except of 5, they all came “back”.
5 of the devices i had to reconnect manually. (one is left, its the most worse accessable device i have, the rainsensor  dyi made from here rain gauge)
but i recognized a very strange behavior of zigbee2mqtt MAP, what did not get better until yesterday… (the map is rebuilt badly every time)
many of the devices are “linked” to coord or routers (dashed line or solid lines), but some of them, do not “glide” and “reorientate” on the map automatically as usual. i recognized all of the “glued to the map”, do show a “0” on the connections lines, what means, linkquality = 0?  But device page shows me real link qualities for all of them, and hassio recorder history stat do show me changing lqi stats regularly, but NOT “0”. so only the map in z2m does not work correct any longer?
i dont know if it´s due to the last update of z2m, or of the newly added routers (2 more since 2 weeks), or the 10 new devices since approx 1 week… or the fw-flashing of the 3 existing routers … if i move one of the router-bubbles all of the other bubbles do wobble around and glide to new positions, except the red marked… those are frozen…
what i also had recognized (in the past and todays much more): many of the devices do have an unstable linkquality (even i had just 40 devices). it seems only the ones connected to the coordinator are “stable” (see history graph “flatlines”) the others do vary very much… 80 to 7 lqi. especially the raingauge sensor had lost connection since the beginning, what decided me to reposition the raingauge first, but without any success, i added two more routers… but it does not became better… rain sensor regularyl lost connection (could be long term 50-80, then off instantly, could be good weather or raining…) i have an addittional temp (weather) sensor of aqara at the same spot, without any issue since ever? anoying… i cant access rain gauge, when its raining ort had rained…
i plan to use more routers, but honestly i dont now where to place and how to manage power source for them  ( i assmue it would not make sence to place two at the same place?)
but i wonder: one router should handle 50 devices as described here?
i have 5 routes + coord? i have “only” 75 devices? shouldn´t be enough? all devices are in range about 10 meters in the house, 3 floor-levels… brick walls
By model
lumi.weather: 56
lumi.airrtc.agl001: 12
lumi.sensor_magnet.aq2: 8
ti.router: 5
another thought: except of the coordinator, all 5 routers  are connected to a plugin power usbsource directly to a wall socket. i plan to make extension cables for all of them. Maybe proximity to the electrical wiring does have any influcence?
but what bothers me a lot, the last 3 routers i had flashedrecently, do NOT show the firmware version in hasso i have flashed? could it be data in hassio (z2m) is outdated, and not beeing updated? i have rebooted, and i had shut off the system to unplug coord from rasp… and since then restartet z2m integration twice?
