Zigbee2MQTT Tuya Moes Smart Knob (ERS-10TZBVK-AA)
Do you have the new (white) rotary button by any chance? Like this one: https://a.aliexpress.com/_EQayxwC
And would you mind sharing your full automation?
i don`t have that particular model. The ones i use are similar to this one and show up as Tuya ERS-10TZBVK-AA
i use my blue print for setting up the devices
I decided to use switch manager. I should’ve known about this tool earlier! It’s really great and available on HACS.
I use your blueprint for months and works perfect!.
With the new zigbee2mqtt version 2.x do you will migrate the blueprint or create new for the new mqtt events system?
Hello, good to hear that its working perfect!.
I haven’t had time to upgrade to new version but reading change list i don`t see anything that could break this blueprint.
This because the blueprint uses the mqtt platform for detecting changes and as long the topics or state entitie don`t change it should just work.
But don`t know for sure unless i have tested this :slight_smile:
I’m switching my stuff to the entity events If I can pull it off…
Ok. My automation stop working and I think is for the zigbee2mqtt changes.
I will test better
Edit:
Yes, its my fault.
Works fine
Hello Pbergman,
I used the blueprint for an automation and commands on/off and dim work fine. Many thanks for that :slight_smile:
The Command | Color Temperature Up and Command | Color Temperature Down I can’t get to work. I want to control RGB Led when I work at the table to cool white and in the evening to warm white by pressing the button and rotating.
How do I do that?
Wilfried
Hello Wilfred,
make sure you are in command mode and then you should be able press + turn to activate that command.
perhaps you should go to your device and check logs to see if it picks up the command.
I have a few of the " MOES Zigbee Smart Knob" (Tuya ERS-10TZBVK-AA)
in my Zigbee network and I have them all automated using the blueprints found here:
I have tried the blueprints for Z2M and ZHA in my home assistant setup and they all work fine for me.
Where can I find that step size code in the Yaml to edit?
I’m using this knob for volume control on my Sonos in HA. Command mode works much faster than event mode, but it still only goes up 2/100th for every rotation click. So I have to turn it a number of times to go up 10% in volume. I’d rather it change 10% in volume when I twist it.
Thanks again for making this blueprint!
