I’m using a pi3 with the Aeotec stick. I have also bought a zooz stick to try because of this problem.
The Aeotec stick should be found with ls /dev/serial/by-id/ I would use that value in your configuration.
Ok. I believe i did that although the logs inducate its still trying to bind on AMA. I will regroup when I got home tonight and make sure I have the right path in the configuration.yaml. Thanks
Use the integrations menu per my previous post, remove your config from configuration.yaml
Thank you for the suggestion. I’ll try it tonight when I get home.
Thanks for everyone’s help. I successfully added the zstick with the config menu by taking out the entries in the config file and using the gui config.
im trying to start my network and this is what i get
2020-03-05 20:19:39.704 Always, OpenZwave Version 1.4.3462 Starting Up
2020-03-05 20:19:46.712 Info, Setting Up Provided Network Key for Secure Communications
2020-03-05 20:19:46.713 Info, mgr, Added driver for controller /dev/ttyAMA0
2020-03-05 20:19:46.713 Info, Opening controller /dev/ttyAMA0
2020-03-05 20:19:46.714 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2020-03-05 20:19:46.714 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2020-03-05 20:19:46.714 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-03-05 20:19:46.714 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-03-05 20:19:46.715 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-03-05 20:19:46.715 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-03-05 20:19:46.715 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-03-05 20:19:46.716 Detail,
2020-03-05 20:19:46.716 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-03-05 20:19:46.716 Detail, contrlr, Notification: DriverFailed
This is very likely not the correct tty device.
