Editing the Documentation and Creating a Pull Request on Github
It is easy to help keep our documentation up to date and it is a simple way you can contribute to the Home Assistant project.
First go to https://github.com/ and sign up for an account. Its quick free and easy. Sign up and sign in.
At the bottom of every documentation page there is an Edit button for you to click.
When you click that link you will be brought to a new page with contents of the page you wanted to edit. In the upper right there is a pencil icon, click it to edit the page.
On the resulting page you can edit the text. Use the existing content and reference the existing page for figuring out how to edit the content. Usually the page just needs some tweaking so you don’t need to start over, just add on or delete some text.
If you are making a large change/new page be sure to read the documentation standards before getting started. See: Standards | Home Assistant Developer Docs
When you are done, click the green Commit changes button.
Then fill in some detail about your change in the pop-up window and click the green Propose changes button
On the next page, click the green Create Pull Request button
On the next page add any additional comments and fill out the two checklists. Then click green Create Pull Request button.
You’re Done! You just submitted your first pull request and contributed to improving Home Assistant!
If this is your first time submitting you likely will need to sign the CLA. This is easy to do and you will either brought straight to it or receive an e-mail to complete this step. Its as simple as reading and clicking another box.
From here you will get an e-mail stating that your pull request was submitted and it will identify some reviewers based on who has worked on the page in the past. You will continue to get e-mails with updates on the status as needed. Eventually you will get one that it has been merged and your changes will go live sometime after.
If all of this seems too much then click the feedback link at the bottom of the documentation page instead and provide details of what you think needs fixing.
You will need a github account for this too (see top of this guide).
The Home Assistant Cookbook - Index
How to update documentation
General thoughts on (getting started with) HA (hassbian)
Zwave instruction are incorrect
Getting nmap to work on windows and also able to detect an android phone
Searchable Home Assistant site
Xiaomi Yeelight E27 bulb component
Mqtt "this integration has no devices" with tasmota connected to add-on broker
New Hass.io images, based on HassOS
RESTful Switch Documentation is wrong
New YeeLight 2 (white) aka YLDP05YL is supported
Remote VLC remote controller (via telnet)
Entity Button Card and call-service modbus.write_register
Error in Garadget docs?
Someone Please Update Snips.AI Help Pages
Updater component not working, what am I doing wrong?
Request re documentation
Specifying configuration manually in configuration.yaml
Cannot Access pi-hole
Automation condition - if a state of an entity hasn't changed
WTH should integrations usage and their technology be documented?
Hacktoberfest 2020
Enocean Temperature A5-04-01 wrong readings
Beginner friendly documentation
The future of YAML
Use apt-get commands
How did you install Home Assistant?
Improving HA documentation?
How do I format the sent brightness command in MQTT?
Integrations Pages Are Becoming Less Layperson Friendly
Badges and State-Label
Running a script or command every 5 minutes
EXECUTE not ACTIVATE?
Tasmota Autodiscovery Not Working
MQTT User Config
WTH is there no consistent documentation concept?
Documentation for functions and operations?
And condition with a single child not working
Google tts docs seems very inaccurate
Home Assistant Knowledge Base
Confusing Documentation for x86 install
Home Assistant Cookbook - Discussion Thread
Script Returning Empty List Despite Matching Sensors
The impact of HA's technical evolution on underlying reference data
MQTT Light with RGB and brightness - how to get the RGB value?
Workday sensor - remove_holiday not working
Improve documentation of components
Raspberry pi gpipo how to?
Hass user password
Suggestions for improving HA documentation
Broadlink RM-PRO and TC2 switch
Automation Old and New
Network In for systemmonitor in windows not working
Great, I think that would be great to have in documentation
I agree. This is just the sort of thing that we needed to have written up. Excellent work, @silvrr!
@Danielhiversen - I’m not sure if you realized the meta joke you just made. :laughing: Wouldn’t adding this to the documentation be roughly the same process?
@silvrr - Thanks so much for this!
Great example of why everyone needs to submit pull requests. In making this little tutorial I made a few tweaks to the yeelight component as shown above to provide the example. As I was paying more attention to making the tutorial than the config example there were errors in it. (spacing and and a missed colon :flushed:)
@LeeJS to save the day! He submitted a Pull Request and fixed the errors which should go live shortly. This just goes to show that we need everyone to be helping with the documentation. Also I need to focus on one thing at a time so I don’t make people frustrated with my config errors. (Sorry @LeeJS)
My pleasure!
This is great. I have lots of my own documents I’ve stored at home which I’ve used to record how I’ve setup some zwave specific devices so I’ll see about moving them here.
one picture is not loading
Thanks, I think this needs an update anyway. Added to my todo list.
Might want to add what to do if you have clicked “Propose file change”, but then notice something needs to be changed (say I noticed a mistake in my edit), prior to clicking “Create pull request”.
In other words, go back to editing before creating the pull request.
OK, I updated the first post with the current workflow. I wasn’t getting this done so I did it as I was making an edit and noticed an issue.
Future items to add:
  1. Creating a github account?
  2. CLA signing process?
  3. Editing after you have clicked “Propose file change”
If anyone is going through the steps and wants to post the steps/screenshots I will either add them to my post or link to your post.
You can edit them but the changes need to be approved and merged. It’s not the wild Wild West.
Thanks just created my first edit
…and it was rejected for being classed as duplicating an existing example.
There will be no Hello World code snippets in this documentation :crazy_face:
Updated December 2024.
The link to the documentation standards in the original post seems to have gone 404. After a little research I think that
https://developers.home-assistant.io/docs/en/documentation_standards.html
should be
https://developers.home-assistant.io/docs/documenting/standards/
You can fix it:
