ScottS
September 4, 2023, 3:21am
1
I’m using Zone for presence tracking with 3 ‘persons’. Although each person indicates they are home, for example, the Zone state (zone.home) only indicates ‘2’. Why may this be?
123
(Taras)
September 4, 2023, 3:42am
2
Did Home Assistant configure the Home Zone or did you via YAML?
ScottS
September 4, 2023, 4:15am
3
Home assistant via Settings.
Edit: As I look closer, I’m the one not accounted for.
Edit 2: In Entities… Although there’s person.a, and person.b, I don’t see a person.scott. all 3 of us show an appropriate device_tracker.
ScottS
September 4, 2023, 5:01pm
4
Figured it out… I needed to basically recreate my person, following directions in this thread…
Not sure if there is a topic for this already, but here goes.
For anyone who has lost owner account access or has previously deleted the owner account, I discovered a way to update/change the account viewed as owner by home assistant.
You will need to install and configure SambaShare. Once the add on is running, download and open X-plore from the app store on your android device. I am unsure if this application is available on iOS.
Open the app and scan your LAN for servers. Home assi…
