0.101: Airly, Apprise, Sinch, Solar-Log, Microsoft Teams
There is no .101.3… 0.101.2 just was released
Fixed the typo.
I had similar message 5 times (different image). The 6th time it worked. I guess there were connectivity issues.
I’ve tried like 15 times with same results. But looking at the comments in the thread, I’ll be better off holding the upgrade as I don’t have time to troubleshoot if anything fails. Guess I’ll try again in couple of days.
You can see the available builds here:
https://hub.docker.com/r/homeassistant/qemux86-64-homeassistant/tags
If I see a build there I can always update to it via ssh
hassio ha update --version=0.101.2
as an example
I did find it in docker hub but the versions json shows 101.1 as the stable image for qemux86-64. I’ll try updating via ssh in the morning.
give it an hour and the version json will catch up…
Telegram bot not working thru Proxy since 0.101
Had to Manually install PySocks in container…
Fix already proposed and even merged…why it’s still not in release? stupid situation
Oh, that is helpful.
Not helpful, but not unhelpful. Just venting.
The PR was merged and asked to be added to next minor update 2+ days ago, then locked 12 hours ago.
But not included in 101.2 which was released 4 hours ago (To be fair, it was submitted 7 hours ago).
Hopefully it will be included in 101.3, but I understand @to4ko’s frustration if this was a critical integration to him.
Yes I know, but at least he had a solution :slight_smile:
for the reference - it’s not about myself but all the user (not lunix gurus or admins) had to run it thru proxy…
I’m having the same issue. I’m running in docker and have tried 0.101.0, 0.101.1, 0.101.2 but they all have the same issue.
The front end does not load and there are lots of errors in the log file.
I’ve rolled back to 0.100.3 each time and that always works.
Extract of the log files from 0.101.2 just now:
2019-11-02 18:23:30 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification
2019-11-02 18:23:30 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds.
2019-11-02 18:23:30 INFO (SyncWorker_10) [homeassistant.loader] Loaded auth from homeassistant.components.auth
2019-11-02 18:23:32 INFO (MainThread) [homeassistant.setup] Setting up homeassistant
2019-11-02 18:23:32 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds.
2019-11-02 18:23:32 INFO (SyncWorker_12) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
2019-11-02 18:23:32 INFO (SyncWorker_7) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2019-11-02 18:23:32 INFO (SyncWorker_3) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
2019-11-02 18:23:32 INFO (MainThread) [homeassistant.bootstrap] Setting up {'system_log', 'logger'}
2019-11-02 18:23:32 INFO (MainThread) [homeassistant.setup] Setting up logger
2019-11-02 18:24:23 ERROR (MainThread) [homeassistant.setup] Error during setup of component person
  File "/usr/src/homeassistant/homeassistant/setup.py", line 172, in _async_setup_component
    hass, processed_config
  File "/usr/src/homeassistant/homeassistant/components/person/__init__.py", line 283, in async_setup
    await manager.async_initialize()
  File "/usr/src/homeassistant/homeassistant/components/person/__init__.py", line 117, in async_initialize
    raw_storage = await self.store.async_load()
  File "/usr/src/homeassistant/homeassistant/helpers/storage.py", line 99, in async_load
    return await self._load_task
concurrent.futures._base.CancelledError
2019-11-02 18:24:23 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform smartir
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 150, in _async_setup_platform
    await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 435, in wait_for
    await waiter
2019-11-02 18:24:23 ERROR (MainThread) [homeassistant.setup] Error during setup of component api
  File "/usr/src/homeassistant/homeassistant/setup.py", line 176, in _async_setup_component
    component.setup, hass, processed_config  # type: ignore
2019-11-02 18:24:23 ERROR (MainThread) [homeassistant.setup] Error during setup of component group
  File "/usr/local/lib/python3.7/asyncio/runners.py", line 43, in run
    return loop.run_until_complete(main)
  File "/usr/local/lib/python3.7/asyncio/base_events.py", line 579, in run_until_complete
    return future.result()
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 302, in setup_and_run_hass
    log_no_color=args.log_no_color,
  File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 146, in async_from_config_file
    config_dict, hass, enable_log=False, skip_pip=skip_pip
  File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 91, in async_from_config_dict
    await _async_set_up_integrations(hass, config)
  File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 372, in _async_set_up_integrations
