Awesome. Thanks @snicker
Hi Snicker, just installed the plugin from HACS and it’s working…
Is there already someone who has created a good Lovelace or Grafana setup to visualize your Zwift work-outs?
Will not speak for everybody, but my use case is limited to control fans, lighting and windows. Have some plans to create something similar to wahoo climb. So basically to momentary data, so I have removed zwift sensors from recorder to reduce diskspace usage.
Just curious… how can you remove the recording function from a sensor?
It is great project, I’ll register again zwift for this.
Through recorder option, since the sensors generate quite an amount of data in attributes
recorder:
exclude:
entities:
- sensor.zwift_cadence_xxxx
- sensor.zwift_power_xxx
- sensor.zwift_online_xxx
Thx… never knew is was this easy.
Does the refresh_interval
parameter still exist? HomeAssistant tells me that it’s an invalid parameter.
Seems pretty realtime now.
FYI I’ve made these things which are nice. Not sure the best way to display yet: Get the amount of time at each power zone in the last session…
- platform: history_stats
name: Threshold last Zwift Session
entity_id: sensor.zwift_power_zone
state: 'Threshold'
type: time
start: '{{ states.input_datetime.zwift_last_online.attributes.timestamp }}'
end: '{{ states.input_datetime.zwift_last_offline.attributes.timestamp }}'
name: Off last Zwift Session
state: 'Off'
type: time
name: Active Recovery last Zwift Session
state: 'Active Recovery'
type: time
name: Endurance last Zwift Session
state: 'Endurance'
type: time
name: Tempo last Zwift Session
state: 'Tempo'
type: time
name: VO2 Max last Zwift Session
state: 'VO2 Max'
type: time
name: Anaerobic capacity last Zwift Session
state: 'Anaerobic capacity'
type: time
name: Neuromuscular Power last Zwift Session
state: 'Neuromuscular Power'
type: time
It runs off the power zone setup here
sensors:
zwift_ftp:
friendly_name: "Zwift FTP"
entity_id: sensor.zwift_online
unit_of_measurement: 'watts'
value_template: "{{states.sensor.zwift_online.attributes.ftp}}"
zwift_power_zone:
friendly_name: "Zwift Power Zone"
value_template: >-
{% set ftp = states('sensor.zwift_ftp') | float %}
{% set power = states('sensor.zwift_power') | float %}
{% set zone1 = ftp | float * 0.55 %}
{% set zone2 = ftp | float * 0.76 %}
{% set zone3 = ftp | float * 0.90 %}
{% set zone4 = ftp | float * 1.05 %}
{% set zone5 = ftp | float * 1.2 %}
{% set zone6 = ftp | float * 1.5 %}
{% if power < 1 %}Off
{% elif zone1 > power %}Active Recovery
{% elif zone2 > power %}Endurance
{% elif zone3 > power %}Tempo
{% elif zone4 > power %}Threshold
{% elif zone5 > power %}VO2 Max
{% elif zone6 > power %}Anaerobic capacity
{% elif zone6 < power %}Neuromuscular Power{% endif %}
and an on/off datetime like this
input_datetime:
zwift_last_online:
name: Zwift Last Online
has_date: true
has_time: true
zwift_last_offline:
name: Zwift Last Offline
has_date: true
has_time: true
These are set through node red
state: 'Threshold'
type: time
state: 'Off'
type: time
type: time
state: 'Endurance'
type: time
state: 'Tempo'
type: time
state: 'VO2 Max'
type: time
type: time
type: time
sensors:
zwift_ftp:
zwift_power_zone:
value_template: >-
input_datetime:
zwift_last_online:
has_date: true
has_time: true
zwift_last_offline:
has_date: true
has_time: true
state: 'Threshold'
type: time
state: 'Off'
type: time
type: time
state: 'Endurance'
type: time
state: 'Tempo'
type: time
state: 'VO2 Max'
type: time
type: time
type: time
sensors:
zwift_ftp:
zwift_power_zone:
value_template: >-
input_datetime:
zwift_last_online:
has_date: true
has_time: true
zwift_last_offline:
has_date: true
has_time: true
These are set through node red which sets them to now when distance goes above 0 and back to 0
[{"id":"52eec60f.e29148","type":"tab","label":"zwift","disabled":false,"info":""},{"id":"55730cc0.8cbe74","type":"api-call-service","z":"52eec60f.e29148","name":"","server":"2c038d05.2091b2","version":1,"service_domain":"input_datetime","service":"set_datetime","entityId":"input_datetime.zwift_last_online","data":"\t{'datetime':$now()}","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":820,"y":380,"wires":[[]]},{"id":"b617cad7.7d3738","type":"function","z":"52eec60f.e29148","name":"","func":"sold = msg.data.event.old_state.state;\nsnew = msg.data.event.new_state.state;\n\nif (sold != snew && sold === \"0.0\"){\n msg = {\n \"payload\": true\n }\n return msg;\n}\n\nelse if (snew === \"0.0\") { \n msg = {\n \"payload\": false\n }\n return msg;\n}\n\n\nmsg = {\n \"payload\": \"nope\"\n}\nreturn msg;","outputs":1,"noerr":0,"x":470,"y":440,"wires":[["d9a72182.4944f"]]},{"id":"a1773896.2d2e18","type":"api-current-state","z":"52eec60f.e29148","name":"","server":"2c038d05.2091b2","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"sensor.zwift_distance","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":210,"y":440,"wires":[["b617cad7.7d3738"]]},{"id":"5d4029a5.1ea498","type":"trigger-state","z":"52eec60f.e29148","name":"","server":"2c038d05.2091b2","entityid":"sensor.zwift_distance","entityidfiltertype":"exact","debugenabled":false,"constraints":[],"constraintsmustmatch":"all","outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"str","x":190,"y":300,"wires":[["b617cad7.7d3738"],[]]},{"id":"d9a72182.4944f","type":"switch","z":"52eec60f.e29148","name":"","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":610,"y":440,"wires":[["55730cc0.8cbe74"],["4ea1644f.0a0b4c"]]},{"id":"4ea1644f.0a0b4c","type":"api-call-service","z":"52eec60f.e29148","name":"","server":"2c038d05.2091b2","version":1,"service_domain":"input_datetime","service":"set_datetime","entityId":"input_datetime.zwift_last_offline","data":"\t{'datetime':$now()}","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":820,"y":440,"wires":[[]]},{"id":"2c038d05.2091b2","type":"server","z":"","name":"Home Assistant"}]
I am so excited for it to be cold enough to Zwift again… these configurations look awesome!!
