Zigbee2MQTT - Tuya 4-button Scene Switch (TS0044)
Hey @aiditz, I’ve been using your converter since months ago and worked perfectly! Thanks for that!
But since the last Z2M update (1.21.2-1) the converter is not working anymore. I get the default actions (on,off,brightness up & down).
Is there a way to fix this?
Since the last Z2M update this blueprint no longer works properly, namely:
  • if there is no change in the state it ignores the press of a button
  • if there is a change in the state (different button is pressed) it executes the previous command.
I have traced and researched so far, but my coding skills it this area are not sufficient to repair the blueprint.
Thanks in advance for any suggestion.
Have people got this working on zigbee2mqtt? as soon as i add the line for the convertor and restart z2mqtt, it fails to load.
You can use mqtt trigger in place of sensor. Everything remains the same.
Logger: homeassistant.components.automation
Source: components/automation/__init__.py:646
Integration: Automation (documentation, issues)
First occurred: 4:49:40 PM (6 occurrences)
Last logged: 4:51:29 PM
Blueprint Zigbee2MQTT - Tuya 4-Button Scene Switch generated invalid automation with inputs OrderedDict([('switch', 'sensor.office_switch_action'), ('button_one_short_press', [OrderedDict([('service', 'climate.turn_on'), ('data', OrderedDict()), ('entity_id', 'climate.office_ac')])]), ('button_one_double_press', [OrderedDict([('service', ''), ('data', OrderedDict())])]), ('button_one_long_press', [OrderedDict([('service', 'climate.turn_off'), ('data', OrderedDict()), ('entity_id', 'climate.office_ac')])])]): Service does not match format <domain>.<name> for dictionary value @ data['action'][1]['choose'][4]['sequence'][0]['service']. Got None
I keep getting this error but I don’t see any corresponding automation. Any idea on how to fix this error?
For everyone that updated Zigbee2MQTT or the Blueprint stopped working in General,
Try changing this Part of the Code
- choose:
  - conditions:
    - '{{ topic.split(''/'')[1].replace(''/'', '''') == deviceName.split('' '')[0]
    sequence:
    - choose:
      - conditions:
        - '{{ command == ''1_single'' }}'
        sequence: !input 'button_one_short_press'
      - conditions:
        - '{{ command == ''3_single'' }}'
        sequence: !input 'button_two_short_press'
      - conditions:
        - '{{ command == ''2_single'' }}'
        sequence: !input 'button_three_short_press'
      - conditions:
        - '{{ command == ''4_single'' }}'
        sequence: !input 'button_four_short_press'
      - conditions:
        - '{{ command == ''2_hold'' }}'
        sequence: !input 'button_three_long_press'
      - conditions:
        - '{{ command == ''4_hold'' }}'
        sequence: !input 'button_four_long_press'
This should make it work again, only the Package Content of Mqtt was changed
Bought one recently here: Tuya Smart ZigBee Smart Switch 4 Gang Scenario 12 Scene Switch Push Button Controller Support deCONZ Tuya Hub|Building Automation| - AliExpress
With the latest update of zigbee2mqtt the blueprint also works with the TS004F Model n ° ESW-0ZAA-EU (branded above the battery with number ESW-0ZBA-EU)
Link:
https://www.zigbee2mqtt.io/devices/TS004F.html
GRAZIE!
Guys I have the zemismart 4 scene button connected to my SmartThings hub and works ok but in HA I can only get the Button 1 to work 2/3/4 do now work but maybe I am not calling it correctly?
You can see the button names here:
And this works image
But if I call Home Cinema Scene Button 1 or 2/3/4 it does not.
Any ideas? All buttons do work ok on the ST side but not on HA (child buttons do not work or I do not know what their names are?)
This blueprint seems broken with the most recent versions of both Zigbee2MQTT and Homeassistant. With the original blueprint the 4-button switch never triggers the automation. With the change from konnectedvn, further on in this topic, the automation gets triggered, but there’s no response to any of the actions.
I have the TuYa TS0044.
Has anyone else this behaviour? Any easy way to fix it? I now wrote my own automation, which works fine, but is tedious. A proper blueprint would be much better.
yep. just upgraded and none of my switches work with this blueprint… the automation does not get triggered.
mine does not work too…
Created my blueprint with original code from first message to figure out what happened.
Works for me if I remove (or comment) line
  attribute: action
here
- platform: state
  entity_id: !input "switch"
  attribute: action
Can confirm this worked for me when setting up today thank you :slight_smile:
Make sure the Home Assistant Legacy and general Legacy switches in Z2M are set constantly. This is what’s messing you up I believe.
I don’t have this switch so I can’t tell you how this blueprint was designed to use what set-up for these legacy switches, but this is likely causing the inconsistencies.
You-all need to look at these and see how they are set and you will likely find the actual problem without having to change the blueprint code.
Just added one of these switches to Home Assistant and couldn’t get anything to work from the blueprint.
In Zigbee2MQTT
Enabled - Home Assistant legacy entity attributes (was previously disabled)
Enabled - Home Assistant legacy triggers
The blueprint now works perfectly. No other changes needed.
Thanks for the tip.
Good afternoon all,
has anyone of you got batteries issues on this 4-button zigbee scene switch?
I have received them recently and I configured them with Deconz (only the single press effective so far, but ok for me), but after one day, all 4 green diodes started flashing rapidly and it was not sending any command.
The documentation being very poor, I can but assume that this rapid flashing could be related to a low battery signal, but I was not expecting it to be out so fast.
Maybe my batteries were old, but before re-starting, has anyone experience this 4-Diodes simultaneous rapid flashing?
Thanks in advance
Vincent
its a battery low signal. maybe you got a bad battery?
I have this switch and use it with this blueprint and its great but after 2022.7 I have had problems.
The switch works and zigbee2mqtt log shows the keypresses. but may automation is not triggered.
I can get it working again by restarting zigbee2mqtt. everything else on the network works fine . even my 4 button ikea switch…
anyone has the same problem?
i will ask a better place but I assume TS0044 users see this :slight_smile:
BR Andy
see a couple messages up
