Using the config checker add-on, I’m seeing the following error with roku:
[07:11:57] INFO: Installed Home Assistant 0.103.6
[07:11:57] INFO: Making a copy of your configuration for checking...
[07:12:14] INFO: Checking your configuration against this version...
[07:18:29] ERROR: The configuration check did not pass!
[07:18:29] ERROR: See the output below for more details.
INFO:homeassistant.util.package:Attempting install of colorlog==4.0.2
Testing configuration at /tmp/config
INFO:homeassistant.util.package:Attempting install of roku==4.0.0
INFO:homeassistant.util.package:Attempting install of influxdb==5.2.3
INFO:homeassistant.util.package:Attempting install of construct==2.9.45
INFO:homeassistant.util.package:Attempting install of python-miio==0.4.7
INFO:homeassistant.util.package:Attempting install of speedtest-cli==2.1.2
INFO:homeassistant.util.package:Attempting install of sqlalchemy==1.3.11
INFO:homeassistant.util.package:Attempting install of python-forecastio==1.4.0
INFO:homeassistant.util.package:Attempting install of hass-nabucasa==0.30
INFO:homeassistant.util.package:Attempting install of home-assistant-frontend==20191204.1
INFO:homeassistant.util.package:Attempting install of PyNaCl==1.3.0
INFO:homeassistant.util.package:Attempting install of defusedxml==0.6.0
INFO:homeassistant.util.package:Attempting install of netdisco==2.6.0
INFO:homeassistant.util.package:Attempting install of distro==1.4.0
INFO:homeassistant.util.package:Attempting install of HAP-python==2.6.0
INFO:homeassistant.util.package:Attempting install of aiohttp_cors==0.7.0
INFO:homeassistant.util.package:Attempting install of zm-py==0.4.0
INFO:homeassistant.util.package:Attempting install of mutagen==1.43.0
INFO:homeassistant.util.package:Attempting install of gTTS-token==1.1.3
INFO:homeassistant.util.package:Attempting install of python-nmap==0.6.1
INFO:homeassistant.util.package:Attempting install of getmac==0.8.1
Failed config
General Errors:
- Component error: roku - No module named 'netdisco'
Currently running Hassio 0.103.4, I didn’t upgrade to 0.103.5 because the changelog wouldn’t affect me, though I did previously use the config checker and saw that .5 would pass just fine.
