Thanks, mate.
Followed all your steps. Below is what I have on terminal and keeps on updating regularly.
rahul@RahulThakkar-PC:~/Documents/HA$ sudo docker-compose up -d
Creating ha_web_1 ... done
rahul@RahulThakkar-PC:~/Documents/HA$ sudo docker logs -f --tail 0 ha_web_1
2018-03-03 16:03:16 INFO (MainThread) [homeassistant.core] Bus:Handling <Event zwave.node_event[L]: entity_id=zwave.aeotec_zw100_multisensor_6_2, node_id=6, basic_level=255>
2018-03-03 16:03:17 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=zwave.aeotec_zw100_multisensor_6_2, old_state=<state zwave.aeotec_zw100_multisensor_6_2=initializing; node_id=6, node_name=Aeotec ZW100 MultiSensor 6, manufacturer_name=Aeotec, product_name=ZW100 MultiSensor 6, old_entity_id=zwave.aeotec_zw100_multisensor_6_6, new_entity_id=zwave.aeotec_zw100_multisensor_6, query_stage=CacheLoad, is_awake=True, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=True, capabilities={'routing', 'listening', 'beaming'}, sentCnt=0, sentFailed=0, retries=0, receivedCnt=0, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:02:59:463 , receivedTS=2018-03-03 16:02:59:463 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, battery_level=100, wake_up_interval=3600, friendly_name=Aeotec ZW100 MultiSensor 6 @ 2018-03-03T16:02:59.910654+11:00>, new_state=<state zwave.aeotec_zw100_multisensor_6_2=initializing; node_id=6, node_name=Aeotec ZW100 MultiSensor 6, manufacturer_name=Aeotec, product_name=ZW100 MultiSensor 6, old_entity_id=zwave.aeotec_zw100_multisensor_6_6, new_entity_id=zwave.aeotec_zw100_multisensor_6, query_stage=CacheLoad, is_awake=True, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=True, capabilities={'routing', 'listening', 'beaming'}, sentCnt=1, sentFailed=0, retries=0, receivedCnt=2, receivedDups=0, receivedUnsolicited=2, sentTS=2018-03-03 16:03:13:863 , receivedTS=2018-03-03 16:03:17:213 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, battery_level=100, wake_up_interval=3600, friendly_name=Aeotec ZW100 MultiSensor 6 @ 2018-03-03T16:02:59.910654+11:00>>
2018-03-03 16:03:17 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.alarm_type, old_state=<state sensor.alarm_type=0; node_id=6, value_index=0, value_instance=1, value_id=72057594144636929, old_entity_id=sensor.aeotec_zw100_multisensor_6_alarm_type_6_0, new_entity_id=sensor.aeotec_zw100_multisensor_6_alarm_type, unit_of_measurement=, friendly_name=Aeotec ZW100 MultiSensor 6 Alarm Type @ 2018-03-03T16:02:59.927602+11:00>, new_state=<state sensor.alarm_type=0; node_id=6, value_index=0, value_instance=1, value_id=72057594144636929, old_entity_id=sensor.aeotec_zw100_multisensor_6_alarm_type_6_0, new_entity_id=sensor.aeotec_zw100_multisensor_6_alarm_type, unit_of_measurement=, friendly_name=Aeotec ZW100 MultiSensor 6 Alarm Type @ 2018-03-03T16:03:17.324485+11:00>>
2018-03-03 16:03:17 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.alarm_level, old_state=<state sensor.alarm_level=0; node_id=6, value_index=1, value_instance=1, value_id=72057594144636945, old_entity_id=sensor.aeotec_zw100_multisensor_6_alarm_level_6_1, new_entity_id=sensor.aeotec_zw100_multisensor_6_alarm_level, unit_of_measurement=, friendly_name=Aeotec ZW100 MultiSensor 6 Alarm Level @ 2018-03-03T16:02:59.930169+11:00>, new_state=<state sensor.alarm_level=0; node_id=6, value_index=1, value_instance=1, value_id=72057594144636945, old_entity_id=sensor.aeotec_zw100_multisensor_6_alarm_level_6_1, new_entity_id=sensor.aeotec_zw100_multisensor_6_alarm_level, unit_of_measurement=, friendly_name=Aeotec ZW100 MultiSensor 6 Alarm Level @ 2018-03-03T16:03:17.326192+11:00>>
