Continue Discussion 319 replies
July 2018
frenck
This is just amazing! Thank you for all the hard work @pvizeli, this is really next level stuff!
July 2018
godinperson
Nice work guys. Migrated my two ResinOS to HassOS and it is working great.
Small issue: https://www.home-assistant.io/hassio/installation/ the link indicates for Rpi3 63-bit. A bit is missing somewhere! :slight_smile:
July 2018
silvrr
pull request submitted to fix this.
The instructions are a bit outdated but anyone (including you!) can submit a pull request on github for the documentation.
July 2018
godinperson
Good to know. Never really understand github, that helps.
July 2018
tottow
Very nice work!
Quick question, which version should I choose? 32 or 64 bit for rpi 3?(non +)
1 reply
July 2018
flamingm0e
both links point to the same file…
1 reply
July 2018
SouzaaThales
Sorry for the noob question, but how can I do it?
1 reply
July 2018
BadHass
Will there be an image for Intel NUC like there is for HASS.IO?
July 2018
DavidFW1960
Is it possible to install this to boot off a USB stick like we can with ResinOS? Or is it possible to have configuration and database on a USB? So then the SD-Card would only contain the OS and HA?
July 2018 ▶ flamingm0e
wackydoo
I also don’t know whether to use 32 or 64 bit for the RPI 3. There is actually a different image for 64 bit RPI on github ( i.e. at https://github.com/home-assistant/hassos/releases ) , even if both RPI links in the announcement point to the same 32 bit release image. I think my old hass.io image is 32 bit FWIW. I believe the ARM V7 on the RPI 3 (non plus) supports 64 bits, but what are the pros and cons. Will all of the addons be available if I select the 64 bit image?
July 2018 ▶ wackydoo
SouzaaThales
I have installed 64 bit version and now I’m getting this error with some add-ons
1 reply
flamingm0e
Home Assistant on hassos runs in docker.
The add-ons don’t care if the host is 32 or 64 bit.
Just install 64bit
July 2018
flamingm0e
Looks like the script is trying to download based on the OS architecture…hmm. That’s not the direction I would have gone with. Lol.
July 2018
Kanishkaz
I’d like to know this too.
July 2018 ▶ SouzaaThales
mbonani
Just add the following to configuration.yaml.
device_tracker:
  - platform: bluetooth_tracker
No add-ons needed.
1 reply
July 2018
ZStanard
I had an issue with snapshots NOT showing up once copied over
when I SSH’d in the command hassio sn reload . got them to appear!
THANKS TO EVERYONE FOR THIS AWESOME SOLUTION!
July 2018
stevemann
That would be HassOS-Lite.:grin:
July 2018
sogood007
So what if I installed my current hass.io through curl -sL https://raw.githubusercontent.com/home-assistant/hassio-build/master/install/hassio_install | bash -s How can I upgrade in that case?
July 2018 ▶ sogood007
DavidFW1960
There’s no upgrade path I can see. Make a snapshot and do a clean install/restore snapshot.
1 reply
July 2018 ▶ DavidFW1960
The upgrade path is the making of a snapshot and restoring it. All your old settings will be restored.
When you install with curl, you are installing Hass.io on your own OS and won’t need HassOS.
1 reply
July 2018 ▶ balloob
talondnb
How do I mount the SD card after flashing so that I can modify the config.txt file? It automounted with the resinOS card but when I plug the newly imaged card into my Mac, it tells me to initialise/eject?
1 reply
July 2018 ▶ talondnb
DavidFW1960
I think the config.txt is still in a fat16 partition and you should be able to mount it. Pretty sure I could on my Windows pc
1 reply
July 2018
Dilby
Could you please explain the rational for moving away from ResinOS to this ? Seems there is a lot of churn with the Home-Assistant OS’s
talondnb
Hmm something must have changed with HassOS as it used to mount the boot partition automatically.
tottow
Let me know what you find out - I’m not getting any smarter on this topic really, specially if 64 bit is giving problems for some addons.
July 2018
adas4190
hi, I have installed HassOs 64bit on my rpi3B and I works great apart of rpi_rf that gives me error:
GPIO.add_event_detect(self.gpio, GPIO.BOTH)
RuntimeError: Failed to add edge detection
I haven’t happened on previous Hassio imaes. Any help??
Thank You
July 2018
Tomahawk
A N00b question…Formatting my old Hassio Sd-card, before installing the new HAssOS, which Linux format should the SD-card be formatted to. Or does Etcher pick the correct format?
July 2018 ▶ Tomahawk
0rn0lf
Etcher is doing everything for you
talondnb
Etcher will format the card correctly.
