xbmcnut
Being able to tweak Lovelace and simply hit the refresh button is freak’n awesome!
Keep up the good work, always love the pace at which things get released (and so open too)
Keep up the GREAT WORK!!! I love Home Assistant and where it is headed. Going to try user authentication next. One question, I don’t think the docs accurately represent what happened to the Pollen.com sensor. Mine all stayed the same they were just appended with a _2.
Is this correct?
We wouldn’t have this statement below if there aren’t any “security concerns/I’ve been hacked” threads, right?
The new additions to component lists seem very quiet for 0.73. No new additions that get me excited. Well, just Rachio and HomeKit and that’s about it… I will wait for 0.74 as I only have two Insteon dimmers and a receiver hooked up.
1 replyYou should read the original blog post for all changes. The one on the forum is incomplete.
1 reply Holy mother of home automations…
That Lovelace UI is going
Thank you guys for the hard work on this!
The correct assumption is I did read the real blog post and clicked “Continue Discussion.” All the changes are a lot more detailed compared to see if there are any new components for 0.73. I read the changes again and there’s not that much that is exciting.
Lovelace does seem interesting, but my home automation setup is barely minimal unless I have money for more products that I can make use of, such as Konnected.
Same here. I double checked my config.
Enabled username/password authentication and getting prompted for a username and passoword which works, but password is not masked as ***. Is it supposed to be so?
posting this only to show that even a total novice can begin to figure this out. I use a tablet in kiosk so I have to keep the panels uncluttered. this is just the first layout. will learn to customize more.
All fixed…thanks
Another change not mentioned in the release notes above that may catch people by surprise (it did me) is that the behavior of the lock toggle in the UI has changed. As of 0.73 the behavior is now reversed:
previously it worked the other way round
For more information on this change and potential future changes around the lock UI see 73.0 -- lock status is inverted and the corresponding issue in Github https://github.com/home-assistant/home-assistant/issues/15276
1 replyAlso still having problems with pollen.com in this release:
2018-07-08 13:00:53 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.pollen
2018-07-08 13:00:53 ERROR (MainThread) [homeassistant.components.sensor] pollen: Error on device update!
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 248, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 317, in async_device_update
yield from self.async_update()
File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/pollen.py", line 186, in async_update
data = self.pollencom.data[self._category]['Location']
KeyError: 'allergy_index'
My config for this component is unchanged from 0.72.1, and still matches a “correct” config according to the documentation for the component. Oddly: one of the conditions I’m monitoring is “disease_average_forecasted”, and though that no longer shows up as an entity for me, I do now see “sensor.cold__flu_forecasted_average_2”, which would appear to be the same data under a different name; a name that is not listed in the documentation as a valid entity.
1 replyPlease post a bug and we’ll take a look.
Fist, I love the new UI. The glance card is especially nice.
It would be really nice to be able to change font size especially on the aforementioned glance card as the names get shortened with only a few characters on my phone screen.
For the lock, the change to ‘lock/unlock’ does fix the ambiguity of the ‘on/off’ service, but it creates a new problem for me. I was using the switch as both the service to toggle on/off and as the sensor to see if it was on/off. In the current state, a locked door has the word UNLOCK and vice versa. This is confusing. I now have to create a sensor to show LOCKED and UNLOCKED. This is still confusing if I have both on the same card.
I think a color change of the locked and unlocked icons would fix this problem for me. The current icons are practically the same at-a-glance. With a color change, like the door and window binary sensors, it would be visually apparent.
I fixed it by renaming my Rachio controller in their app.
Lol, this confused me for a good hour as I couldnt figure out why my door was unlocked.
It is supported in new HassOS https://twitter.com/pvizeli/status/1016720869702455300
I have my Raspberry Pi 3 B+ running Home Assistant in a virtual environment after following the excellent documentation too.
DHT Sensor not working.
2018-07-11 01:26:42 ERROR (SyncWorker_1) [homeassistant.util.package] Unable to install package Adafruit_Python_DHT==1.3.2: Failed building wheel for Adafruit-Python-DHT
Command “/srv/homeassistant/bin/python3.6 -u -c “import setuptools, tokenize;file=’/tmp/pip-install-96kyhhq0/Adafruit-Python-DHT/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-record-t5blsd6_/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.6/Adafruit-Python-DHT” failed with error code 1 in /tmp/pip-install-96kyhhq0/Adafruit-Python-DHT/
2018-07-11 01:26:42 ERROR (MainThread) [homeassistant.requirements] Not initializing sensor.dht because could not install requirement Adafruit_Python_DHT==1.3.2
2018-07-11 01:26:42 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform sensor.dht: Could not install all requirements.
I have a question, to get the layout to show properly can any Jpg be used?
I haven’t made a layout.jpg yet but I have tried to get a picture to show just to experiment with it.
I love the new UI thanks to the devs for the work you all put in!
is it possible to mask the password?
is it possible to submit username & password upon pressing the “enter” key, so you don’t have to use mouse in order to click on the submit button?
Is anyone having problems with google mini being discovered in 0.73.0? I keep getting a “State not available”.
Hi, thanks for the great work!
I currently facing issues with packages for the dht and miflora (bluetooth) couldn’t find a change related to that issue. Does somebody know more about?
