0.101: Airly, Apprise, Sinch, Solar-Log, Microsoft Teams
try from integration pageas its simpliest
If youā€™re using hass.io and the addon as the broker you donā€™t need any config in configuration.yaml at allā€¦
Thanks, just a last question. Is the syntax correct also for one light controlled by mqtt?
  - platform: mqtt
    name: "Faretti Ingresso"
    command_topic: "cmnd/sonoff-01/power"
    state_topic: "stat/sonoff-01/POWER"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    payload_available: "Online"
    payload_not_available: "Offline"
    retain: true
No, using hassbianā€¦
just one thing at a time, just get broker setup correctly first
Oh yes, i as only asking to enable after all is checked and working.
Oh, yeah. I forgot about the integrations UI. That configuration method makes troubleshooting these kinds of issues a bit more complicated.
Iā€™ll have to try to remember that for the next time.
Is there a way to know when if/when the 0.101.4 milestone will be released? There are some fixes in there I am anxiously awaiting.
I wouldnā€™t expect to see a version 0.101.4 given that 0.102.0 is to be released tomorrow
The August integration is broken for me with 0.101.3.
Invalid config
The following components and platforms could not be set up:
* [august](https://home-assistant.io/integrations/august/)
Please check your config.
2019-11-18 21:26:02 ERROR (MainThread) [homeassistant.setup] Error during setup of component august
  File "/usr/src/homeassistant/homeassistant/setup.py", line 176, in _async_setup_component
    component.setup, hass, processed_config  # type: ignore
  File "/usr/src/homeassistant/homeassistant/components/august/__init__.py", line 170, in setup
    return setup_august(hass, config, api, authenticator)
  File "/usr/src/homeassistant/homeassistant/components/august/__init__.py", line 119, in setup_august
    hass.data[DATA_AUGUST] = AugustData(hass, api, authentication.access_token)
  File "/usr/src/homeassistant/homeassistant/components/august/__init__.py", line 181, in __init__
    self._doorbells = self._api.get_doorbells(self._access_token) or []
  File "/usr/local/lib/python3.7/site-packages/august/api.py", line 146, in get_doorbells
    access_token=access_token).json()
  File "/usr/local/lib/python3.7/site-packages/august/api.py", line 296, in _call_api
    response.raise_for_status()
  File "/usr/local/lib/python3.7/site-packages/requests/models.py", line 940, in raise_for_status
    raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 401 Client Error: Unauthorized for url: https://api-production.august.com/users/doorbells/mine
2019-11-18 21:26:18 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
Have you checked you login details for august or deleted the token
That worked. Thanks