July 2018
Tomahawk
Backup not displayed in HAssOS?
The install of HassOS went fine. Copied previous HassIO backups to HassOS, and they do not show up in the GUI. Only my newest Test backup made by HassOS is displayed in the GUI. And I have done several restarts of HassOS for hoping this will pick up the old backups.
Looks like I am not able to install my HassIO backup.
Anny ideas?
mories
For me restart was working. Snapshots were available after reboot.
Otherwise install ssh addon, connect and isssue the “hassio snapshots reload” command.
I saw some mentioning this method
lv-88
Did you press the refresh button in top corner?
1 reply
July 2018
lerroy_b
Seconding this request, will there be an image made for NUC please.
thank you
July 2018 ▶ lv-88
Tomahawk
LOL!
The life of a N00b…
Thanks!
July 2018
Aussybob
I have added the VMDK file to my vm and it gets to the HassOS boot menu… I can’t make it autoboot???
am I missing something?
July 2018
braddo
Can you make some comments about HA running on Docker? You mentioned that HassOS will be a Docker host but I already have one of those… (Intel Nuc running Ubuntu Server with Docker). Is HassOS in any way relevant to my setup, I can’t tell? Have ignored HassIO for quite a long time now because I don’t understand why one would care about that either? Is the whole world RasPi now? I used those for a while but upgraded to the Nuc. Seems a ton of effort going into everything except home automation unless I’m missing something fundamental which is entirely possible! I would love more effort on the basics like Bluetooth le, presence detection, detecting and maintaining state so we can automate based on that without writing lots of custom code.
July 2018
talondnb
Can anyone tell me where the previous releases are (resinOS)? I’m not having any luck with this release so would like to revert back.
Right after burning the SD with etcher I get this:
08
I’m expecting to be able to read the boot partition to modify some files before booting but can’t do this anymore with HassOS.
July 2018
Rocksolid
Stuck at Preparing Hass.io for over 30mins.
RPI B+
this is second try.
talondnb
Found the previous resin image and the resin-boot partition mounts fine. I’ll stick with this release for now!
July 2018
ezar
For RPi3 (Not B+), 32 or 64?
Regards,
1 reply
July 2018 ▶ ezar
talondnb
64 should be OK. See how you go…
July 2018
Losgat
not sure if it’s just me but it runs/boots a lot slower than the old ResinOS system.
and getting underVoltage errors very strange
July 2018
nocturne1
It wasn’t documented very well in the post, but you need a separate FAT32 USB stick with a volume name of CONFIG, and the resin-sample file in a “/network/” directory.
Took me a while to figure it out last night, but working fine now.
July 2018 ▶ nocturne1
talondnb
I’m actually trying that right now, if this fails I’ll go back to resin. Man, pretty frustrating not spotting that 5 sd card burns ago…
July 2018
klogg
I don’t know about running slower but I am pretty sure it starts slower.
It was bad enough before but several minutes to restart when making changes to my config is putting me off wanting to change/add/enhance anything! :scream:
Remember to contribute back to the docs to help clarify if something is not clear
1 reply
July 2018
tboyce1
There’s a donation page for purchasing hardware to get a supported build:
1 reply
July 2018
Mr.Art
Hi, guys. I installed a new HassOS on my Raspberry Pi 3B+ and I am a little confused: How should I connect like Pi user now for installing some new features or configurations? e.g. I need to install LIRC, configure CloudMQTT bridge, configure raspi-config, setting up platform rpi_rf, etc. Thanks in advance for yours advices.
1 reply
July 2018
flamingm0e
HassOS is for the pi. It has no bearing on what is going on inside any other OS.
Just use normal Home Assistant Docker.
It sounds an awful lot like you need hassbian.
July 2018
Rocksolid
Anyone clear instruction on how to setup wifi on hassos?
July 2018
Grambo1966
All good so far, thanks for all the hard work your an amazing teamgiphy
July 2018
machine2669
I setup 64bit on rpi b. Everything is ok, except the dht sensor (there was an error since 0.73) and rpi_gpio . Everyone else has the same problem?
1 reply
July 2018
jakobve
3B+ here, boots up and connects to network OK, but connection refused to ip:8123. What can I try?
1 reply
July 2018 ▶ balloob
nocturne1
It actually appears that the correct method (and other updates regarding this new version) got pushed to the Getting Started page already: https://www.home-assistant.io/getting-started/
July 2018
jaalperin
I have been running hass.io on a rpi3B+ with Raspbian Stretch. Webmin and Node-Red are also running.