    *(async_setup_component(hass, domain, config) for domain in domains_to_load)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 51, in async_setup_component
    return await task  # type: ignore
  File "/usr/src/homeassistant/homeassistant/setup.py", line 147, in _async_setup_component
    hass, config, integration
  File "/usr/src/homeassistant/homeassistant/config.py", line 736, in async_process_component_config
    p_validated = component_platform_schema(p_config)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 272, in __call__
    return self._compiled([], data)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 205, in _run
    return self._exec(self._compiled, value, path)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 285, in _exec
    v = func(path, v)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
    return schema(data)
  File "/usr/src/homeassistant/homeassistant/components/scene/__init__.py", line 46, in _platform_validator
    return platform.PLATFORM_SCHEMA(config)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
    return base_validate(path, iteritems(data), out)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 386, in validate_mapping
    cval = cvalue(key_path, value)
    v = func(path, v)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 635, in validate_sequence
    cval = validate(index_path, value)
    v = func(path, v)
    return schema(data)
  File "/usr/src/homeassistant/homeassistant/components/homeassistant/scene.py", line 37, in _convert_states
    if isinstance(states[entity_id], dict):
KeyError: 'group.livingroom'
  File "/usr/src/homeassistant/homeassistant/components/group/__init__.py", line 216, in async_setup
    await _async_process_config(hass, config, component)
  File "/usr/src/homeassistant/homeassistant/components/group/__init__.py", line 373, in _async_process_config
    mode=mode,
  File "/usr/src/homeassistant/homeassistant/components/group/__init__.py", line 488, in async_create_group
    await component.async_add_entities([group], True)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 252, in async_add_entities
    await asyncio.wait(tasks)
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 389, in wait
    return await _wait(fs, timeout, return_when, loop)
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 482, in _wait
    await waiter
2019-11-02 18:24:27 ERROR (MainThread) [homeassistant.setup] Error during setup of component input_select
    v = func(path, v)
    return schema(data)
    v = func(path, v)
    v = func(path, v)
    return schema(data)
  File "/usr/src/homeassistant/homeassistant/components/input_select/__init__.py", line 114, in async_setup
    await component.async_add_entities(entities)
    await waiter
2019-11-02 18:24:27 ERROR (MainThread) [homeassistant.setup] Error during setup of component alarm_control_panel
    v = func(path, v)
    return schema(data)
    v = func(path, v)
    v = func(path, v)
    return schema(data)
  File "/usr/src/homeassistant/homeassistant/components/alarm_control_panel/__init__.py", line 46, in async_setup
    await component.async_setup(config)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 121, in async_setup
    await waiter
2019-11-02 18:24:28 ERROR (MainThread) [homeassistant.components.alarm_control_panel] Error while setting up platform manual
    v = func(path, v)
    return schema(data)
    v = func(path, v)
    v = func(path, v)
    return schema(data)
    await waiter
2019-11-02 18:24:28 ERROR (MainThread) [homeassistant.setup] Error during setup of component climate
Understood, fair enough.
Solved this by using the Integration and enabling the ‘Floor Temperature’ option and restarting. You can disable it afterwards.
Can you help me correct? I do not know how to do.
Hi community,
anyone having issues with device tracker “fritz” platform in 0.101.x?
All of my devices appear as “not_home”, even though they are shown as active in FritzBOX.
Anmerkung%202019-11-02%20184905
Anmerkung%202019-11-02%20184909
The one thing looking odd to me ist the “source_type: null” attribute.
Im currenttly running 0.101.2 in Docker (on Ubuntu/NUC).
My current config:
device_tracker:
  - platform: fritz
    username: !secret fb_user
    password: !secret fb_password
    new_device_defaults:
      track_new_devices: false
      hide_if_away: false
Any hint would be appreciated.
THX! Kai
Anyone using HTTP shortcut Android APP?
How to use the token now that in 101 is not possible to append password in the POST URL?
My fritz is still working.
Is there a replacing sensor for Ikea Tradfri Blinds? Button remotes etc. are now represented as battery entities, but I can no longer find the battery status for the blinds.
