All good. You can copy it in your configuration.yaml
Hallo,
wenn ich das einfĂŒge bekomme ich nach einem Neustart folgende Fehlermeldungen:
Logger: homeassistant.components.sensor
Source: helpers/entity_platform.py:692
Integration: Sensor (documentation, issues)
First occurred: 16:16:16 (3 occurrences)
Last logged: 17:10:22
Updating octoprint sensor took longer than the scheduled update interval 0:00:30
Logger: homeassistant.config
Source: config.py:464
First occurred: 16:11:17 (8 occurrences)
Last logged: 17:10:11
Invalid config for [template]: required key not provided @ data['sensor'][0]['state']. Got None. (See /config/configuration.yaml, line 139).
Invalid config for [automation]: [template] is an invalid option for [automation]. Check: automation->template. (See /config/configuration.yaml, line 12).
Invalid config for [template]: required key not provided @ data['sensor'][0]['state']. Got None. (See /config/configuration.yaml, line 138).
GruĂ Werner
Hi there,
when I insert this I get the following error messages after a restart:
Greetings Werner
Would you please so kind and post your configuration.yaml?
Hallo,
gern, ich hoffe ich habe alle Zugangsdaten entfernt.
GruĂ Werner
Hi there,
gladly, I hope I have removed all access data.
Greetings Werner
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
frontend:
themes: !include_dir_merge_named themes
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
automation: !include automations.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
# Test Garagentor Cover
cover:
covers:
garage_door:
friendly_name: "Garagentor mit Pfeilen"
device_class: garage
value_template: "{{ is_state('binary_sensor.tk04_sonoff_turkontakt_ias_zone', 'on') }}"
open_cover:
service: light.toggle
entity_id: light.ewelink_zb_sw01_1e1c6b22_on_off
close_cover:
stop_cover:
camera:
- platform: onvif
host:
port:
username:
password:
extra_arguments: -rtsp_flags none -rtsp_transport udp -q:v 2
alarm_control_panel:
- platform: manual
name:
code:
arming_time: 10
delay_time: 20
# Gruppe Hauptlich KĂŒche
light:
- platform: group
entities:
- light.lc10_paulmann_level_light_color_on_off
- light.lc11_paulmann_level_light_color_on_off
- light.lc12_paulmann_level_light_color_on_off
# Gruppe Ambientlicht KĂŒche
- platform: group
entities:
- light.iluminize_hk_zd_rgbcct_a_5878befe_level_light_color_on_off
- light.iluminize_hk_zd_rgbcct_a_44ada7fe_level_light_color_on_off
# Telegram Bot anbindung
telegram_bot:
- platform: polling
api_key:
allowed_chat_ids:
notify:
- name: HA_Message
platform: telegram
chat_id:
# Datum und Uhrzeit
sensors:
datum_zeit_time:
friendly_name: ""
value_template: >
{% set days = ['Mo.', 'Di.', 'Mi.', 'Do.', 'Endl.Fr.', 'Sa.', 'So.'] %}
{{ days[now().weekday()] }}
{{ now().strftime('%d.%m. - %H:%M') }} Uhr
# Einbindung Octoprint
octoprint:
host:
api_key:
# EntitÀten verbinden Gargentor (Test)
switch:
switches:
garage_door:
friendly_name: "Garagentorschalter"
turn_on:
turn_off:
icon_template: >-
{{ 'mdi:garage' if is_state('binary_sensor.tk04_sonoff_turkontakt_ias_zone','off') else 'mdi:garage-open' }}
# LĂŒfter SZ-KG EIN AUS
- platform: command_line
switches:
luefterszkg:
command_on: "/usr/bin/curl -X GET http://192.168.178.72/?power=on"
command_off: "/usr/bin/curl -X GET http://192.168.178.72/?power=off"
value_template: '{{ value == "1" }}'
friendly_name: LĂŒfter SZ-KG
luefterwzdg:
command_on: "/usr/bin/curl -X GET http://192.168.178.39/?power=on"
command_off: "/usr/bin/curl -X GET http://192.168.178.39/?power=off"