Conversion to HassOS worked as advertised except that four of thirteen add-ons were not installed. They are all from third parties. One is a local modification found in the Addon directory. Not difficult to fix if you have local backups of the other available Samba directories (share, addon, config, ssl) in addition to backup.
But, the HassOS version seems slower to (re)start than the Raspbian version. So I timed them. The HassOS version consistently takes 4 minutes and 24 seconds to present the UI upon restart. The Raspbian version is ready in 2 minutes and 26 seconds. No errors in either log. Have repeated these results many times.
1 reply
July 2018 ▶ machine2669
talondnb
I had the rpi_gpio issue too. Reverting now back to resin…
Denny_d
same for me…very slow to boot whitout error
July 2018 ▶ tboyce1
lerroy_b
thanks for this I’ll donate now.
July 2018
Mr.Art
I install HassOS to Raspbian Stretch Lite as Docker, but I can not install HA. Hassio folder content has all files, but the “homeassistant” subfolder is empty. Do anyone know, how can I figureout this problem?
root@raspberrypi:~# curl -sL https://raw.githubusercontent.com/home-assistant/hassio-build/master/install/hassio_install | bash -s -- -m raspberrypi3-64
[Info] Install supervisor docker
[Info] Install supervisor startup scripts
[Info] Install AppArmor scripts
[Info] Run Hass.io
I see this, but nothing happens.
1 reply
July 2018
flamingm0e
HassOS IS the OS. You can’t install HassOS IN Docker.
I think you are slightly confused on what HassOS is.
1 reply
Mr.Art
OK, but I have installed that as you advised from official link: [https://github.com/home-assistant/hassio-build/tree/master/install#install-hassio]. It’s probably not the OS but IO :slight_smile:
1 reply
July 2018
ashley-nz
Excellent stuff - nice work. Migrated my system to hassIo 1.5 earlier today.
I hit a corrupt SD card on first attempt, but second attempt on another fresh 16gb class 10 went through fine,
Just has to adjust the DHCP reservation for the new RPI3B+ to match the original IP, and restore in the snapshot - all good using zwave.
Also I had to cut away a little plastic on an existing RPI2B+ case for it to be able to take the rpi3b+ board.
Couple of random questions;
Is the general opinion still that the reliability of the RPI3b+ platform is help back by the reliability of SD cards in general?
July 2018
klogg
Just on the startup time…
Today I restarted and got these warnings:
These first four: it doesn’t seem right to take this long to set up something so simple and I have never seen them before
2018-07-13 07:50:22 WARNING (MainThread) [homeassistant.setup] Setup of group is taking over 10 seconds.
2018-07-13 07:50:22 WARNING (MainThread) [homeassistant.setup] Setup of input_select is taking over 10 seconds.
2018-07-13 07:50:24 WARNING (MainThread) [homeassistant.setup] Setup of input_text is taking over 10 seconds.
2018-07-13 07:50:25 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
This I always used to get so no change:
2018-07-13 07:50:33 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
This I started getting since v0.7x.x (not sure exactly) and I’d really like to know why:
2018-07-13 07:51:44 WARNING (SyncWorker_12) [soco.discovery] Can't make a discovery socket for 92.242.132.15: OSError: [Errno 99] Address not available
And this too is not new but included for completeness:
2018-07-13 07:52:11 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
I’m just adding this info in case it is useful for anyone who might be looking into the slow start-up times
royjustme
Hi I currently boot from a hard drive Don’t have clear access to micro slot as i put it in a combo case. Can I use the USB migrate?
July 2018 ▶ royjustme
DavidFW1960
Well that’s my question as well but no one is answering that question.
July 2018
kjacksonmusic
I have completed the upgrade! Everything seems to be working great Pi 3 B - 64bit image installed.
I only have one issue, binary sensors and device trackers seem to be reporting the opposite information to the histogram, ie if a binary sensor is off, the histogram view shows that it is on…
Also the logbook says there are no entries.
1 reply
July 2018
kanga_who
I tried both the 64 and 32 bit today in 2 different USB thumb drives and neither would Boot, tried an SD card, worked first time. Seems USB boot is an issue.
July 2018 ▶ Mr.Art
Bobby_Nobble
You’re confusing installing hass.IO into Docker running on raspbian with hass.OS which is a complete preconfigured OS with docker and a hass.IO container all in one ready to roll image.
1 reply
July 2018
Mr.Art
No :slight_smile: For some reason I can`t install Hass.IO from this guide “hassio-build/install at master · home-assistant/hassio-build · GitHub” But nothing happens.
[Info] Run Hass.io
For me works only one this installer: GitHub - dale3h/hassio-installer: Hass.io Installer for Raspberry Pi 3 B+ (Raspbian Stretch Lite) from dale3h.