2018-03-03 16:03:18 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=zwave.aeotec_zw100_multisensor_6_2, old_state=<state zwave.aeotec_zw100_multisensor_6_2=initializing; node_id=6, node_name=Aeotec ZW100 MultiSensor 6, manufacturer_name=Aeotec, product_name=ZW100 MultiSensor 6, old_entity_id=zwave.aeotec_zw100_multisensor_6_6, new_entity_id=zwave.aeotec_zw100_multisensor_6, query_stage=CacheLoad, is_awake=True, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=True, capabilities={'routing', 'listening', 'beaming'}, sentCnt=1, sentFailed=0, retries=0, receivedCnt=2, receivedDups=0, receivedUnsolicited=2, sentTS=2018-03-03 16:03:13:863 , receivedTS=2018-03-03 16:03:17:213 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, battery_level=100, wake_up_interval=3600, friendly_name=Aeotec ZW100 MultiSensor 6 @ 2018-03-03T16:02:59.910654+11:00>, new_state=<state zwave.aeotec_zw100_multisensor_6_2=initializing; node_id=6, node_name=Aeotec ZW100 MultiSensor 6, manufacturer_name=Aeotec, product_name=ZW100 MultiSensor 6, old_entity_id=zwave.aeotec_zw100_multisensor_6_6, new_entity_id=zwave.aeotec_zw100_multisensor_6, query_stage=CacheLoad, is_awake=True, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=True, capabilities={'routing', 'listening', 'beaming'}, sentCnt=1, sentFailed=1, retries=0, receivedCnt=2, receivedDups=0, receivedUnsolicited=2, sentTS=2018-03-03 16:03:13:863 , receivedTS=2018-03-03 16:03:17:213 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, battery_level=100, wake_up_interval=3600, friendly_name=Aeotec ZW100 MultiSensor 6 @ 2018-03-03T16:02:59.910654+11:00>>
2018-03-03 16:03:22 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=zwave.__2, old_state=<state zwave.__2=initializing; node_id=7, node_name= , manufacturer_name=, product_name=, old_entity_id=zwave.__7, new_entity_id=zwave._, query_stage=Probe, is_awake=True, is_ready=False, is_failed=False, is_info_received=False, max_baud_rate=40000, is_zwave_plus=False, capabilities={'routing', 'listening', 'beaming'}, sentCnt=0, sentFailed=0, retries=0, receivedCnt=0, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:02:59:463 , receivedTS=2018-03-03 16:02:59:463 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, friendly_name= @ 2018-03-03T16:03:00.048882+11:00>, new_state=<state zwave.__2=initializing; node_id=7, node_name= , manufacturer_name=, product_name=, old_entity_id=zwave.__7, new_entity_id=zwave._, query_stage=Probe, is_awake=True, is_ready=False, is_failed=False, is_info_received=False, max_baud_rate=40000, is_zwave_plus=False, capabilities={'routing', 'listening', 'beaming'}, sentCnt=1, sentFailed=1, retries=0, receivedCnt=0, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:03:17:988 , receivedTS=2018-03-03 16:02:59:463 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, friendly_name= @ 2018-03-03T16:03:00.048882+11:00>>
2018-03-03 16:03:22 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=zwave.aeotec_zw090_zstick_gen5_au, old_state=<state zwave.aeotec_zw090_zstick_gen5_au=initializing; node_id=1, node_name=Aeotec ZW090 Z-Stick Gen5 AU, manufacturer_name=Aeotec, product_name=ZW090 Z-Stick Gen5 AU, old_entity_id=zwave.aeotec_zw090_zstick_gen5_au_1, new_entity_id=zwave.aeotec_zw090_zstick_gen5_au, query_stage=Neighbors, is_awake=True, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=False, capabilities={'primaryController', 'listening', 'beaming'}, sentCnt=0, sentFailed=0, retries=0, receivedCnt=0, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:02:59:461 , receivedTS=2018-03-03 16:02:59:461 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, friendly_name=Aeotec ZW090 Z-Stick Gen5 AU @ 2018-03-03T16:02:59.576850+11:00>, new_state=<state zwave.aeotec_zw090_zstick_gen5_au=ready; node_id=1, node_name=Aeotec ZW090 Z-Stick Gen5 AU, manufacturer_name=Aeotec, product_name=ZW090 Z-Stick Gen5 AU, old_entity_id=zwave.aeotec_zw090_zstick_gen5_au_1, new_entity_id=zwave.aeotec_zw090_zstick_gen5_au, query_stage=Complete, is_awake=True, is_ready=True, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=False, capabilities={'primaryController', 'listening', 'beaming'}, neighbors={2, 3, 5}, sentCnt=1, sentFailed=0, retries=0, receivedCnt=0, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:02:59:952 , receivedTS=2018-03-03 16:02:59:461 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, friendly_name=Aeotec ZW090 Z-Stick Gen5 AU @ 2018-03-03T16:03:22.264425+11:00>>