friendly_name: LĂŒfter WZ-DG
luefterszmoritz:
command_on: "/usr/bin/curl -X GET http://192.168.178.79/?power=on"
command_off: "/usr/bin/curl -X GET http://192.168.178.79/?power=off"
friendly_name: LĂŒfter SZ-Moritz
lueftermoritz:
command_on: "/usr/bin/curl -X GET http://192.168.178.71/?power=on"
command_off: "/usr/bin/curl -X GET http://192.168.178.71/?power=off"
friendly_name: LĂŒfter Moritz
template:
- sensor:
- unique_id: fensterstatus_kueche
- name: Status KĂŒchenfenster
state: |
{% set b1 = states('binary_sensor.lumi_lumi_sensor_magnet_aq2_b460d606_on_off') %}
{% set b2 = states('binary_sensor.lumi_lumi_sensor_magnet_aq2_b095e406_on_off') %}
{% if b1 == 'off' and b2 == 'off' %} Fenster KĂŒche geschlossen
{% elif b1 == 'on' and b2 == 'off' %} Fenster KĂŒche gekippt
{% elif b2 == 'on' %} Fenster KĂŒche offen
{% elif b1 == 'unavailable' or b2 == 'unavailable' %} Fenster KĂŒche nicht verfĂŒgbar
{% else %} ?
icon: |
{% if b1 == 'off' and b2 == 'off' %} mdi:window-closed-variant
{% elif b1 == 'on' and b2 == 'off' %} mdi:angle-acute
{% elif b2 == 'on' %} mdi:window-open-variant
{% elif b1 == 'unavailable' or b2 == 'unavailable' %} mdi:exclamation
{% else %} ?
Seems that your legacy template sensor and my example (âmodernâ method) clash.
This is my example built in legacy design:
fensterstatus_kueche:
friendly_name: Status KĂŒchenfenster
value_template: |
{% set b2 = states('binary_sensor. lumi_lumi_sensor_magnet_aq2_b095e406_on_off') %}
{% else %} ?
icon_template: |
{% else %} ?
Copy it under the last line of your sensor datum_zeit_time
Hallo danke,
das scheint zu funktionieren. Da ich unterwegs bin konnte ich es nur mit dem Handy testen, da erscheint nun so ein Bild
siehe ganz unten. Evtl. liegt es auch an meinem gewÀhlten Sensoren. Muss ich morgen am PC schauen.Danke.
GruĂ Werner
Hallo,
habe nun nochmals alles geprĂŒft. Die Lösung ist genial.
Vielen, vielen Dank.
Nur noch zwei Fragen:
- Ist es einfach möglich die Symbole von allen Fenstern die nicht geschlossen sind gelb zu fÀrben?
2.Wenn ich alle Fenster so eingefĂŒgt habe, dann ist meine configuration.yaml sehr voll. Könnte man alle Fenstersensoren z.B. in eine fenstersensoren.yaml auslagern?
Nochmals herzlichen Dank. Wie kann man diese Programiersprache nur so verstehen?
GruĂ Werner
Hi there,
have now checked everything again. The solution is awesome.
Thanks alot.
Just two more questions:
- Is it easy to color the symbols of all windows that are not closed yellow?
- When I have inserted all windows like this, then my configuration.yaml is very full. Could all window sensors be outsourced, for example in a window sensors.yaml?
Again thank you very much. How can you understand this programming language in that way?
Greetings Werner
As far as I know, there is no possibility to color the icon of a custom sensor. But you can adjust your theme.
Itâs possible to outsource your sensors but be aware that all sensors have to go to the other file. Because you canât duplicate sensor:
sensor: !include sensoren.yaml
âŠ
For a more adjustable split you could use directories (Iâm doing it by using packages
homeassistant:
packages: !include_dir_named pakete
(âpaketeâ is just an example)
In this new directory you can put unique files (and other directories), for example
tueren.yaml
telegram.yaml (if you want to outsource more than just sensors)
Hallo und vielen Dank.
die Auslagerung habe ich soweit verstanden und wĂŒrde mich bei Problemen nochmals melden.
