Hi, yep the sensor is still working fine. I make use of it every time I’m Zwifting
About the configuration in Home Assistant. In configuration.yaml file I added the platform like you already mentioned in your message. After that I added the following entities in my dashboard (there a more entities availably):
type: entities
entities:
- entity: sensor.zwift_online_4431663
- entity: sensor.zwift_cadence_4431663
- entity: sensor.zwift_heart_rate_4431663
- entity: sensor.zwift_power_4431663
- entity: sensor.zwift_speed_4431663
- entity: sensor.zwift_distance_4431663
- entity: sensor.zwift_level_4431663
- entity: sensor.zwift_cycle_progress_4431663
title: Zwift
state_color: true
I also made in Node Red (which I do my automations in) the following automation (see below). This automation controls my fans based on my heartrate in Zwift.
[{"id":"e6dcfb8ea25b1e24","type":"server-state-changed","z":"edbfabe1c95de39e","name":"Zwift cadance <=40","server":"480f0ad4.89a784","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.zwift_cadence_4431663","entityidfiltertype":"exact","outputinitially":true,"state_type":"num","haltifstate":"40","halt_if_type":"num","halt_if_compare":"lte","outputs":2,"output_only_on_state_change":true,"for":"60","forType":"num","forUnits":"seconds","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":90,"y":570,"wires":[["49e2421c8c2c27d4"],[]]},{"id":"49e2421c8c2c27d4","type":"api-current-state","z":"edbfabe1c95de39e","name":"Zwift speed <= 10","server":"480f0ad4.89a784","version":3,"outputs":2,"halt_if":"10.0","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.zwift_speed_4431663","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":300,"y":570,"wires":[["7796c675d9160253"],[]]},{"id":"a7741dbf5bc3514c","type":"function","z":"edbfabe1c95de39e","name":"Set text to number","func":"msg.payload = Number(msg.payload);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1080,"y":555,"wires":[["809971767d09657c","f0db4f9bbe3f102b","c8da7738c333eccd","0aab647246bf633d"]]},{"id":"c8da7738c333eccd","type":"api-call-service","z":"edbfabe1c95de39e","name":"Zwift fan - hoog - Off","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.fan_zwift_high"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1420,"y":570,"wires":[[]]},{"id":"f0db4f9bbe3f102b","type":"api-call-service","z":"edbfabe1c95de39e","name":"Zwift fan - middel - Off","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.fan_zwift_middel"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1420,"y":525,"wires":[[]]},{"id":"809971767d09657c","type":"api-call-service","z":"edbfabe1c95de39e","name":"Zwift fan - laag - Off","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.fan_zwift_low"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1420,"y":480,"wires":[[]]},{"id":"6e4ecba18eb82bd7","type":"api-call-service","z":"edbfabe1c95de39e","name":"Zwift verlichting groep (Off)","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["light.zwift_verlichting_groep_2"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"first","x":1575,"y":615,"wires":[[]]},{"id":"7796c675d9160253","type":"api-current-state","z":"edbfabe1c95de39e","name":"Zwift power <= 10","server":"480f0ad4.89a784","version":3,"outputs":2,"halt_if":"10","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.zwift_power_4431663","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":510,"y":570,"wires":[["a7741dbf5bc3514c"],[]]},{"id":"bd02c70091a1cf75","type":"comment","z":"edbfabe1c95de39e","name":"Zwift -> 60 sec. klaar met fietsen","info":"","x":130,"y":525,"wires":[]},{"id":"0aab647246bf633d","type":"delay","z":"edbfabe1c95de39e","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1365,"y":615,"wires":[["6e4ecba18eb82bd7","1a5c8a878e4c05bb","65cdc652c5268632","b40948021496d9b8"]]},{"id":"65cdc652c5268632","type":"api-call-service","z":"edbfabe1c95de39e","name":"Verlichting kantoor Melloh spotjes (verl.) (OFF)","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["light.kantoor_melloh_spotjes_groep"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1630,"y":705,"wires":[[]]},{"id":"b40948021496d9b8","type":"api-call-service","z":"edbfabe1c95de39e","name":"Kastje kantoor Melloh (verl.) (OFF)","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["light.candle_gold"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":true,"outputProperties":[],"queue":"none","x":1600,"y":750,"wires":[[]]},{"id":"1a5c8a878e4c05bb","type":"api-call-service","z":"edbfabe1c95de39e","name":"Fototoestel verlichting - kantoor Melloh (verl.) (OFF)","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["light.fototoestel_verlichting_kantoor_melloh"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1645,"y":660,"wires":[[]]},{"id":"ad26c0fb5fe7eee5","type":"api-current-state","z":"edbfabe1c95de39e","name":">=90: