I tried with z-wave controller that had not been paired with any devices, and encountered the same problem.
Before first login to home-assistant:
View of home-assistant start screen:
After account creation in Home-Assistant
]And, yet, if I set up the integration, it connects:
Here are the logs for this scenario (without a device paired to the controller):
2021-08-03 16:56:35.566 INFO APP: Listening on port 8091 host 0.0.0.0 protocol HTTP
2021-08-03 16:56:36.310 INFO MQTT: MQTT is disabled
2021-08-03 16:56:36.512 INFO ZWAVE: Connecting to /dev/serial/by-id/usb-0658_0200-if00
2021-08-03 16:57:38.272 INFO ZWAVE: Zwave driver is ready
2021-08-03 16:57:38.277 INFO ZWAVE: Controller status: Driver ready
2021-08-03 16:57:38.300 INFO ZWAVE: Scanning network with homeid: 0xd8e81a8f
2021-08-03 16:57:38.317 INFO ZWAVE: Node 1: interview started
2021-08-03 16:57:38.758 INFO ZWAVE: Node 1: interview stage PROTOCOLINFO completed
2021-08-03 16:57:38.782 INFO ZWAVE: Node 1: interview stage NODEINFO completed
2021-08-03 16:57:38.791 INFO ZWAVE: Node 1: interview stage COMMANDCLASSES completed
2021-08-03 16:57:38.863 INFO ZWAVE: Node 1: interview stage OVERWRITECONFIG completed
2021-08-03 16:57:38.867 INFO ZWAVE: Node 1: interview stage COMPLETE completed
2021-08-03 16:57:38.886 INFO ZWAVE: Node 1 ready: Zooz - ZST10 (S2 USB Stick Controller)
2021-08-03 16:57:38.891 INFO ZWAVE: Controller status: Scan completed
2021-08-03 16:57:38.893 INFO ZWAVE: Network scan complete. Found: 1 nodes
2021-08-03 16:57:38.896 INFO ZWAVE: Node 1: interview COMPLETED, all values are updated
2021-08-03 16:57:38.905 INFO ZWAVE: Node 1 is alive
2021-08-03 16:57:39.360 INFO ZWAVE: Next update scheduled for: Wed Aug 04 2021 00:00:00 GMT+0000 (Coordinated Universal Time)
2021-08-03 17:08:28.257 INFO APP: GET /zwavejs2mqtt 200 107.683 ms - 1475
2021-08-03 17:08:28.441 INFO APP: GET /static/css/app.3ef71e230a7d149d2175.css 200 20.638 ms - 645097
2021-08-03 17:08:28.633 INFO APP: GET /static/js/app.41b94a256197955ca683.js 200 11.565 ms - 1832141
2021-08-03 17:08:31.266 INFO APP: GET /api/auth-enabled 200 19.771 ms - 29
2021-08-03 17:08:31.287 INFO APP: GET /static/favicons/favicon-32x32.png 200 5.806 ms - 1831
2021-08-03 17:08:31.503 INFO APP: GET /static/favicons/site.webmanifest 200 4.423 ms - 409
2021-08-03 17:08:31.604 INFO APP: GET /static/logo.png 200 5.853 ms - 10014
2021-08-03 17:08:31.741 INFO APP: GET /static/favicons/favicon-32x32.png 304 6.324 ms - -
2021-08-03 17:08:31.966 INFO APP: GET /api/settings 200 348.358 ms - 11807
2021-08-03 17:08:32.034 INFO APP: GET /static/fonts/MaterialIcons-Regular.fa3334f.woff2 200 43.622 ms - 82492
2021-08-03 17:08:32.222 INFO APP: GET /api/auth-enabled 304 60.665 ms - -
2021-08-03 17:11:00.269 INFO APP: GET /api/settings 304 133.057 ms - -
