pascalspits
(Pascal Standaert)
February 15, 2022, 10:06am
1
I have problems with my AEON Labs Home Energy Meter - Gen5 ZW095, manually the values get refreshed, automatically they don’t …
Diagnostics
Driver Version: 8.11.4
Server Version: 1.14.1
Home ID: 25482898
Server URL: ws://a0d7b954-zwavejs2mqtt:3000
I switched ON all parameters for Group 1
PARAMETER 101 Automatic Report: Group 1 - kWh (Whole HEM)
PARAMETER 101 Automatic Report: Group 1 - Power (Whole HEM)
PARAMETER 101 Automatic Report: Group 1 - Voltage (Whole HEM)
PARAMETER 101 Automatic Report: Group 1 - Current (Whole HEM)
PARAMETER 101 Automatic Report: Group 1 - Power (Clamp 1)
PARAMETER 101 Automatic Report: Group 1 - Power (Clamp 2)
PARAMETER 101 Automatic Report: Group 1 - Power (Clamp 3)
PARAMETER 101 Automatic Report: Group 1 - kWh (Clamp 1)
PARAMETER 101 Automatic Report: Group 1 - kWh (Clamp 2)
PARAMETER 101 Automatic Report: Group 1 - kWh (Clamp 3)
PARAMETER 101 Automatic Report: Group 1 - Voltage (Clamp 1)
PARAMETER 101 Automatic Report: Group 1 - Voltage (Clamp 2)
PARAMETER 101 Automatic Report: Group 1 - Voltage (Clamp 3)
PARAMETER 101 Automatic Report: Group 1 - Current (Clamp 1)
PARAMETER 101 Automatic Report: Group 1 - Current (Clamp 2)
PARAMETER 101 Automatic Report: Group 1 - Current (Clamp 3)
PARAMETER 111 Automatic Reporting Interval: Group 1 60 seconds
but it’s not working …
What did I do wrong ?
RickKramer
(Rick Kramer - Jansen)
February 15, 2022, 10:44am
2
Can you retrieve the current configuration for parameter 101? It should be a numeric value somewhere between 1 and 4144911. Based on your configuration above (enabled all parameters) it should be at 4144911 but perhaps you enabled the different settings too fast.
Home Energy Meter Gen5 setting your sensor to report. : Aeotec Help Desk
pascalspits
(Pascal Standaert)
February 15, 2022, 4:57pm
3
where could I retrieve this ?
pascalspits
(Pascal Standaert)
February 17, 2022, 8:02am
4
I did a reset and entered the settings again … still not reporting … huh ?
RickKramer
February 18, 2022, 6:58am
5
Is ANY of the entities updating? Just to verify there is maybe some bug in setting the correct value on parameter 101. As you use Z-WaveJS2MQTT (based on your Server URL) you should be able to check the Device configuration in the web interface to see which settings are active after reinterviewing the device.
Open the Z-WaveJS2MQTT web interface through the addon
In the control panel open your device
Using the Advanced button, choose Re-interview Node and wait until it completes
After interviewing has completed, under the node you will find “Configuration Vx” (where x is some number depending on the device)
Find the settings for parameter 101, the ID for those parameters will most likely start with [node ID]-112-0-101-X where X is each of the individual parameters for reports.
Check if each value is set to Enabled that you want to have reported
Ensure that parameter 111 has been set correctly
Let us know what you find.
pascalspits
(Pascal Standaert)
February 22, 2022, 2:07pm
6
You see something wrong ? I don’t …
Configuration v1
[17-112-0-3] Selective Reporting
[0] Disable (Default)
Report only when the defined threshold is exceeded
[17-112-0-4] Power Change Threshold (Whole HEM)
50
W
Threshold change in power consumption to induce an automatic report
[17-112-0-5] Power Change Threshold (Clamp 1)
50
W
[17-112-0-6] Power Change Threshold (Clamp 2)
50
W
[17-112-0-7] Power Change Threshold (Clamp 3)
50
W
[17-112-0-8] Power Percentage Threshold (Whole HEM)
10
Threshold change in power consumption (on a percentage basis) to induce an automatic report (Default: 10)
[17-112-0-9] Power Percentage Threshold (Clamp 1)
10
[17-112-0-10] Power Percentage Threshold (Clamp 2)
10
[17-112-0-11] Power Percentage Threshold (Clamp 3)
10
[17-112-0-13] CRC-16 Encapsulation
[17-112-0-101-1] Automatic Report: Group 1 - kWh (Whole HEM)
[1] Enable
[17-112-0-101-2] Automatic Report: Group 1 - Power (Whole HEM)
[1] Enable
[17-112-0-101-4] Automatic Report: Group 1 - Voltage (Whole HEM)
[1] Enable
[17-112-0-101-8] Automatic Report: Group 1 - Current (Whole HEM)
[1] Enable
[17-112-0-101-256] Automatic Report: Group 1 - Power (Clamp 1)
[1] Enable
[17-112-0-101-512] Automatic Report: Group 1 - Power (Clamp 2)