Zwift Fan - laag is (aan)","server":"480f0ad4.89a784","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.fan_zwift_low","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1130,"y":30,"wires":[[],["d8bb79bb2cee702a"]]},{"id":"d8bb79bb2cee702a","type":"api-call-service","z":"edbfabe1c95de39e","name":"Zwift fan - laag - On","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.fan_zwift_low"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1405,"y":30,"wires":[["1be23e96e2aaa4d3"]]},{"id":"caee75668c74550a","type":"switch","z":"edbfabe1c95de39e","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"125","vt":"num"},{"t":"btwn","v":"126","vt":"num","v2":"148","v2t":"num"},{"t":"btwn","v":"149","vt":"num","v2":"162","v2t":"num"},{"t":"btwn","v":"163","vt":"num","v2":"300","v2t":"num"}],"checkall":"true","repair":false,"outputs":4,"x":720,"y":180,"wires":[["4677c94a79578a7c","302ba3f6c4fafef5","e609251919d17ce9"],["dcd7f96935b35e4c"],["13f1d6fb1cd467cd"],["daebe235a4b83c87"]]},{"id":"4e732172cb0160ba","type":"api-current-state","z":"edbfabe1c95de39e","name":">=166: Zwift Fan - hoog is (aan)","server":"480f0ad4.89a784","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.fan_zwift_high","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1130,"y":390,"wires":[[],["2cb3667bfebfc878"]]},{"id":"2cb3667bfebfc878","type":"api-call-service","z":"edbfabe1c95de39e","name":"Zwift fan - hoog - On","server":"480f0ad4.89a784","version":5,"debugenabled":true,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.fan_zwift_high"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1415,"y":390,"wires":[["5b797c12b845da7f"]]},{"id":"302ba3f6c4fafef5","type":"switch","z":"edbfabe1c95de39e","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"90","vt":"num"},{"t":"lte","v":"89","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":915,"y":30,"wires":[["ad26c0fb5fe7eee5"],["8831c667a65c8690"]]},{"id":"4e11efd843d5ae82","type":"api-call-service","z":"edbfabe1c95de39e","name":"Zwift fan - laag - Off","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.fan_zwift_low"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1405,"y":75,"wires":[["6e452db052ab6a8a"]]},{"id":"8831c667a65c8690","type":"api-current-state","z":"edbfabe1c95de39e","name":"<=89: Zwift Fan - laag is (aan)","server":"480f0ad4.89a784","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.fan_zwift_low","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1130,"y":75,"wires":[["4e11efd843d5ae82"],[]]},{"id":"daebe235a4b83c87","type":"switch","z":"edbfabe1c95de39e","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"163","vt":"num"},{"t":"lte","v":"162","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":910,"y":390,"wires":[["4e732172cb0160ba"],["4677c94a79578a7c"]]},{"id":"4677c94a79578a7c","type":"api-current-state","z":"edbfabe1c95de39e","name":"<=164: Zwift Fan - hoog is (aan)","server":"480f0ad4.89a784","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.fan_zwift_high","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1130,"y":435,"wires":[["fb90fc71926c6faa"],[]]},{"id":"fb90fc71926c6faa","type":"api-call-service","z":"edbfabe1c95de39e","name":"Zwift fan - hoog - Off","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.fan_zwift_high"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1415,"y":435,"wires":[["698ddccab3a74761"]]},{"id":"c0fce1f5e0092850","type":"api-current-state","z":"edbfabe1c95de39e","name":"Zwift heart rate >= 80","server":"480f0ad4.89a784","version":3,"outputs":2,"halt_if":"80","halt_if_type":"num","halt_if_compare":"gte","entity_id":"sensor.zwift_heart_rate_4431663","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":320,"y":180,"wires":[["d122ae79e84f0e65"],[]]},{"id":"94f2df0e10576ecc","type":"server-state-changed","z":"edbfabe1c95de39e","name":"Zwift cadance >=40","server":"480f0ad4.89a784","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.zwift_cadence_4431663","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"40","halt_if_type":"num","halt_if_compare":"gte","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":100,"y":180,"wires":[["c0fce1f5e0092850"],[]]},{"id":"d122ae79e84f0e65","type":"function","z":"edbfabe1c95de39e","name":"Set text to number","func":"msg.payload = Number(msg.payload);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":550,"y":180,"wires":[["caee75668c74550a"]]},{"id":"9dc8be5be983c0f4","type":"comment","z":"edbfabe1c95de39e","name":"Hartslag Zwift -> snelheid