2018-03-03 16:03:26 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=zwave.aeotec_zw100_multisensor_6, old_state=<state zwave.aeotec_zw100_multisensor_6=initializing; node_id=2, node_name=Aeotec ZW100 MultiSensor 6, manufacturer_name=Aeotec, product_name=ZW100 MultiSensor 6, old_entity_id=zwave.aeotec_zw100_multisensor_6_2, new_entity_id=zwave.aeotec_zw100_multisensor_6, query_stage=CacheLoad, is_awake=True, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=True, capabilities={'routing', 'listening', 'beaming'}, sentCnt=1, sentFailed=1, retries=0, receivedCnt=0, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:02:59:958 , receivedTS=2018-03-03 16:02:59:461 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, battery_level=100, wake_up_interval=3600, friendly_name=Aeotec ZW100 MultiSensor 6 @ 2018-03-03T16:02:59.583303+11:00>, new_state=<state zwave.aeotec_zw100_multisensor_6=initializing; node_id=2, node_name=Aeotec ZW100 MultiSensor 6, manufacturer_name=Aeotec, product_name=ZW100 MultiSensor 6, old_entity_id=zwave.aeotec_zw100_multisensor_6_2, new_entity_id=zwave.aeotec_zw100_multisensor_6, query_stage=CacheLoad, is_awake=True, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=True, capabilities={'routing', 'listening', 'beaming'}, sentCnt=2, sentFailed=2, retries=0, receivedCnt=0, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:03:22:163 , receivedTS=2018-03-03 16:02:59:461 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, battery_level=100, wake_up_interval=3600, friendly_name=Aeotec ZW100 MultiSensor 6 @ 2018-03-03T16:02:59.583303+11:00>>
2018-03-03 16:03:30 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_dawn=2018-03-03T19:39:17+00:00, next_dusk=2018-03-03T09:23:34+00:00, next_midnight=2018-03-03T14:30:40+00:00, next_noon=2018-03-04T02:30:40+00:00, next_rising=2018-03-03T20:05:58+00:00, next_setting=2018-03-03T08:56:50+00:00, elevation=43.64, azimuth=302.34, friendly_name=Sun @ 2018-03-03T16:02:53.621728+11:00>, new_state=<state sun.sun=above_horizon; next_dawn=2018-03-03T19:39:17+00:00, next_dusk=2018-03-03T09:23:34+00:00, next_midnight=2018-03-03T14:30:40+00:00, next_noon=2018-03-04T02:30:40+00:00, next_rising=2018-03-03T20:05:58+00:00, next_setting=2018-03-03T08:56:50+00:00, elevation=43.54, azimuth=302.18, friendly_name=Sun @ 2018-03-03T16:02:53.621728+11:00>>
2018-03-03 16:03:30 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=zwave._, old_state=<state zwave._=initializing; node_id=4, node_name= , manufacturer_name=, product_name=, old_entity_id=zwave.__4, new_entity_id=zwave._, query_stage=Probe, is_awake=True, is_ready=False, is_failed=False, is_info_received=False, max_baud_rate=40000, is_zwave_plus=False, capabilities={'routing', 'listening', 'beaming'}, sentCnt=1, sentFailed=1, retries=0, receivedCnt=0, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:03:08:464 , receivedTS=2018-03-03 16:02:59:463 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, friendly_name= @ 2018-03-03T16:02:59.864016+11:00>, new_state=<state zwave._=initializing; node_id=4, node_name= , manufacturer_name=, product_name=, old_entity_id=zwave.__4, new_entity_id=zwave._, query_stage=Probe, is_awake=True, is_ready=False, is_failed=False, is_info_received=False, max_baud_rate=40000, is_zwave_plus=False, capabilities={'routing', 'listening', 'beaming'}, sentCnt=2, sentFailed=2, retries=0, receivedCnt=0, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:03:26:290 , receivedTS=2018-03-03 16:02:59:463 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, friendly_name= @ 2018-03-03T16:02:59.864016+11:00>>
