How can I fix this?
Logger: homeassistant.components.automation
Source: components/automation/__init__.py:255
Integration: Automation (documentation, issues)
First occurred: 10:46:04 (4 occurrences)
Last logged: 10:46:04
Blueprint Aqara Magic Cube Zigbee2MQTT - 2022-05-05 generated invalid automation with inputs OrderedDict([('remote', 'sensor.cube_1_living_room_action_angle'), ('slide_any', []), ('doubletap_any', [OrderedDict([('type', 'turn_on'), ('device_id', 'dab8e2497c63bd8c393d94f80ae89456'), ('entity_id', 'light.0x00178801036fb1ab'), ('domain', 'light'), ('flash', 'short')]), OrderedDict([('device_id', ''), ('domain', ''), ('entity_id', '')])]), ('flipped90_any', [OrderedDict([('type', 'turn_off'), ('device_id', 'dab8e2497c63bd8c393d94f80ae89456'), ('entity_id', 'light.0x00178801036fb1ab'), ('domain', 'light')])]), ('rotate_cw_any', [OrderedDict([('device_id', 'dab8e2497c63bd8c393d94f80ae89456'), ('domain', 'light'), ('entity_id', 'light.0x00178801036fb1ab'), ('type', 'brightness_increase')])]), ('rotate_ccw_any', [OrderedDict([('device_id', 'dab8e2497c63bd8c393d94f80ae89456'), ('domain', 'light'), ('entity_id', 'light.0x00178801036fb1ab'), ('type', 'brightness_decrease')])])]): Integration '' not found. Got <homeassistant.components.blueprint.models.BlueprintInputs object at 0x7fd493fc1060>
Blueprint Aqara Magic Cube Zigbee2MQTT - 2022-05-05 generated invalid automation with inputs OrderedDict([('remote', 'sensor.cube_1_living_room_action'), ('rotate_ccw_any', [OrderedDict([('device_id', ''), ('domain', ''), ('entity_id', '')])])]): Integration '' not found. Got <homeassistant.components.blueprint.models.BlueprintInputs object at 0x7fd4940209d0>
Blueprint Aqara Magic Cube Zigbee2MQTT - 2022-05-05 generated invalid automation with inputs OrderedDict([('remote', 'sensor.0x00158d0007e39ff6_action'), ('shake', [OrderedDict([('service', 'scene.create'), ('data', OrderedDict([('scene_id', 'antesVictor'), ('snapshot_entities', 'light.hue_2_victor')]))]), OrderedDict([('repeat', OrderedDict([('count', '5'), ('sequence', [OrderedDict([('service', 'light.turn_on'), ('data', OrderedDict([('rgb_color', [0, 255, 0])])), ('target', OrderedDict([('device_id', 'bfa6e23d5dc48fdd1e384f747737d3b6')]))]), OrderedDict([('delay', OrderedDict([('hours', 0), ('minutes', 0), ('seconds', 1), ('milliseconds', 0)]))]), OrderedDict([('service', 'light.turn_on'), ('data', OrderedDict([('rgb_color', [0, 255, 255])])), ('target', OrderedDict([('device_id', 'bfa6e23d5dc48fdd1e384f747737d3b6')]))]), OrderedDict([('delay', OrderedDict([('hours', 0), ('minutes', 0), ('seconds', 1), ('milliseconds', 0)]))])])]))]), OrderedDict([('service', 'scene.turn_on'), ('target', OrderedDict([('entity_id', 'antesVictor')])), ('metadata', OrderedDict())])])]): not a valid value for dictionary value @ data['action'][2]['choose'][6]['sequence'][2]['target']['entity_id']. Got None
Blueprint Aqara Magic Cube Zigbee2MQTT - 2022-05-05 generated invalid automation with inputs OrderedDict([('remote', 'sensor.cube_2_babaciuni_room_action'), ('rotate_cw_any', [OrderedDict([('device_id', '32dc34d856fb18390539e535b30dee96'), ('domain', 'light'), ('entity_id', 'light.hue_bulb_babaciuni'), ('type', 'brightness_increase')]), OrderedDict([('device_id', ''), ('domain', ''), ('entity_id', '')])])]): Integration '' not found. Got <homeassistant.components.blueprint.models.BlueprintInputs object at 0x7fd493ef72b0>