1 reply
July 2018 ▶ kanga_who
Mickael_Selander
anyone got it to boot from a USB drive and not a SD-Card?
1 reply
July 2018 ▶ kjacksonmusic
platup
I have the same issue. I have no logbook and no history.
Everything else seems to be working.
My install was the 64bit on a RPi3.
1 reply
July 2018
ezar
Can I access to boot partition?
1 reply
July 2018 ▶ Mickael_Selander
etique57
Nope.
Just tried on my setup, which worked with resinos, but I couldn’t get it to boot off my USB-connected SSD.
For now I switched back to a SD card (that’s the beauty of the snapshots!)
1 reply
July 2018 ▶ Mr.Art
Bobby_Nobble
That’s actually a ‘yes’ or you wouldn’t have posted in this thread in the first place :roll_eyes:
1 reply
July 2018 ▶ ezar
talondnb
No, you can only provide configuration through an additional USB stick at the moment. See the documentation a few posts above.
July 2018 ▶ platup
kjacksonmusic
do you see anything like this in your log…?
Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'SELECT events.event_id AS events_event_id, events.event_type AS events_event_type, events.event_data AS events_event_data, events.origin AS events_origin, events.time_fired AS events_time_fired, events.created AS events_created \nFROM events LEFT OUTER JOIN states ON events.event_id = states.event_id \nWHERE events.event_type IN (?, ?, ?, ?) AND events.time_fired > ? AND events.time_fired < ? AND (states.last_updated = states.last_changed OR states.state_id IS NULL) ORDER BY events.time_fired'] [parameters: ('state_changed', 'logbook_entry', 'homeassistant_start', 'homeassistant_stop', '2018-07-13 04:00:00.000000', '2018-07-14 04:00:00.000000')] (Background on this error at: http://sqlalche.me/e/4xp6)
if so delete the “home_assistantv2” database file in /config (or cut it somewhere else) and restart, should be back to normal. :ok_hand:
That being said, you will loose your logbook history as you are deleting or removing the file that holds it all…
platup
Yes, thank you. That did fix it for me.
July 2018
Chris8837
I have installed this 5 times now. Everytime I edit the configurator.yaml file and reboot it gets stuck. I can’t access anymore. No one else is having this issue? I can play around and add samba ssh mosquito. But as soon as I edit anything in the configurator and reboot the system doesn’t connect?
1 reply
July 2018 ▶ Chris8837
DavidFW1960
Are you doing a configuration check before rebooting? How are you rebooting.
1 reply
July 2018
ezar
How I access to boot partition?
We want to add gpio.
My problem:
2018-07-13 21:18:55 ERROR (SyncWorker_9) [homeassistant.components.sensor.onewire] No onewire sensor found. Check if dtoverlay=w1-gpio is in your /boot/config.txt. Check the mount_dir parameter if it’s defined
July 2018
JoRoCoBo
DuckDNS with Ngnix not working
I’m running the DuckDNS and Nginx addons together, and I’m no longer able to connect through to HA from the DuckDNS domain. My configs were recreated from a snapshot when I migrated to HassOS so there shouldn’t have been an issue there. Since then I’ve deleted and re-added both of them but still no luck. Is there anything additional I need to do to integrate with the new security features in HassOS?
Thanks,
July 2018 ▶ etique57
etique57
OK for some reason, with both a SD and the USB-SSD, I eventually end up loading the Hassio instance from the SSD, so all good.
1 reply
DavidFW1960
HassOS? How did you get it to work?
1 reply
etique57
Honnestly I don’t really know.
Here’s what I did:
1 reply
DavidFW1960
If you unplug the SD-Card and reboot does it boot and work?
1 reply
etique57
Nope, doesn’t work without the SD. It did with HassIO.
I need the SD in, and then it boots and seems to switch properly on the USB-SSD.
1 reply
DavidFW1960
Yes so it’s still booting from the SD-Card. I suspect it’s running fully off the SD-Card. The USB seems to only be used to transfer files from the docs.
What happens if you do remove the USB and re-boot the Pi? I bet everything still works.
1 reply
etique57
I can confirm this a bit later but it seems to be eating the disk space of the SSD (went from 2.3GB used to 2.7 after a few hours of logging on MariaDB). I’ll try what you say though.
1 reply
DavidFW1960
Well if it is writing to SSD that would be good news… makes the SD-Card like a read only ROM… if the yaml files are there as well anyway…
1 reply
July 2018 ▶ Aussybob
Tinkerer Solution Institution
I get the same problem, so it’s not just you. I haven’t raised an issue yet though, simply because I was just doing it for playing with.
