Hi
the problem is that after booting my esp32 the voltage is 0.0000 Volt at adc pin 34. so measurement is not working. if i disconnect and reconnect the adc pin the measurement works and i get realistic values.
my sensor is running with 24volts. i use a step up to get the voltage.
whats the problem of my setup?
substitutions:
device_name: test_spannug
device_description: test
friendly_name: Zisterne Füllstand
esphome:
comment: ${device_description}
platform: ESP32
board: nodemcu-32s
#on_boot:
# then:
# - delay: 1s
# - switch.turn_on: relay
#- delay: 9s
#- switch.turn_off: relay
wifi:
ssid: !secret wifi_ssid
fast_connect: true
manual_ip:
static_ip: 192.168.1.99
gateway: 192.168.1.1
subnet: 255.255.255.0
#mqtt:
# broker: 192.168.1.43
#port: 1883
#username: openhabian
#password: openhabian
#birth_message:
#will_message:
#discovery: True
#on_message:
#- topic: zisterne/ota_mode
# payload: 'ON'
# then:
# - deep_sleep.prevent: deep_sleep_1
#- topic: zisterne/sleep_mode
# payload: 'ON'
# then:
# - deep_sleep.enter: deep_sleep_1
captive_portal:
# Enable logging
logger:
level: debug
ota:
api:
web_server:
port: 80
switch:
- platform: restart
- platform: adc
pin: GPIO34
update_interval: 1s
attenuation: 11db