2021-08-03 17:11:00.415 INFO APP: GET /api/auth-enabled 304 4.937 ms - -
2021-08-03 17:11:28.191 INFO APP: GET /control-panel 200 9.523 ms - 1475
2021-08-03 17:11:28.354 INFO APP: GET /static/css/app.3ef71e230a7d149d2175.css 304 6.693 ms - -
2021-08-03 17:11:28.362 INFO APP: GET /static/js/app.41b94a256197955ca683.js 304 10.953 ms - -
2021-08-03 17:11:28.776 INFO APP: GET /api/auth-enabled 304 5.096 ms - -
2021-08-03 17:11:28.892 INFO APP: GET /static/favicons/favicon-32x32.png 304 3.877 ms - -
2021-08-03 17:11:28.997 INFO APP: GET /static/favicons/site.webmanifest 304 3.014 ms - -
2021-08-03 17:11:29.115 INFO APP: GET /static/logo.png 304 6.916 ms - -
2021-08-03 17:11:29.129 INFO APP: GET /static/fonts/MaterialIcons-Regular.fa3334f.woff2 304 2.606 ms - -
2021-08-03 17:11:29.265 INFO APP: GET /static/favicons/favicon-32x32.png 304 31.147 ms - -
2021-08-03 17:11:29.291 INFO APP: GET /api/settings 304 131.591 ms - -
2021-08-03 17:11:29.400 INFO APP: GET /api/auth-enabled 304 5.945 ms - -
2021-08-03 17:12:24.958 INFO APP: GET /control-panel 304 7.150 ms - -
2021-08-03 17:12:25.102 INFO APP: GET /static/css/app.3ef71e230a7d149d2175.css 304 2.457 ms - -
2021-08-03 17:12:25.183 INFO APP: GET /static/js/app.41b94a256197955ca683.js 304 2.384 ms - -
2021-08-03 17:12:25.549 INFO APP: GET /api/auth-enabled 304 4.446 ms - -
2021-08-03 17:12:25.641 INFO APP: GET /static/favicons/favicon-32x32.png 304 3.228 ms - -
2021-08-03 17:12:25.828 INFO APP: GET /static/logo.png 304 2.103 ms - -
2021-08-03 17:12:25.925 INFO APP: GET /static/favicons/site.webmanifest 304 2.398 ms - -
2021-08-03 17:12:26.010 INFO APP: GET /static/fonts/MaterialIcons-Regular.fa3334f.woff2 304 8.684 ms - -
2021-08-03 17:12:26.131 INFO APP: GET /api/settings 304 122.860 ms - -
2021-08-03 17:12:26.250 INFO APP: GET /static/favicons/favicon-32x32.png 304 4.204 ms - -
2021-08-03 17:12:26.314 INFO APP: GET /api/auth-enabled 304 5.499 ms - -
2021-08-03 17:12:30.003 INFO APP: GET /control-panel 304 7.548 ms - -
2021-08-03 17:12:30.164 INFO APP: GET /static/css/app.3ef71e230a7d149d2175.css 304 4.968 ms - -
2021-08-03 17:12:30.169 INFO APP: GET /static/js/app.41b94a256197955ca683.js 304 8.353 ms - -
2021-08-03 17:12:30.390 INFO APP: GET /api/auth-enabled 304 4.017 ms - -
2021-08-03 17:12:30.459 INFO APP: GET /static/favicons/favicon-32x32.png 304 2.256 ms - -
2021-08-03 17:12:30.516 INFO APP: GET /static/favicons/site.webmanifest 304 2.162 ms - -
2021-08-03 17:12:30.642 INFO APP: GET /static/logo.png 304 2.228 ms - -
2021-08-03 17:12:30.696 INFO APP: GET /static/favicons/favicon-32x32.png 304 25.505 ms - -
2021-08-03 17:12:30.797 INFO APP: GET /api/settings 304 129.500 ms - -
2021-08-03 17:12:30.909 INFO APP: GET /api/auth-enabled 304 5.298 ms - -
2021-08-03 17:13:12.530 INFO APP: GET /control-panel 304 8.543 ms - -
