It does not upgrade to 101.2 from 100.3
2019-11-02 22:26:57 ERROR (MainThread) [homeassistant.setup] Error during setup of component yeelight
File "/usr/src/homeassistant/homeassistant/setup.py", line 176, in _async_setup_component
component.setup, hass, processed_config # type: ignore
concurrent.futures._base.CancelledError
2019-11-02 22:26:57 ERROR (MainThread) [homeassistant.setup] Error during setup of component api
2019-11-02 22:26:57 ERROR (MainThread) [homeassistant.components.alarm_control_panel] Error while setting up platform bwalarm
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 150, in _async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 435, in wait_for
await waiter
2019-11-02 22:26:57 ERROR (MainThread) [homeassistant.setup] Error during setup of component shopping_list
File "/usr/src/homeassistant/homeassistant/setup.py", line 172, in _async_setup_component
File "/usr/src/homeassistant/homeassistant/components/shopping_list/__init__.py", line 87, in async_setup
yield from data.async_load()
File "/usr/src/homeassistant/homeassistant/components/shopping_list/__init__.py", line 171, in async_load
self.items = yield from self.hass.async_add_job(load)
2019-11-02 22:26:57 ERROR (MainThread) [homeassistant.components.deconz] Error connecting with deCONZ gateway
2019-11-02 22:26:57 ERROR (MainThread) [homeassistant.setup] Error during setup of component group
File "/usr/local/lib/python3.7/asyncio/runners.py", line 43, in run
return loop.run_until_complete(main)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 579, in run_until_complete
return future.result()
File "/usr/src/homeassistant/homeassistant/__main__.py", line 302, in setup_and_run_hass
log_no_color=args.log_no_color,
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 146, in async_from_config_file
config_dict, hass, enable_log=False, skip_pip=skip_pip
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 91, in async_from_config_dict
await _async_set_up_integrations(hass, config)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 372, in _async_set_up_integrations
*(async_setup_component(hass, domain, config) for domain in domains_to_load)
File "/usr/src/homeassistant/homeassistant/setup.py", line 51, in async_setup_component
return await task # type: ignore
File "/usr/src/homeassistant/homeassistant/setup.py", line 147, in _async_setup_component
hass, config, integration
File "/usr/src/homeassistant/homeassistant/config.py", line 736, in async_process_component_config
p_validated = component_platform_schema(p_config)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 205, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 285, in _exec
v = func(path, v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
return schema(data)
File "/usr/src/homeassistant/homeassistant/components/scene/__init__.py", line 46, in _platform_validator
return platform.PLATFORM_SCHEMA(config)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 386, in validate_mapping
cval = cvalue(key_path, value)
v = func(path, v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 635, in validate_sequence
cval = validate(index_path, value)
v = func(path, v)
return schema(data)
File "/usr/src/homeassistant/homeassistant/components/homeassistant/scene.py", line 37, in _convert_states
if isinstance(states[entity_id], dict):
KeyError: 'group.ceiling_lights'
File "/usr/src/homeassistant/homeassistant/components/group/__init__.py", line 216, in async_setup
await _async_process_config(hass, config, component)
File "/usr/src/homeassistant/homeassistant/components/group/__init__.py", line 373, in _async_process_config
mode=mode,
File "/usr/src/homeassistant/homeassistant/components/group/__init__.py", line 488, in async_create_group
await component.async_add_entities([group], True)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 252, in async_add_entities
await asyncio.wait(tasks)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 389, in wait
return await _wait(fs, timeout, return_when, loop)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 482, in _wait
await waiter
2019-11-02 22:26:57 ERROR (MainThread) [homeassistant.setup] Error during setup of component config
v = func(path, v)
return schema(data)
v = func(path, v)
v = func(path, v)
return schema(data)