Some of us do it through the Summer
I have a problem where it’s failing to save the _online_
entity because of the workout…
Error saving event: <Event state_changed[L]: entity_id=sensor.zwift_online_753598, ... privateAttributes=-1807501245=24953748, -1006995462=1534277136, -1741267406=15025, -51277064=6, -606378544=23389, 756053275=14, -1774820805=12, -1001004453=CYCLIST, 1017378481=606, -331985374=59, -2008990124=24965, -259609442=13, 2004261226=28796.1, -398081446=<workout_file>
<description>Foundation training: Relatively low intensity ride with goal of spending a large proportion of the ride into Endurance Zone 2.</description>
<category>6wk Beginner FTP Builder</category><WorkoutPlan>1</WorkoutPlan>
<subcategory>Week 1</subcategory>
<categoryIndex>3</categoryIndex>
<name>Foundation</name>
<authorIcon>UI/WhiteOrangeTheme/Workout_Select/brands/MarcoPinotti_Logo.tga</authorIcon>
<categoryIndex>2</categoryIndex>
<workout>
<Warmup Duration="600" Zone="1"/>
<SteadyState Duration="300" Zone="2"><TextEvent message="90-100 RPM Cadence!" /></SteadyState>
<SteadyState Duration="120" Zone="1"><TextEvent message="90-100 RPM Cadence!" /></SteadyState>
<Cooldown Duration="300" Zone="1"/>
</workout>
</workout_file>...
Any idea how/where to kill that data in Zwift or in this implementation?
I now have this lovely chart using the sensors I mentioned about and the big number card https://github.com/custom-cards/bignumber-card. Colours could do with some love!
Here is the config that makes it:
type: vertical-stack
cards:
- type: 'custom:bignumber-card'
entity: sensor.active_recovery_last_zwift_session
min: 0
max: 1
scale: 20px
show_state: true
title: Active Recovery
show_icon: false
severity:
- value: 0.01
style: grey
- value: 2
style: grey
entity: sensor.endurance_last_zwift_session
min: 0
max: 1
scale: 20px
show_state: true
title: Endurance
show_icon: false
scale: 20px
entity: sensor.tempo_last_zwift_session
min: 0
max: 1
show_state: true
title: Tempo
show_icon: false
severity:
- value: 0.01
style: 'rgb(130,212,83)'
- value: 2
entity: sensor.threshold_last_zwift_session
scale: 20px
min: 0
max: 1
show_state: true
title: Threshold
show_icon: false
severity:
- value: 0.01
style: yellow
- value: 2
style: yellow
entity: sensor.vo2_max_last_zwift_session
min: 0
max: 1
scale: 20px
show_state: true
title: Vo2 Max
show_icon: false
severity:
- value: 0.01
style: orange
- value: 2
style: orange
entity: sensor.anaerobic_capacity_last_zwift_session
min: 0
max: 1
show_state: true
title: Anaerobic Capacity
show_icon: false
scale: 20px
severity:
- value: 0.01
style: red
- value: 2
style: red
entity: sensor.neuromuscular_power_last_zwift_session
min: 0
max: 1
scale: 20px
show_state: true
title: Neuromuscular Power
show_icon: false
severity:
- value: 0.01
style: purple
- value: 2
style: purple
Note that this is based on a 1 hour session, you’ll need to tweak the max accordingly. It could probably use a template maybe, hmmm.
Also note the node red above seems to add UTC dates which I’ll fix and update here ASAP
refresh_interval
is replaced by update_interval
. This defaults to 15 seconds, but when a player is online, Zwift will be polled every second.
@phillprice update to the latest commit in the repository and the issue with the privateAttributes should be resolved. Given that I was just dumping a ton of data into the attributes of the online
sensor, it looks like a lot of unsanitary data was coming in on that privateAttributes
key. It’s eliminated now
Hey .- since the update (and moving to a HACS install I have no data coming through.
Happy to debug if you have any guidance
could you share your config for the sensor? I’m at a loss since I’m running the same version and it seems to be working fine
Sure, Its not very interesting!
- platform: zwift
username: !secret my_zwift_username
password: !secret my_zwift_password
I’m not sure what to add add to the logger for this would it be one of these?
logger:
default: error
logs:
homeassistant.components.sensor: debug
homeassistant.components.zwift: debug
Still not sure what could be going on. I did notice in your configurations above that your sensor names were sensor.zwift_online
. However, there should be your player ID in that sensor
Yeah I removed my ID