Mit dem EinfÀrben (Thema) werde ich mich auch beschÀftzigen.
Das Hauptziel ist auf jedenfall erreicht.
Vielen Dank.
GruĂ Werner
Hello and thank you very much.
I have understood the outsourcing as far as possible and would contact me again if there were any problems.
I will also deal with the coloring (topic).
The main goal has definitely been achieved.
Thanks very much.
Greetings Werner
Iâm curious: When you click on your profile (last entry in sidebar menu), what is set under âthemeâ?
Hi there,
âBackend-Selectâ is selected.
Greetings Werner
Hallo,
da ist âBackend-Selectâ ausgewĂ€hlt.
GruĂ Werner
Then the colors should work. Strange.
The colors also work normally. The symbols only remain blue for the newly created window sensors
Normal funktionieren die Farben auch. Nur bei den neu erstellten Fenstersensoren bleiben die Symbole blau.
I was wrong. Also the default theme canât change the colors of a custom sensor in a generic frontend card. What a pity.
Hi there,
no problem. If this does not work, I will display all open or tilted windows on a map. I use this system for this:
đč Auto-entities - Automatically fill cards with entities
Unfortunately, I still canât do that either.
Tried to select âfensterstatusâ as Entities - that also worked.
However, if I enter âoffenâ as the âStateâ, it doesnât work.
I changed the sensor code a bit, for example:
fensterstatus_schlafzimmer_dg:
friendly_name: Fenster Schlafzimmer-DG
value_template: |
{% set b1 = states('binary_sensor.lumi_lumi_sensor_magnet_aq2_007cf906_on_off') %}
{% set b2 = states('binary_sensor.lumi_lumi_sensor_magnet_aq2_698aff06_on_off') %}
{% if b1 == 'off' and b2 == 'off' %} geschlossen
{% elif b1 == 'on' and b2 == 'off' %} gekippt
{% elif b2 == 'on' %} offen
{% elif b1 == 'unavailable' or b2 == 'unavailable' %} nicht verfĂŒgbar
{% else %} ?
icon_template: |
{% else %} ?
Greetings Werner
Hallo,
kein Problem. Wenn es so nicht geht, werde ich mir alle offenen oder gekippten Fenster in einer Karte anzeigen lassen. Ich nutze dazu dieses System:
Leider bekomme ich auch das noch nicht hin.
Habe versucht als Entities fensterstatus zu wÀhlen - das hat auch funktioniert.
Jedoch wenn ich als âStateâ z.B. âoffenâ eingebe, da funktioniert es nicht.
Den Sensorencode habe ich noch etwas geÀndert, z.B.:
value_template: |
{% else %} ?
icon_template: |
{% else %} ?
GruĂ Werner
Sorry it works, with this code:
type: custom:auto-entities
card:
type: entities
filter:
include:
- entity_id: '*fensterstatus*'
state: '*offen*'
exclude: []
But how can I define a state as offen or gekippt
Sorry es funktioniert doch, mit diesem Code:
card:
type: entities
filter:
include:
state: '*offen*'
exclude: []
Aber wie kann ich als state offen oder gekippt
definieren?
My first success.
It works like this:
card:
type: entities
filter:
include:
state: '*offen*'
state: '*gekippt*'
exclude: []
Mein erster Erfolg.
Es funktioniert so:
card:
type: entities
filter:
include:
state: '*offen*'
state: '*gekippt*'
exclude: []
Who did you work that?
I have do a new card but nothing would show? I have one entity_id for open and one for gekippt.
I would show it on the card if its open or gekippt or closed.
Hi there,
so i ended up in the l:
card:
type: entities
title: Offene Fenster
state_color: true
show_header_toggle: false
filter:
include:
state: offen
state: '*offen oder gekippt*'
state: gekippt
state: '*nicht*'
state: '?'
exclude:
state: '*geschlossen*'
sort:
method: friendly_name
Greetings Werner
thx for this piece of code!