fan","info":"","x":130,"y":135,"wires":[]},{"id":"dcd7f96935b35e4c","type":"switch","z":"edbfabe1c95de39e","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"138","vt":"num"},{"t":"lt","v":"138","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":910,"y":120,"wires":[["a3bbc646638c3005","2484ce2904ec705b"],["e609251919d17ce9"]]},{"id":"a3bbc646638c3005","type":"api-current-state","z":"edbfabe1c95de39e","name":">=152: Zwift Fan - middel is (aan)","server":"480f0ad4.89a784","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.fan_zwift_middel","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1140,"y":120,"wires":[[],["781e0c148f24db89"]]},{"id":"781e0c148f24db89","type":"api-call-service","z":"edbfabe1c95de39e","name":"Zwift fan - middel - On","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.fan_zwift_middel"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1410,"y":120,"wires":[["a6d698c22514bbf7"]]},{"id":"644a1d52bd192224","type":"api-call-service","z":"edbfabe1c95de39e","name":"Zwift fan - middel - Off","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.fan_zwift_middel"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1415,"y":210,"wires":[["3488153aaaa35b15"]]},{"id":"e609251919d17ce9","type":"api-current-state","z":"edbfabe1c95de39e","name":"<=151: Zwift Fan - middel is (aan)","server":"480f0ad4.89a784","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.fan_zwift_middel","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1140,"y":210,"wires":[["644a1d52bd192224"],[]]},{"id":"7a3b351bf855ccef","type":"api-call-service","z":"edbfabe1c95de39e","name":"Zwift verlichting groep - E14 WIZ rood (ON)","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.zwift_verlichting_groep_2"],"data":"{\"transition\":150.0,\"rgb_color\":[255,0,0],\"brightness_step_pct\":100}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"first","x":1905,"y":390,"wires":[[]]},{"id":"7f54a54d6db363e9","type":"api-call-service","z":"edbfabe1c95de39e","name":"Zwift verlichting groep - E14 WIZ groen (ON)","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.zwift_verlichting_groep_2"],"data":"{\"transition\":150.0,\"rgb_color\":[80,191,0],\"brightness_step_pct\":100}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"first","x":1905,"y":30,"wires":[[]]},{"id":"90d9754a827b07ea","type":"api-call-service","z":"edbfabe1c95de39e","name":"Zwift verlichting groep - E14 WIZ groen (Off)","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["light.zwift_verlichting_groep_2"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"first","x":1905,"y":75,"wires":[[]]},{"id":"9b9cb4c292497135","type":"inject","z":"edbfabe1c95de39e","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"90","payloadType":"str","x":515,"y":255,"wires":[["caee75668c74550a"]]},{"id":"a0020fe4f2c2598b","type":"inject","z":"edbfabe1c95de39e","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"155","payloadType":"str","x":515,"y":375,"wires":[["caee75668c74550a"]]},{"id":"8cf8b48d20bc45bf","type":"inject","z":"edbfabe1c95de39e","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"168","payloadType":"str","x":515,"y":495,"wires":[["caee75668c74550a"]]},{"id":"cb1672e7658f0099","type":"inject","z":"edbfabe1c95de39e","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"65","payloadType":"str","x":515,"y":225,"wires":[["caee75668c74550a"]]},{"id":"1be23e96e2aaa4d3","type":"delay","z":"edbfabe1c95de39e","name":"","pauseType":"delay","timeout":"300","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1625,"y":30,"wires":[["7f54a54d6db363e9"]]},{"id":"6e452db052ab6a8a","type":"delay","z":"edbfabe1c95de39e","name":"","pauseType":"delay","timeout":"300","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1625,"y":75,"wires":[["90d9754a827b07ea"]]},{"id":"a6d698c22514bbf7","type":"delay","z":"edbfabe1c95de39e","name":"","pauseType":"delay","timeout":"300","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1620,"y":120,"wires":[["64899e8f6a10c0b0"]]},{"id":"5b797c12b845da7f","type":"delay","z":"edbfabe1c95de39e","name":"","pauseType":"delay","timeout":"300","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1625,"y":390,"wires":[["7a3b351bf855ccef"]]},{"id":"698ddccab3a74761","type":"delay","z":"edbfabe1c95de39e","name":"","pauseType":"delay","timeout":"300","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1625,"y":435,"wires":[["eb6ae63d70f91eb5"]]},{"id":"13f1d6fb1cd467cd","type":"switch","z":"edbfabe1c95de39e","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"149","vt":"num"},{"t":"lt","v":"149","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":910,"y":255,"wires":[["9b4fe3e38fd1c3e6","33461e0c49692e27","b4442058633740a6"],[]]},{"id":"9b4fe3e38fd1c3e6","type":"api-current-state","z":"edbfabe1c95de39e","name":">=158: Zwift Fan - middel is (aan)","server":"480f0ad4.89a784","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.fan_zwift_middel","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1140,"y":255,"wires":[[],["4e1c28e152e4192e"]]},{"id":"4e1c28e152e4192e","type":"api-call-service","z":"edbfabe1c95de39e","name":"Zwift fan - middel - On","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.fan_zwift_middel"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1410,"y":255,"wires":[["b65d0a28d3cc6bcc"]]},{"id":"b65d0a28d3cc6bcc","type":"delay","z":"edbfabe1c95de39e","name":"","pauseType":"delay","timeout":"300","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1630,"y":255,"wires":[["8012554def7ca0fd"]]},{"id":"8012554def7ca0fd","type":"api-call-service","z":"edbfabe1c95de39e","name":"Zwift verlichting groep - E14 WIZ paars (ON)","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.zwift_verlichting_groep_2"],"data":"{\"transition\":150.0,\"rgb_color\":[155, 0, 155],\"brightness_step_pct\":100}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"first","x":1915,"y":300,"wires":[[]]},{"id":"64899e8f6a10c0b0","type":"api-call-service","z":"edbfabe1c95de39e","name":"Zwift verlichting groep - E14 WIZ blauw (ON)","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.zwift_verlichting_groep_2"],"data":"{\"transition\":150.0,\"rgb_color\":[20,3,252],\"brightness_step_pct\":100}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"first","x":1910,"y":165,"wires":[[]]},{"id":"e5748e388a21662b","type":"inject","z":"edbfabe1c95de39e","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"140","payloadType":"str","x":515,"y":315,"wires":[["caee75668c74550a"]]},{"id":"df71d386a2d299ae","type":"inject","z":"edbfabe1c95de39e","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"152","payloadType":"str","x":515,"y":345,"wires":[["caee75668c74550a"]]},{"id":"acf6dfd9e2b752d8","type":"inject","z":"edbfabe1c95de39e","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"130","payloadType":"str","x":515,"y":285,"wires":[["caee75668c74550a"]]},{"id":"eb6ae63d70f91eb5","type":"api-call-service","z":"edbfabe1c95de39e","name":"Zwift verlichting groep - E14 WIZ paars (ON)","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.zwift_verlichting_groep_2"],"data":"{\"transition\":150.0,\"rgb_color\":[155, 0, 155],\"brightness_step_pct\":100}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"first","x":1915,"y":435,"wires":[[]]},{"id":"a1ba1a7cbf904734","type":"api-call-service","z":"edbfabe1c95de39e","name":"Zwift verlichting groep - E14 WIZ groen (ON)","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.zwift_verlichting_groep_2"],"data":"{\"transition\":150.0,\"rgb_color\":[80,191,0],\"brightness_step_pct\":100}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"first","x":1920,"y":210,"wires":[[]]},{"id":"3488153aaaa35b15","type":"delay","z":"edbfabe1c95de39e","name":"","pauseType":"delay","timeout":"300","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1630,"y":210,"wires":[["a1ba1a7cbf904734"]]},{"id":"1ed21a653465d3e5","type":"inject","z":"edbfabe1c95de39e","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"159","payloadType":"str","x":515,"y":405,"wires":[["caee75668c74550a"]]},{"id":"251df908859f7fa4","type":"api-current-state","z":"edbfabe1c95de39e","name":"<=164: Zwift Fan - hoog is (aan)","server":"480f0ad4.89a784","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.fan_zwift_high","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1445,"y":345,"wires":[["fcbecb7ec82ee00e"],[]]},{"id":"fcbecb7ec82ee00e","type":"api-call-service","z":"edbfabe1c95de39e","name":"Zwift fan - hoog - Off","server":"480f0ad4.89a784","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.fan_zwift_high"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1715,"y":345,"wires":[[]]},{"id":"a3f9a0e8258b7be7","type":"inject","z":"edbfabe1c95de39e","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"162","payloadType":"str","x":515,"y":435,"wires":[["caee75668c74550a"]]},{"id":"0051c17f4e31938e","type":"inject","z":"edbfabe1c95de39e","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"163","payloadType":"str","x":515,"y":465,"wires":[["caee75668c74550a"]]},{"id":"33461e0c49692e27","type":"delay","z":"edbfabe1c95de39e","name":"","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1075,"y":345,"wires":[["251df908859f7fa4"]]},{"id":"b4442058633740a6","type":"delay","z":"edbfabe1c95de39e","name":"","pauseType":"delay","timeout":"700","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1070,"y":300,"wires":[["8012554def7ca0fd"]]},{"id":"2484ce2904ec705b","type":"delay","z":"edbfabe1c95de39e","name":"","pauseType":"delay","timeout":"700","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1070,"y":165,"wires":[["64899e8f6a10c0b0"]]},{"id":"480f0ad4.89a784","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
