Are you able to use cover.open or cover.close? I only get an error when I call the service. set_position is working fine.
But I’m also using the new integration which is currently available in the new HA beta.
Has anyone encountered any issued with Aeotec Multisensor 6’s? I’m banging my head against the wall with them. I have them all in Zwave2MQTT properly and properly in HA and the contacts are customized to motions. Everything was working perfectly and now the motions are not triggering events in HA for some of the units. The other sensors (temp, lux, etc) in those units are continuing to to function. Any suggestions or experience appreciated.
I had the same problem the motion was sometimes reported sometimes not. Because i have also Vera controller at home i moved the sensors to vera and they are working fine with vera integration in home assistant.
Ok, I have a Vera controller also and I have also found it works. I was hoping to migrate away from Vera as the legacy platform is becoming deprecated as they move to EZ-LO. Also, it sends the sensors as 6 devices. The Z-wave frustration is unending.
Parameter 5: Which command would be sent when the motion sensor triggered.
To set which command would be sent when the motion sensor is triggered.
Size: 1 Byte, Default Value: 1
Setting
Description
1
Send Basic Set
2
Send Sensor Binary Report
Honestly from the devices that i use vera had much better support so i was not able to migrate completely.
I have Fibaro, Aeotec and Qubino devices and only fibaro is working better on zvave2mqtt, aeotec is ok but sometimes it dos not sync the state, qubino dimer does not work at all when you manually chage the state of the switch, and qubino relay is responding very slow, aeotec dimmer also does not report state sometimes so i use zeave l2mqtt for fibaro modules and vera for the rest.
Yup, for me it was an easy transition, but that’s also because I’ve been reading about it since the beginning. If you’re comfortable around HA, then it should be easy.
For example, I came from OZW, and I used to think my zwave bulbs dimmed/transitioned whenever I would turn it off/on. But after zwaveJS, the bulb responds instantly. So it was actually OZW that was causing the slow response
