0.102: Official Android App, Almond, Scene editor
Well thanks for doing my homework for me! That is exactly the behaviour I’d like to see in the UI. But I guess Mick said it best - you can’t always get what you want!
Well… that was a disaster!
I ended up with a BUNCH of switches and lights I DON’T want exposed… exposed…
That makes NO SENSE
This kind of reminds me of the BS I went through before… So I’m adding back the
exposed_domains:
  - input_boolean
So it seems unless I have 1 exposed domain as per the above it will then add all sorts of other spurious shit to Google Assistant I don’t want. I think I might raise a new issue about this.
This is my ‘final’ google yaml
# Google Assistant
project_id: !secret ga_project
api_key: !secret api-ga
exposed_domains:
  - input_boolean
entity_config:
  light.lounge:
    room: lounge room
    expose: true
  light.dining:
    room: dining room
    expose: true
  light.office:
    room: office
    expose: true
  light.desk:
    room: office
    expose: true
  switch.sonoff12914:
    room: kitchen
    expose: true
  switch.sonoff23110:
    room: bathroom
    expose: true
  switch.sonoff51083:
    room: house
    expose: true
  switch.sonoff63719:
    room: house
    expose: true
  input_boolean.homeandawayauto:
    room: house
    expose: true
  input_boolean.alarmgaragedoor:
    room: house
    expose: true
  input_boolean.overtime:
    room: kitchen
    expose: true
  input_boolean.holiday:
    room: kitchen
    expose: true
  sensor.nodemcu_lounge_bme280_temperature:
    room: lounge room
    name: Lounge Temperature
    expose: true
  sensor.sonoff1_2914_si7021_temperature:
    room: meals area
    name: Meals Area Temperature
    expose: true
  sensor.bom_gosford_air_temp_c:
    room: house
    name: Outside Temperature
    expose: true
  script.bedtime:
    room: bedroom
    expose: true
  script.diningdaylight:
    room: dining room
    expose: true
  script.diningnormal:
    room: dining room
    expose: true
  script.diningwarm:
    room: dining room
    expose: true
  script.lounge100:
    room: lounge room
    expose: true
  script.loungedaylight:
    room: lounge room
    expose: true
  script.loungemovie:
    room: lounge room
    expose: true
  script.loungenormal:
    room: lounge room
    expose: true
  script.loungewarm:
    room: lounge room
    expose: true
  script.officeall:
    room: office
    expose: true
  script.officedaylight:
    room: office
    expose: true
  script.officemain:
    room: office
    expose: true
  script.officewarm:
    room: office
    expose: true
  script.deskdaylight:
    room: office
    expose: true
  script.desknormal:
    room: office
    expose: true
  script.deskwarm:
    room: office
    expose: true
Check out the expose_by_default parameter. I think you need it!
expose_by_default (boolean)(Optional)
Expose devices in all supported domains by default. If exposed_domains domains is set, only these domains are exposed by default. If expose_by_default is set to false, devices have to be manually exposed in entity_config .
Default value: true
Still doesn’t make sense.
If I don’t have an exposed_domains, expose_by_default should not matter…
maybe I should delete that exposed_domains again and set expose_by_default to false… lemme try that lol
OK that worked. Now I’m removing expose: true from everywhere as that is the default and I’m not exposing any domains by default anymore…
And that doesn’t work nothing is exposed…
Cloud config is indeed different then local config, you need to specific each entity first that you want to expose… I struggle with that too when I stepped over from local to nabu
not sure if this helps, but in my cloud config (I use Nabu Casa)
I explicitly include entities and 1 domain like this, exclude 2 other domains, (which probably isnt necessary because of the include, but just to be sure) and nothing else gets included:
cloud:
  google_actions:
    filter:
      include_entities:
        - script.aan_de_slag_direct
        - script.gaming_direct
        - script.gym_direct
        - script.home_theater_direct
        - script.mode_developer_direct
        - script.mode_full_house_direct
        - script.mode_kiosk_direct
        - etc
      include_domains:
#        - switch
#        - light
        - media_player
#        - scene
      exclude_domains:
        - script
        - switch
Each included entity gets its own config like:
    entity_config:
      input_boolean.audio_system:
        aliases:
          - Muziek
          - Music
        room: Woonkamer
Not only can one create useful aliases for normal speech, these entities are in their correct room immediately and that doesnt need configuring i the Google Home environment at all.