2021-08-03 17:13:12.808 INFO APP: GET /static/css/app.3ef71e230a7d149d2175.css 304 2.867 ms - -
2021-08-03 17:13:12.843 INFO APP: GET /static/js/app.41b94a256197955ca683.js 304 2.588 ms - -
2021-08-03 17:13:13.346 INFO APP: GET /api/auth-enabled 304 5.390 ms - -
2021-08-03 17:13:13.490 INFO APP: GET /static/favicons/favicon-32x32.png 304 2.521 ms - -
2021-08-03 17:13:13.615 INFO APP: GET /static/favicons/site.webmanifest 304 2.882 ms - -
2021-08-03 17:13:14.013 INFO APP: GET /api/settings 304 190.826 ms - -
2021-08-03 17:13:14.031 INFO APP: GET /static/fonts/MaterialIcons-Regular.fa3334f.woff2 304 6.112 ms - -
2021-08-03 17:13:14.068 INFO APP: GET /static/logo.png 304 2.605 ms - -
2021-08-03 17:13:14.133 INFO APP: GET /api/auth-enabled 304 6.000 ms - -
2021-08-03 17:13:26.601 INFO APP: GET /api/store 200 34.599 ms - 1527
2021-08-03T16:56:36.519Z DRIVER ββββββββ βββ βββ ββββββ βββ βββ ββββββββ βββ ββββββββ
ββββββββ βββ βββ ββββββββ βββ βββ ββββββββ βββ ββββββββ
βββββ βββ ββ βββ ββββββββ βββ βββ ββββββ ββββββ βββ ββββββββ
βββββ ββββββββββ ββββββββ ββββ ββββ ββββββ ββββββ ββ βββ ββββββββ
ββββββββ ββββββββββ βββ βββ βββββββ ββββββββ ββββββββ ββββββββ
ββββββββ ββββββββ βββ βββ βββββ ββββββββ ββββββ ββββββββ
2021-08-03T16:56:36.525Z DRIVER version 8.0.6
2021-08-03T16:56:36.528Z DRIVER
2021-08-03T16:56:54.055Z CONFIG version 8.0.6
2021-08-03T16:57:36.689Z CONFIG Priority device configuration directory /usr/src/app/store/config not found
2021-08-03T16:57:36.830Z CNTRLR beginning interview...
2021-08-03T16:57:36.831Z CNTRLR querying version info...
2021-08-03T16:57:37.728Z CNTRLR received version info:
controller type: Static Controller
library version: Z-Wave 6.04
2021-08-03T16:57:37.729Z CNTRLR querying controller IDs...
2021-08-03T16:57:37.771Z CNTRLR received controller IDs:
home ID: 0xd8e81a8f
own node ID: 1
2021-08-03T16:57:37.772Z CNTRLR querying controller capabilities...
2021-08-03T16:57:37.821Z CNTRLR received controller capabilities:
controller role: primary
is in other network: false
is SIS present: true
was real primary: true
is a SUC: true
2021-08-03T16:57:37.822Z CNTRLR querying API capabilities...
2021-08-03T16:57:37.863Z CNTRLR received API capabilities:
serial API version: 2.3
manufacturer ID: 0x027a
product type: 0x0401
product ID: 0x02
supported functions:
Β· GetSerialApiInitData (0x02)
Β· FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION (0x03)
Β· ApplicationCommand (0x04)
Β· GetControllerCapabilities (0x05)
Β· SetSerialApiTimeouts (0x06)
Β· GetSerialApiCapabilities (0x07)
Β· FUNC_ID_SERIAL_API_SOFT_RESET (0x08)
Β· UNKNOWN_FUNC_UNKNOWN_0x09 (0x09)
Β· UNKNOWN_FUNC_UNKNOWN_0x0a (0x0a)
Β· SerialAPISetup (0x0b)
Β· SetRFReceiveMode (0x10)
Β· UNKNOWN_FUNC_SET_SLEEP_MODE (0x11)