[1] Enable
[17-112-0-101-1024] Automatic Report: Group 1 - Power (Clamp 3)
[1] Enable
[17-112-0-101-2048] Automatic Report: Group 1 - kWh (Clamp 1)
[1] Enable
[17-112-0-101-4096] Automatic Report: Group 1 - kWh (Clamp 2)
[1] Enable
[17-112-0-101-8192] Automatic Report: Group 1 - kWh (Clamp 3)
[1] Enable
[17-112-0-101-65536] Automatic Report: Group 1 - Voltage (Clamp 1)
[1] Enable
[17-112-0-101-131072] Automatic Report: Group 1 - Voltage (Clamp 2)
[1] Enable
[17-112-0-101-262144] Automatic Report: Group 1 - Voltage (Clamp 3)
[1] Enable
[17-112-0-101-524288] Automatic Report: Group 1 - Current (Clamp 1)
[1] Enable
[17-112-0-101-1048576] Automatic Report: Group 1 - Current (Clamp 2)
[1] Enable
[17-112-0-101-2097152] Automatic Report: Group 1 - Current (Clamp 3)
[1] Enable
[17-112-0-102-1] Automatic Report: Group 2 - kWh (Whole HEM)
[17-112-0-102-2] Automatic Report: Group 2 - Power (Whole HEM)
[17-112-0-102-4] Automatic Report: Group 2 - Voltage (Whole HEM)
[17-112-0-102-8] Automatic Report: Group 2 - Current (Whole HEM)
[17-112-0-102-256] Automatic Report: Group 2 - Power (Clamp 1)
[17-112-0-102-512] Automatic Report: Group 2 - Power (Clamp 2)
[17-112-0-102-1024] Automatic Report: Group 2 - Power (Clamp 3)
[17-112-0-102-2048] Automatic Report: Group 2 - kWh (Clamp 1)
[17-112-0-102-4096] Automatic Report: Group 2 - kWh (Clamp 2)
[17-112-0-102-8192] Automatic Report: Group 2 - kWh (Clamp 3)
[17-112-0-102-65536] Automatic Report: Group 2 - Voltage (Clamp 1)
[17-112-0-102-131072] Automatic Report: Group 2 - Voltage (Clamp 2)
[17-112-0-102-262144] Automatic Report: Group 2 - Voltage (Clamp 3)
[17-112-0-102-524288] Automatic Report: Group 2 - Current (Clamp 1)
[17-112-0-102-1048576] Automatic Report: Group 2 - Current (Clamp 2)
[17-112-0-102-2097152] Automatic Report: Group 2 - Current (Clamp 3)
[17-112-0-103-1] Automatic Report: Group 3 - kWh (Whole HEM)
[17-112-0-103-2] Automatic Report: Group 3 - Power (Whole HEM)
[17-112-0-103-4] Automatic Report: Group 3 - Voltage (Whole HEM)
[17-112-0-103-8] Automatic Report: Group 3 - Current (Whole HEM)
[17-112-0-103-256] Automatic Report: Group 3 - Power (Clamp 1)
[17-112-0-103-512] Automatic Report: Group 3 - Power (Clamp 2)
[17-112-0-103-1024] Automatic Report: Group 3 - Power (Clamp 3)
[17-112-0-103-2048] Automatic Report: Group 3 - kWh (Clamp 1)
[17-112-0-103-4096] Automatic Report: Group 3 - kWh (Clamp 2)
[17-112-0-103-8192] Automatic Report: Group 3 - kWh (Clamp 3)
[17-112-0-103-65536] Automatic Report: Group 3 - Voltage (Clamp 1)
[17-112-0-103-131072] Automatic Report: Group 3 - Voltage (Clamp 2)
[17-112-0-103-262144] Automatic Report: Group 3 - Voltage (Clamp 3)
[17-112-0-103-524288] Automatic Report: Group 3 - Current (Clamp 1)
[17-112-0-103-1048576] Automatic Report: Group 3 - Current (Clamp 2)
[17-112-0-103-2097152] Automatic Report: Group 3 - Current (Clamp 3)
[17-112-0-111] Automatic Reporting Interval: Group 1
5
seconds
(Default: 600)
[17-112-0-112] Automatic Reporting Interval: Group 2
120
seconds
(Default: 600)
[17-112-0-113] Automatic Reporting Interval: Group 3
120
seconds
(Default: 600)
[17-112-0-200] Partner ID
[0] Aeotec (Default)
[17-112-0-252] Lock Configuration
[17-112-0-2] Energy Detection Mode
[17-112-0-255] Reset to Factory Default Setting
Custom Configuration
Parameter
1
Size
1
Value
0
RickKramer
February 22, 2022, 7:01pm
7
Aside from the very low frequency I see nothing wrong with this. Last thing I can think of is that Group 1 doesn’t contain your Controller (node 1), could you check that under the Groups for this node?
RickKramer
February 28, 2022, 9:16pm
9
This is what I would have expected. Get that fixed and it should start working
pascalspits
(Pascal Standaert)
February 28, 2022, 10:20pm
10
thanks a million, it’s working !
Just chiming in to say this solved it for me too. Thank you
Un4Seen
(Un4Seen)
January 13, 2024, 6:19pm
12
I have the same problem. There is nothing on the groups page for the Home Energy Meter node in the Z-Wave JS. how did you guys get it to be added to some group and have a lifeline to the controller?
Un4Seen
(Un4Seen)
January 13, 2024, 6:21pm
13
Found it… there’s an “Add” button on the groups page in Z-wave JS
Thank you for this thread, really helped me.