(VirtualBox 5.1 in my case)
1 reply
Chris8837
I’m brand new to this. But I setup a few switches and are playing around currently. My last setup the SD card crashed and I didn’t have a backup. So what I’ve learned Im starting brand new again. All I did was copy the few lines at the bottom and move them up to organize. Then to test I rebooted. When I refresh the screen it defaults back to setup then can’t connect. Then setup then can’t connect in a continuous loop. I’m setting this up exactly like I did before.
The only one I’m touching is the config.yaml file right now.
(I just tried going back to resinos 1.3 and it’s working perfectly)
July 2018 ▶ mbonani
SouzaaThales
Isn’t working
1 reply
July 2018
willsy555
I’ve installed the new hassos on a pi3b+. Everything is working perfectly apart from videos from my two ffmpeg cameras.
I just get a title bar for them and no image.
Anyone else having problems with ffmpeg?
Cheers
Will
1 reply
July 2018
JtotheDub77
Trying to restart/rebuild my system from the ground up today, figured I’d go with the new 64-bit image… got it up and running fine but once I performed DuckDNS setup using this written guide as help: https://www.juanmtech.com/hassio-duckdns-add-on-set-up/ I’m getting no UI at all now. Can’t even access via https://local_ip:8123 getting a “Corrupted Content Error” when I try to reach the UI via the local IP. I can see the config files via Samba Share and have a bunch of errors. When I performed the initial DuckDNS setup inside the UI the log there said everything worked fine. Here’s the HA log I’m getting after rebooting and updating my configuration.yaml with the info mentioned in step 3 of the guide:
2018-07-14 23:23:44 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2018-07-14 23:23:57 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
  File "uvloop/sslproto.pyx", line 593, in uvloop.loop.SSLProtocol._on_handshake_complete
  File "uvloop/sslproto.pyx", line 171, in uvloop.loop._SSLPipe.feed_ssldata
  File "/usr/lib/python3.6/ssl.py", line 689, in do_handshake
    self._sslobj.do_handshake()
ssl.SSLError: [SSL: HTTP_REQUEST] http request (_ssl.c:777)
2018-07-14 23:23:57 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
  File "uvloop/sslproto.pyx", line 497, in uvloop.loop.SSLProtocol.data_received
  File "uvloop/sslproto.pyx", line 204, in uvloop.loop._SSLPipe.feed_ssldata
2018-07-14 23:23:58 ERROR (zeroconf-Engine) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-14 23:24:10 ERROR (MainThread) [homeassistant.components.device_tracker] Unable to load /config/known_devices.yaml: Config file not found: /config/known_devices.yaml
2018-07-14 23:24:18 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2018-07-14 23:24:18 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
2018-07-14 23:24:18 ERROR (SyncWorker_13) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-14 23:24:48 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2018-07-14 23:24:48 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
2018-07-14 23:25:49 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: SSLV3_ALERT_BAD_CERTIFICATE
  File "uvloop/sslproto.pyx", line 182, in uvloop.loop._SSLPipe.feed_ssldata
  File "/usr/lib/python3.6/ssl.py", line 633, in read
    v = self._sslobj.read(len)
ssl.SSLError: [SSL: SSLV3_ALERT_BAD_CERTIFICATE] sslv3 alert bad certificate (_ssl.c:2217)
2018-07-14 23:25:50 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: SSLV3_ALERT_BAD_CERTIFICATE
1 reply
July 2018
seiken
Please give us a nuc image!
//Regards
July 2018 ▶ JtotheDub77
JoRoCoBo
I’ve just managed to get this running using the DuckDNS and Nginx addons and if you follow that route you’ll end up with a HA that can be accessed both externally and with a local IP address, and it’s a much simpler process to set up. For some reason after the update to HassOS i had to remove both of those addons, restart, then add them back in again.
Just remember that if you go with Nginx, you’ll need to have a single port forwarding rule that maps port 443 to port 443 on the IP address of your HassOS server (say your Raspberry Pi).
1 reply
July 2018 ▶ JoRoCoBo
JtotheDub77
Thanks, I actually just barely realized what I was doing wrong so PSA to anyone looking to “restart” like I did… need to use a new DuckDNS account to get a new Token, I was getting tons of errors because I was using the same token as my previous install, once I setup a new DuckDNS everything works fine. I will need to do some reading up on the Nginx after I get come of my basic functions re-built.
July 2018
nickrout Solution Institution
Please read the thread
1 reply
July 2018
frits1980
Don’t know if I have to post this here or start a new thread. Have hassOS on Rpi3B. Bluetooth tracker enabled but known devices never changes. No mention about it in any log. Any ideas?