Β· FUNC_ID_ZW_SEND_NODE_INFORMATION (0x12)
Β· SendData (0x13)
Β· SendDataMulticast (0x14)
Β· GetControllerVersion (0x15)
Β· SendDataAbort (0x16)
Β· FUNC_ID_ZW_R_F_POWER_LEVEL_SET (0x17)
Β· FUNC_ID_ZW_GET_RANDOM (0x1c)
Β· GetControllerId (0x20)
Β· UNKNOWN_FUNC_MEMORY_GET_BYTE (0x21)
Β· UNKNOWN_FUNC_MEMORY_PUT_BYTE (0x22)
Β· UNKNOWN_FUNC_MEMORY_GET_BUFFER (0x23)
Β· UNKNOWN_FUNC_MEMORY_PUT_BUFFER (0x24)
Β· UNKNOWN_FUNC_FlashAutoProgSet (0x27)
Β· UNKNOWN_FUNC_UNKNOWN_0x28 (0x28)
Β· GetNVMId (0x29)
Β· ExtNVMReadLongBuffer (0x2a)
Β· ExtNVMWriteLongBuffer (0x2b)
Β· ExtNVMReadLongByte (0x2c)
Β· ExtExtWriteLongByte (0x2d)
Β· undefined (0x2e)
Β· undefined (0x2f)
Β· undefined (0x37)
Β· undefined (0x38)
Β· UNKNOWN_FUNC_ClearNetworkStats (0x39)
Β· UNKNOWN_FUNC_GetNetworkStats (0x3a)
Β· UNKNOWN_FUNC_GetBackgroundRSSI (0x3b)
Β· undefined (0x3c)
Β· UNKNOWN_FUNC_RemoveNodeIdFromNetwork (0x3f)
Β· GetNodeProtocolInfo (0x41)
Β· HardReset (0x42)
Β· FUNC_ID_ZW_REPLICATION_COMMAND_COMPLETE (0x44)
Β· FUNC_ID_ZW_REPLICATION_SEND_DATA (0x45)
Β· AssignReturnRoute (0x46)
Β· DeleteReturnRoute (0x47)
Β· RequestNodeNeighborUpdate (0x48)
Β· ApplicationUpdateRequest (0x49)
Β· AddNodeToNetwork (0x4a)
Β· RemoveNodeFromNetwork (0x4b)
Β· FUNC_ID_ZW_CREATE_NEW_PRIMARY (0x4c)
Β· FUNC_ID_ZW_CONTROLLER_CHANGE (0x4d)
Β· undefined (0x4f)
Β· FUNC_ID_ZW_SET_LEARN_MODE (0x50)
Β· AssignSUCReturnRoute (0x51)
Β· FUNC_ID_ZW_REQUEST_NETWORK_UPDATE (0x53)
Β· SetSUCNodeId (0x54)
Β· DeleteSUCReturnRoute (0x55)
Β· GetSUCNodeId (0x56)
Β· UNKNOWN_FUNC_SEND_SUC_ID (0x57)
Β· UNKNOWN_FUNC_AssignPrioritySUCReturnRoute (0x58)
Β· FUNC_ID_ZW_EXPLORE_REQUEST_INCLUSION (0x5e)
Β· undefined (0x5f)
Β· RequestNodeInfo (0x60)
Β· RemoveFailedNode (0x61)
Β· IsFailedNode (0x62)
Β· ReplaceFailedNode (0x63)
Β· UNKNOWN_FUNC_UNKNOWN_0x66 (0x66)
Β· UNKNOWN_FUNC_UNKNOWN_0x67 (0x67)
Β· UNKNOWN_FUNC_UNKNOWN_0x78 (0x78)
Β· GetRoutingInfo (0x80)
Β· UNKNOWN_FUNC_LOCK_ROUTE_RESPONSE (0x90)
Β· UNKNOWN_FUNC_GET_PRIORITY_ROUTE (0x92)
Β· UNKNOWN_FUNC_SET_PRIORITY_ROUTE (0x93)
Β· UNKNOWN_FUNC_UNKNOWN_0x98 (0x98)
Β· FUNC_ID_APPLICATION_SLAVE_COMMAND_HANDLER (0xa1)
Β· UNKNOWN_FUNC_UNKNOWN_0xB4 (0xb4)
Β· UNKNOWN_FUNC_WATCH_DOG_ENABLE (0xb6)
Β· UNKNOWN_FUNC_WATCH_DOG_DISABLE (0xb7)
Β· UNKNOWN_FUNC_WATCH_DOG_KICK (0xb8)
Β· UNKNOWN_FUNC_UNKNOWN_0xB9 (0xb9)
Β· UNKNOWN_FUNC_RF_POWERLEVEL_GET (0xba)
Β· UNKNOWN_FUNC_GET_LIBRARY_TYPE (0xbd)
Β· UNKNOWN_FUNC_SEND_TEST_FRAME (0xbe)
Β· UNKNOWN_FUNC_GET_PROTOCOL_STATUS (0xbf)
Β· FUNC_ID_ZW_SET_PROMISCUOUS_MODE (0xd0)
Β· FUNC_ID_PROMISCUOUS_APPLICATION_COMMAND_HANDLER (0xd1)
Β· UNKNOWN_FUNC_UNKNOWN_0xD2 (0xd2)
Β· UNKNOWN_FUNC_UNKNOWN_0xD3 (0xd3)
Β· UNKNOWN_FUNC_UNKNOWN_0xD4 (0xd4)
Β· undefined (0xee)
Β· UNKNOWN_FUNC_UNKNOWN_0xEF (0xef)
2021-08-03T16:57:37.865Z CNTRLR querying serial API setup capabilities...