Must confess I have my Hue and Tradfri lights connected to Google directly, because every once in a while HA has issues (because an undocumented breaking change :wink: ) and cant connect to the cloud in that case. Having Hue and Tradfri directly linked to Google Home certainly has its advantages then.
Long story short: nothing gets added unless I explicitly instruct it to.
I feel it is the best of both worlds like this.
My whole family can talk to the house and get things done.
for updating: whenever I change things in the HA environment a click in the cloud config on Sync entities to google is enough. Seems to all do the trick very nicely.
Really like the ease of things, and the fun of course. Very cool to be able to talk to home when not at home… :wink:
Very much the same here. I have a couple of lights and switches that are configured in Google directly so I don’t expose them via HA (even though they are integrated in HA as well). That way if something goes awry with HA I can still control a couple of lights…
I tired to expose the 2 scripts I really wanted to Alexa and they didn’t show. I exposed the entire script domain and still nothing is coming up in Alexa. All my switches and whatnot are there, and the Alexa GUI page shows the scripts are exposed as scenes, but they aren’t showing up in the Alexa app.
Edit:
Add YAML
alexa:
  filter:
    include_domains:
      - switch
      - light
      - lock
      - climate
      - scene
      - script
    exclude_domains:
      - automation
      - remote
      - device_tracker
    include_entities:
      - script.alexa_goodnight
      - script.alexa_goodbye
It’s done until another update :smile:
I understand why they changed scenes. I doubt they will be changing scripts.
HA… makes us adaptable lol…
In the release notes I read:
Voice for Home Assistant Cloud
Nabu Casa has introduced a new beta service providing speech-to-text and text-to-speech services to Home Assistant Cloud subscribers powered by Azure Cognitive Services.
I don’t have a nabu account for that long. Were do you find the beta services?
102.3 broke Solaredge component
2019-12-01 12:29:28 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform solaredge
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 150, in _async_setup_platform
    await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
    return fut.result()
  File "/usr/src/homeassistant/homeassistant/components/solaredge/sensor.py", line 35, in async_setup_entry
    api.get_details, entry.data[CONF_SITE_ID]
  File "/usr/src/homeassistant/homeassistant/core.py", line 343, in async_add_executor_job
    task = self.loop.run_in_executor(None, target, *args)
  File "uvloop/loop.pyx", line 2647, in uvloop.loop.Loop.run_in_executor
  File "/usr/local/lib/python3.7/asyncio/coroutines.py", line 162, in iscoroutinefunction
    return (inspect.iscoroutinefunction(func) or
  File "/usr/local/lib/python3.7/inspect.py", line 185, in iscoroutinefunction
    object.__code__.co_flags & CO_COROUTINE)
AttributeError: 'functools._lru_cache_wrapper' object has no attribute '__code__'
I have the impression that since 0.102.3 the config check, restart (auto config check before) and LL refresh (yaml mode) takes ages.
Can someone confirm?
Me too, same thing
Config check takes a little longer for me, but this is because of a bug in HACS, it used to take around 5 seconds to check config, but now it takes around 10 seconds to check config.
Thanks for your reply. I’m waiting 25 - 30 seconds for the config check.
Is there any link to the HACS issue?
I had this and one by one disabled my custom components. I found that if I remove the Samsung multi room custom component it went back to 5 seconds. As soon I put it back, it goes to near 30 seconds. Weird as it’s worked fine for a long time.
Same for me
I have a very similar issue. I am also running home assistant on an Intel NUC. I am running it on a Lubuntu with hass.io. After updating from 0.101.2 to 0.102.3, the CPU load went up to 100% after a couple of hours. I was barely able to connect to the host system over SSH. I figured out that the CPU load is caused by running out of memory (I have 8GB of RAM installed).
After a reboot, I figured out that there must be a memory leak in the main Home Assistant container. The memory usage of this container raises continuously about 150MB per hour. As soon as the system is running out of memory, the CPU gets to 100% and the system is unstable.
My solution was to go back to version 0.101.2. This version seems to work fine.
Mine hasn’t been a constant issue but it does seem to spike higher than it ever did previously. I have 16Gb RAM in my NUC (I think…from memory) and it isn’t getting used up, it’s just the CPU that sits high for a while but then eventually comes back down to normal. I am however only on a Pentium NUC…maybe time to upgrade
While writing this the CPU has gone for another spike…
