also facing same problems to upgrade to 0.101.3 from version 1.00.3, removed api_password, did not help.
I added addon that checks config and got this output.
[22:36:44] INFO: Checking your configuration against this version...
[22:44:46] ERROR: The configuration check did not pass!
[22:44:46] ERROR: See the output below for more details.
INFO:homeassistant.util.package:Attempting install of colorlog==4.0.2
Testing configuration at /tmp/config
INFO:homeassistant.util.package:Attempting install of home-assistant-frontend==20191025.1
INFO:homeassistant.util.package:Attempting install of aiohttp_cors==0.7.0
INFO:homeassistant.util.package:Attempting install of hbmqtt==0.9.5
INFO:homeassistant.util.package:Attempting install of paho-mqtt==1.4.0
INFO:homeassistant.util.package:Attempting install of RPi.GPIO==0.7.0
INFO:homeassistant.util.package:Attempting install of librouteros==2.3.0
INFO:homeassistant.util.package:Attempting install of construct==2.9.45
INFO:homeassistant.util.package:Attempting install of python-miio==0.4.6
INFO:homeassistant.util.package:Attempting install of pyatmo==2.3.2
INFO:homeassistant.util.package:Attempting install of python-forecastio==1.4.0
INFO:homeassistant.util.package:Attempting install of pychromecast==4.0.1
INFO:homeassistant.util.package:Attempting install of pywebpush==1.9.2
INFO:homeassistant.util.package:Attempting install of wakeonlan==1.1.6
INFO:homeassistant.util.package:Attempting install of broadlink==0.12.0
INFO:homeassistant.util.package:Attempting install of hikvision==0.4
ERROR:homeassistant.scripts.check_config:BURB
File "/usr/local/lib/python3.7/site-packages/homeassistant/scripts/check_config.py", line 206, in check
async_check_ha_config_file(hass)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 579, in run_until_complete
return future.result()
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/check_config.py", line 140, in async_check_ha_config_file
p_validated = component_platform_schema(p_config)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 205, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 285, in _exec
v = func(path, v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
return schema(data)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/scene/__init__.py", line 46, in _platform_validator
return platform.PLATFORM_SCHEMA(config)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 386, in validate_mapping
cval = cvalue(key_path, value)
v = func(path, v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 635, in validate_sequence
cval = validate(index_path, value)
v = func(path, v)
return schema(data)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/homeassistant/scene.py", line 37, in _convert_states
if isinstance(states[entity_id], dict):
KeyError: 'light.kitchen_led'
Fatal error while loading config: 'light.kitchen_led'
Failed config
General Errors:
- 'light.kitchen_led'
Successful config (partial)
General Errors:
config is:
- platform: mqtt
state_topic: "stat/son-kitchenled/RESULT"
command_topic: "cmnd/son-kitchenled/POWER"
state_value_template: "{{ value_json.POWER }}"
brightness_state_topic: "stat/son-kitchenled/RESULT"
brightness_command_topic: "cmnd/son-kitchenled/Dimmer"
brightness_scale: 100
brightness_value_template: "{{ value_json.Dimmer }}"
retain: false
qos: 1
payload_on: "ON"
payload_off: "OFF"
I really dont see whats wrong with kitchen_led light here, as there are similar lights in the config. Or maybe there is different problem…
Commented out the light, now error changed to
General Errors:
- module ‘aiohttp’ has no attribute ‘web’