2018-03-03 16:03:34 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=zwave.aeotec_zw100_multisensor_6_2, old_state=<state zwave.aeotec_zw100_multisensor_6_2=initializing; node_id=6, node_name=Aeotec ZW100 MultiSensor 6, manufacturer_name=Aeotec, product_name=ZW100 MultiSensor 6, old_entity_id=zwave.aeotec_zw100_multisensor_6_6, new_entity_id=zwave.aeotec_zw100_multisensor_6, query_stage=CacheLoad, is_awake=True, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=True, capabilities={'routing', 'listening', 'beaming'}, sentCnt=1, sentFailed=1, retries=0, receivedCnt=2, receivedDups=0, receivedUnsolicited=2, sentTS=2018-03-03 16:03:13:863 , receivedTS=2018-03-03 16:03:17:213 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, battery_level=100, wake_up_interval=3600, friendly_name=Aeotec ZW100 MultiSensor 6 @ 2018-03-03T16:02:59.910654+11:00>, new_state=<state zwave.aeotec_zw100_multisensor_6_2=initializing; node_id=6, node_name=Aeotec ZW100 MultiSensor 6, manufacturer_name=Aeotec, product_name=ZW100 MultiSensor 6, old_entity_id=zwave.aeotec_zw100_multisensor_6_6, new_entity_id=zwave.aeotec_zw100_multisensor_6, query_stage=CacheLoad, is_awake=True, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=True, capabilities={'routing', 'listening', 'beaming'}, sentCnt=2, sentFailed=2, retries=0, receivedCnt=2, receivedDups=0, receivedUnsolicited=2, sentTS=2018-03-03 16:03:30:392 , receivedTS=2018-03-03 16:03:17:213 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, battery_level=100, wake_up_interval=3600, friendly_name=Aeotec ZW100 MultiSensor 6 @ 2018-03-03T16:02:59.910654+11:00>>
2018-03-03 16:03:38 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=zwave.__2, old_state=<state zwave.__2=initializing; node_id=7, node_name= , manufacturer_name=, product_name=, old_entity_id=zwave.__7, new_entity_id=zwave._, query_stage=Probe, is_awake=True, is_ready=False, is_failed=False, is_info_received=False, max_baud_rate=40000, is_zwave_plus=False, capabilities={'routing', 'listening', 'beaming'}, sentCnt=1, sentFailed=1, retries=0, receivedCnt=0, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:03:17:988 , receivedTS=2018-03-03 16:02:59:463 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, friendly_name= @ 2018-03-03T16:03:00.048882+11:00>, new_state=<state zwave.__2=initializing; node_id=7, node_name= , manufacturer_name=, product_name=, old_entity_id=zwave.__7, new_entity_id=zwave._, query_stage=Probe, is_awake=True, is_ready=False, is_failed=False, is_info_received=False, max_baud_rate=40000, is_zwave_plus=False, capabilities={'routing', 'listening', 'beaming'}, sentCnt=2, sentFailed=2, retries=0, receivedCnt=0, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:03:34:519 , receivedTS=2018-03-03 16:02:59:463 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, friendly_name= @ 2018-03-03T16:03:00.048882+11:00>>
2018-03-03 16:03:42 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=zwave.aeotec_zw100_multisensor_6, old_state=<state zwave.aeotec_zw100_multisensor_6=initializing; node_id=2, node_name=Aeotec ZW100 MultiSensor 6, manufacturer_name=Aeotec, product_name=ZW100 MultiSensor 6, old_entity_id=zwave.aeotec_zw100_multisensor_6_2, new_entity_id=zwave.aeotec_zw100_multisensor_6, query_stage=CacheLoad, is_awake=True, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=True, capabilities={'routing', 'listening', 'beaming'}, sentCnt=2, sentFailed=2, retries=0, receivedCnt=0, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:03:22:163 , receivedTS=2018-03-03 16:02:59:461 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, battery_level=100, wake_up_interval=3600, friendly_name=Aeotec ZW100 MultiSensor 6 @ 2018-03-03T16:02:59.583303+11:00>, new_state=<state zwave.aeotec_zw100_multisensor_6=dead; node_id=2, node_name=Aeotec ZW100 MultiSensor 6, manufacturer_name=Aeotec, product_name=ZW100 MultiSensor 6, old_entity_id=zwave.aeotec_zw100_multisensor_6_2, new_entity_id=zwave.aeotec_zw100_multisensor_6, query_stage=CacheLoad, is_awake=True, is_ready=False, is_failed=True, is_info_received=True, max_baud_rate=40000, is_zwave_plus=True, capabilities={'routing', 'listening', 'beaming'}, sentCnt=3, sentFailed=3, retries=0, receivedCnt=0, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:03:38:602 , receivedTS=2018-03-03 16:02:59:461 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, battery_level=100, wake_up_interval=3600, friendly_name=Aeotec ZW100 MultiSensor 6 @ 2018-03-03T16:03:42.848257+11:00>>
2018-03-03 16:03:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=zwave._, old_state=<state zwave._=initializing; node_id=4, node_name= , manufacturer_name=, product_name=, old_entity_id=zwave.__4, new_entity_id=zwave._, query_stage=Probe, is_awake=True, is_ready=False, is_failed=False, is_info_received=False, max_baud_rate=40000, is_zwave_plus=False, capabilities={'routing', 'listening', 'beaming'}, sentCnt=2, sentFailed=2, retries=0, receivedCnt=0, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:03:26:290 , receivedTS=2018-03-03 16:02:59:463 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, friendly_name= @ 2018-03-03T16:02:59.864016+11:00>, new_state=<state zwave._=dead; node_id=4, node_name= , manufacturer_name=, product_name=, old_entity_id=zwave.__4, new_entity_id=zwave._, query_stage=Probe, is_awake=True, is_ready=False, is_failed=True, is_info_received=False, max_baud_rate=40000, is_zwave_plus=False, capabilities={'routing', 'listening', 'beaming'}, sentCnt=3, sentFailed=3, retries=0, receivedCnt=0, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:03:42:748 , receivedTS=2018-03-03 16:02:59:463 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, friendly_name= @ 2018-03-03T16:03:47.022514+11:00>>
2018-03-03 16:03:48 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=zwave.vision_zm1601_battery_operated_siren, old_state=<state zwave.vision_zm1601_battery_operated_siren=initializing; node_id=5, node_name=Vision ZM1601 Battery Operated Siren, manufacturer_name=Vision, product_name=ZM1601 Battery Operated Siren, old_entity_id=zwave.vision_zm1601_battery_operated_siren_5, new_entity_id=zwave.vision_zm1601_battery_operated_siren, query_stage=CacheLoad, is_awake=True, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=False, capabilities={'routing', 'frequent', 'beaming'}, sentCnt=1, sentFailed=0, retries=0, receivedCnt=0, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:03:12:577 , receivedTS=2018-03-03 16:02:59:463 , lastRequestRTT=1284, averageRequestRTT=1284, lastResponseRTT=0, averageResponseRTT=0, battery_level=100, friendly_name=Vision ZM1601 Battery Operated Siren @ 2018-03-03T16:02:59.867188+11:00>, new_state=<state zwave.vision_zm1601_battery_operated_siren=initializing; node_id=5, node_name=Vision ZM1601 Battery Operated Siren, manufacturer_name=Vision, product_name=ZM1601 Battery Operated Siren, old_entity_id=zwave.vision_zm1601_battery_operated_siren_5, new_entity_id=zwave.vision_zm1601_battery_operated_siren, query_stage=Dynamic, is_awake=True, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=False, capabilities={'routing', 'frequent', 'beaming'}, neighbors={1, 3}, sentCnt=3, sentFailed=0, retries=0, receivedCnt=1, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:03:46:922 , receivedTS=2018-03-03 16:03:48:567 , lastRequestRTT=1226, averageRequestRTT=1255, lastResponseRTT=1646, averageResponseRTT=1646, battery_level=100, friendly_name=Vision ZM1601 Battery Operated Siren @ 2018-03-03T16:02:59.867188+11:00>>