2021-08-03T16:57:37.919Z CNTRLR supported serial API setup commands:
Β· GetSupportedCommands
Β· SetTxStatusReport
Β· SetPowerlevel
Β· GetPowerlevel
Β· GetMaximumPayloadSize
2021-08-03T16:57:37.920Z CNTRLR Enabling TX status report...
2021-08-03T16:57:37.955Z CNTRLR Enabling TX status report successful...
2021-08-03T16:57:37.956Z CNTRLR finding SUC...
2021-08-03T16:57:38.018Z CNTRLR This is the SUC
2021-08-03T16:57:38.068Z CNTRLR querying node information...
2021-08-03T16:57:38.196Z CNTRLR received node information:
controller is a SUC: true
controller is a slave: false
controller supports timers: false
nodes in the network: 1
2021-08-03T16:57:38.232Z CNTRLR setting serial API timeouts: ack = 1000 ms, byte = 150 ms
2021-08-03T16:57:38.262Z CNTRLR serial API timeouts overwritten. The old values were: ack = 1500 ms, byte = 15
0 ms
2021-08-03T16:57:38.263Z CNTRLR Interview completed
2021-08-03T16:57:38.314Z CNTRLR [Node 001] Beginning interview - last completed stage: None
2021-08-03T16:57:38.315Z CNTRLR [Node 001] new node, doing a full interview...
2021-08-03T16:57:38.320Z CNTRLR Β» [Node 001] querying protocol info...
2021-08-03T16:57:38.755Z CNTRLR Β« [Node 001] received response for protocol info:
basic device class: Static Controller
generic device class: Static Controller
specific device class: PC Controller
node type: Controller
is always listening: true
is frequent listening: false
can route messages: true
supports security: false
supports beaming: true
maximum data rate: 100000 kbps
protocol version: 3
2021-08-03T16:57:38.777Z CNTRLR [Node 001] Interview stage completed: ProtocolInfo
2021-08-03T16:57:38.778Z CNTRLR [Node 001] not pinging the controller
2021-08-03T16:57:38.780Z CNTRLR [Node 001] not querying node info from the controller
2021-08-03T16:57:38.785Z CNTRLR [Node 001] Interview stage completed: NodeInfo
2021-08-03T16:57:38.793Z CNTRLR [Node 001] Interview stage completed: CommandClasses
2021-08-03T16:57:38.861Z CNTRLR [Node 001] Embedded device config loaded
2021-08-03T16:57:38.865Z CNTRLR [Node 001] Interview stage completed: OverwriteConfig
2021-08-03T16:57:38.869Z CNTRLR [Node 001] Interview completed
2021-08-03T16:57:38.887Z CNTRLR [Node 001] The node is ready to be used
2021-08-03T16:57:38.889Z CNTRLR All nodes are ready to be used
2021-08-03T16:57:38.907Z CNTRLR [Node 001] The node is alive.
