Anyone else seeing an issue with the local todo list? Since the upgrade all my todo list items got removed and Iām getting the below error in the logs. If i try and recreate the items on the list they donāt get created when i click the add button. But if i open the file config.storage\local_todo.ha_actions.ics i see the items in there
Logger: homeassistant.components.todo
Source: helpers/entity_platform.py:350
integration: To-do list (documentation, issues)
First occurred: 09:25:06 (1 occurrences)
Last logged: 09:25:06
Error while setting up local_todo platform for todo
File "/usr/local/lib/python3.12/site-packages/ical/component.py", line 139, in __init__
super().__init__(**data)
File "/usr/local/lib/python3.12/site-packages/pydantic/main.py", line 341, in __init__
raise validation_error
pydantic.error_wrappers.ValidationError: 1 validation error for Todo
__root__
Failed to validate: 20240307T083444, errors: (["Expected DATE-TIME TZID value '+08' to be valid timezone", "Expected value to match DATE pattern: '20240307T083444'"]) (type=value_error)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 350, in _async_setup_platform
await asyncio.shield(awaitable)
File "/usr/src/homeassistant/homeassistant/components/local_todo/todo.py", line 71, in async_setup_entry
calendar = IcsCalendarStream.calendar_from_ics(ics)
File "/usr/local/lib/python3.12/site-packages/ical/calendar_stream.py", line 82, in calendar_from_ics
stream = cls.from_ics(content)
File "/usr/local/lib/python3.12/site-packages/ical/calendar_stream.py", line 69, in from_ics
return cls(**result)
File "/usr/local/lib/python3.12/site-packages/pydantic/main.py", line 339, in __init__
values, fields_set, validation_error = validate_model(__pydantic_self__.__class__, data)
File "/usr/local/lib/python3.12/site-packages/pydantic/main.py", line 1076, in validate_model
v_, errors_ = field.validate(value, values, loc=field.alias, cls=cls_)
File "/usr/local/lib/python3.12/site-packages/pydantic/fields.py", line 895, in validate
v, errors = self._validate_sequence_like(v, values, loc, cls)
File "/usr/local/lib/python3.12/site-packages/pydantic/fields.py", line 928, in _validate_sequence_like
r, ee = self._validate_singleton(v_, values, v_loc, cls)
File "/usr/local/lib/python3.12/site-packages/pydantic/fields.py", line 1094, in _validate_singleton
value, error = field.validate(v, values, loc=loc, cls=cls)
File "/usr/local/lib/python3.12/site-packages/pydantic/fields.py", line 884, in validate
v, errors = self._validate_singleton(v, values, loc, cls)
File "/usr/local/lib/python3.12/site-packages/pydantic/fields.py", line 1101, in _validate_singleton
return self._apply_validators(v, values, loc, cls, self.validators)
File "/usr/local/lib/python3.12/site-packages/pydantic/fields.py", line 1157, in _apply_validators
v = validator(cls, v, values, self, self.model_config)
File "/usr/local/lib/python3.12/site-packages/pydantic/class_validators.py", line 337, in <lambda>
return lambda cls, v, values, field, config: validator(v)
File "/usr/local/lib/python3.12/site-packages/pydantic/main.py", line 711, in validate
return cls(**value)
return cls(**value)
File "/usr/local/lib/python3.12/site-packages/ical/todo.py", line 203, in __init__
File "/usr/local/lib/python3.12/site-packages/ical/component.py", line 141, in __init__
raise CalendarParseError(f"Failed to parse component: {err}") from err
ical.exceptions.CalendarParseError: Failed to parse component: 1 validation error for Todo
__root__