2018-03-03 16:03:48 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=zwave.vision_zm1601_battery_operated_siren, old_state=<state zwave.vision_zm1601_battery_operated_siren=initializing; node_id=5, node_name=Vision ZM1601 Battery Operated Siren, manufacturer_name=Vision, product_name=ZM1601 Battery Operated Siren, old_entity_id=zwave.vision_zm1601_battery_operated_siren_5, new_entity_id=zwave.vision_zm1601_battery_operated_siren, query_stage=Dynamic, is_awake=True, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=False, capabilities={'routing', 'frequent', 'beaming'}, neighbors={1, 3}, sentCnt=3, sentFailed=0, retries=0, receivedCnt=1, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:03:46:922 , receivedTS=2018-03-03 16:03:48:567 , lastRequestRTT=1226, averageRequestRTT=1255, lastResponseRTT=1646, averageResponseRTT=1646, battery_level=100, friendly_name=Vision ZM1601 Battery Operated Siren @ 2018-03-03T16:02:59.867188+11:00>, new_state=<state zwave.vision_zm1601_battery_operated_siren=initializing; node_id=5, node_name=Vision ZM1601 Battery Operated Siren, manufacturer_name=Vision, product_name=ZM1601 Battery Operated Siren, old_entity_id=zwave.vision_zm1601_battery_operated_siren_5, new_entity_id=zwave.vision_zm1601_battery_operated_siren, query_stage=Dynamic, is_awake=True, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=False, capabilities={'routing', 'frequent', 'beaming'}, neighbors={1, 3}, sentCnt=4, sentFailed=0, retries=0, receivedCnt=2, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:03:48:571 , receivedTS=2018-03-03 16:03:48:770 , lastRequestRTT=25, averageRequestRTT=640, lastResponseRTT=198, averageResponseRTT=922, battery_level=100, friendly_name=Vision ZM1601 Battery Operated Siren @ 2018-03-03T16:02:59.867188+11:00>>
2018-03-03 16:03:53 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=zwave.aeotec_zw100_multisensor_6_2, old_state=<state zwave.aeotec_zw100_multisensor_6_2=initializing; node_id=6, node_name=Aeotec ZW100 MultiSensor 6, manufacturer_name=Aeotec, product_name=ZW100 MultiSensor 6, old_entity_id=zwave.aeotec_zw100_multisensor_6_6, new_entity_id=zwave.aeotec_zw100_multisensor_6, query_stage=CacheLoad, is_awake=True, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=True, capabilities={'routing', 'listening', 'beaming'}, sentCnt=2, sentFailed=2, retries=0, receivedCnt=2, receivedDups=0, receivedUnsolicited=2, sentTS=2018-03-03 16:03:30:392 , receivedTS=2018-03-03 16:03:17:213 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, battery_level=100, wake_up_interval=3600, friendly_name=Aeotec ZW100 MultiSensor 6 @ 2018-03-03T16:02:59.910654+11:00>, new_state=<state zwave.aeotec_zw100_multisensor_6_2=dead; node_id=6, node_name=Aeotec ZW100 MultiSensor 6, manufacturer_name=Aeotec, product_name=ZW100 MultiSensor 6, old_entity_id=zwave.aeotec_zw100_multisensor_6_6, new_entity_id=zwave.aeotec_zw100_multisensor_6, query_stage=CacheLoad, is_awake=True, is_ready=False, is_failed=True, is_info_received=True, max_baud_rate=40000, is_zwave_plus=True, capabilities={'routing', 'listening', 'beaming'}, sentCnt=3, sentFailed=3, retries=0, receivedCnt=2, receivedDups=0, receivedUnsolicited=2, sentTS=2018-03-03 16:03:48:774 , receivedTS=2018-03-03 16:03:17:213 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, battery_level=100, wake_up_interval=3600, friendly_name=Aeotec ZW100 MultiSensor 6 @ 2018-03-03T16:03:53.051772+11:00>>
2018-03-03 16:03:57 INFO (Dummy-2) [homeassistant.components.zwave] Zwave network is ready for use. All awake nodes have been queried. Sleeping nodes will be queried when they awake.
