T-H FL 2 (0x00124b0025155f35): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:info 2023-03-10 12:51:22: Loading dock Porch light (0x00124b0024bf40b7): ZBMINI-L - SONOFF Zigbee smart switch (no neutral) (EndDevice)
Zigbee2MQTT:info 2023-03-10 12:51:22: T-H F-3 CURE 2 (0x00124b0025152333): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:info 2023-03-10 12:51:22: T-H Bag 1 (0x00124b00251565e9): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:info 2023-03-10 12:51:22: T-H Bag 2 (0x00124b002515202c): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:info 2023-03-10 12:51:22: T-H Bag 3 (0x00124b00251568d9): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:info 2023-03-10 12:51:22: T=H Bag 4 (0x00124b00251579b7): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:warn 2023-03-10 12:51:22: `permit_join` set to `true` in configuration.yaml.
Zigbee2MQTT:warn 2023-03-10 12:51:22: Allowing new devices to join.
Zigbee2MQTT:warn 2023-03-10 12:51:22: Set `permit_join` to `false` once you joined all devices.
Zigbee2MQTT:info 2023-03-10 12:51:22: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2023-03-10 12:51:22: Connecting to MQTT server at mqtt://core-mosquitto:1883
Zigbee2MQTT:error 2023-03-10 12:51:26: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
Zigbee2MQTT:error 2023-03-10 12:51:26: MQTT failed to connect, exiting...
Zigbee2MQTT:info 2023-03-10 12:51:26: Stopping zigbee-herdsman...
Zigbee2MQTT:error 2023-03-10 12:51:27: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
Zigbee2MQTT:error 2023-03-10 12:51:28: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
Zigbee2MQTT:error 2023-03-10 12:51:29: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
Zigbee2MQTT:error 2023-03-10 12:51:30: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
Zigbee2MQTT:error 2023-03-10 12:51:34: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
Zigbee2MQTT:error 2023-03-10 12:51:35: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
Zigbee2MQTT:info 2023-03-10 12:51:36: Stopped zigbee-herdsman