2018-03-03 16:03:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event zwave.network_ready[L]>
2018-03-03 16:03:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=zwave.__2, old_state=<state zwave.__2=initializing; node_id=7, node_name= , manufacturer_name=, product_name=, old_entity_id=zwave.__7, new_entity_id=zwave._, query_stage=Probe, is_awake=True, is_ready=False, is_failed=False, is_info_received=False, max_baud_rate=40000, is_zwave_plus=False, capabilities={'routing', 'listening', 'beaming'}, sentCnt=2, sentFailed=2, retries=0, receivedCnt=0, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:03:34:519 , receivedTS=2018-03-03 16:02:59:463 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, friendly_name= @ 2018-03-03T16:03:00.048882+11:00>, new_state=<state zwave.__2=dead; node_id=7, node_name= , manufacturer_name=, product_name=, old_entity_id=zwave.__7, new_entity_id=zwave._, query_stage=Probe, is_awake=True, is_ready=False, is_failed=True, is_info_received=False, max_baud_rate=40000, is_zwave_plus=False, capabilities={'routing', 'listening', 'beaming'}, sentCnt=3, sentFailed=3, retries=0, receivedCnt=0, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:03:52:951 , receivedTS=2018-03-03 16:02:59:463 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, friendly_name= @ 2018-03-03T16:03:57.196157+11:00>>
2018-03-03 16:03:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=zwave.vision_zm1601_battery_operated_siren, old_state=<state zwave.vision_zm1601_battery_operated_siren=initializing; node_id=5, node_name=Vision ZM1601 Battery Operated Siren, manufacturer_name=Vision, product_name=ZM1601 Battery Operated Siren, old_entity_id=zwave.vision_zm1601_battery_operated_siren_5, new_entity_id=zwave.vision_zm1601_battery_operated_siren, query_stage=Dynamic, is_awake=True, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=False, capabilities={'routing', 'frequent', 'beaming'}, neighbors={1, 3}, sentCnt=4, sentFailed=0, retries=0, receivedCnt=2, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:03:48:571 , receivedTS=2018-03-03 16:03:48:770 , lastRequestRTT=25, averageRequestRTT=640, lastResponseRTT=198, averageResponseRTT=922, battery_level=100, friendly_name=Vision ZM1601 Battery Operated Siren @ 2018-03-03T16:02:59.867188+11:00>, new_state=<state zwave.vision_zm1601_battery_operated_siren=ready; node_id=5, node_name=Vision ZM1601 Battery Operated Siren, manufacturer_name=Vision, product_name=ZM1601 Battery Operated Siren, old_entity_id=zwave.vision_zm1601_battery_operated_siren_5, new_entity_id=zwave.vision_zm1601_battery_operated_siren, query_stage=Complete, is_awake=True, is_ready=True, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=False, capabilities={'routing', 'frequent', 'beaming'}, neighbors={1, 3}, sentCnt=4, sentFailed=0, retries=0, receivedCnt=2, receivedDups=0, receivedUnsolicited=0, sentTS=2018-03-03 16:03:48:571 , receivedTS=2018-03-03 16:03:48:770 , lastRequestRTT=25, averageRequestRTT=640, lastResponseRTT=198, averageResponseRTT=922, battery_level=100, friendly_name=Vision ZM1601 Battery Operated Siren @ 2018-03-03T16:03:57.202150+11:00>>
2018-03-03 16:03:57 INFO (MainThread) [homeassistant.components.zwave] Z-Wave ready after 58 seconds
2018-03-03 16:03:57 INFO (SyncWorker_14) [homeassistant.components.zwave] Z-Wave polling interval set to 60000 ms
