0.105: Safe mode, Headers & Footers, New Zones Editor, Garmin, Sighthound
There’s also this little issue: the current version of Config Helper (1.5) for the VS Code Editor doesn’t yet know that state_color is a valid property. Everywhere you specify it in the file gets flagged as being a disallowed property.
Screenshot from 2020-02-06 13-03-47
It’s not a show-stopper but it does make the file appear to have a lot of errors.
In addition, in my personal opinion, the image used to explain the state_color change is not correct:
For me, all these entities are wrong. The correct would be:
  • Enable Plex Notifications
  • Enable Expiring Domain Notifications
  • Enable Discord Notifications
So the coloured icon will be good in all cases.
Did I understand correctly that the following configuration in my ui-lovelace.yaml is no longer supported from version 0.107.0 on.
If yes, what is the alternative?
#Temperatur Wohnzimmer
        - type: thermostat
          entity: climate.wohnzimmer
        - type: history-graph
          title: "Temperatur"
          entities:
            - entity: sensor.temperatur_und_luftfeuchtigkeitssensor_temperature
You are using the correct Lovelace History graph, the deprecated one is the old States UI History Graph.
You can at least set state_color at the card level, so all entities within that card will be affected. I thought this was going to be bad for me, as well, but it only took a few minutes to get all of my cards updated.
You are right, I found it in docs now (Entities Card). Not ideal for me, but it could be done.
I’d LOVE state_color to go one step further and allow you to define WHAT color a given state is…
- entity: switch.whatever
  state_color:
    - value: 'on'
      color: #4C709D
    - value: 'off'
      color: #FFF
or
  state_color:
    - on: #4C709D
    - off: #FFF
or whatever the most logical way to do it is, I’m no expert.
Would be nice at the Card level as well.
Could go a step further and implement a state_icon which allowed changing the ICON based on state changes - currently I have to create a bunch of template switches to do this.
It can be defined at the card level.
Do I need to do something special with my zha configuration in this release?
I get the following error on 0.105.1 (works again when reverted to 0.104.3)
Error setting up entry /dev/ttyACM1 for zha
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 215, in async_setup
hass, self
File “/usr/src/homeassistant/homeassistant/components/zha/init.py”, line 103, in async_setup_entry
await zha_gateway.async_initialize()
File “/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py”, line 136, in async_initialize
await self.application_controller.startup(auto_form=True)
File “/usr/local/lib/python3.7/site-packages/bellows/zigbee/application.py”, line 138, in startup
await self.initialize()
File “/usr/local/lib/python3.7/site-packages/bellows/zigbee/application.py”, line 91, in initialize
await self._cfg(c.CONFIG_KEY_TABLE_SIZE, 8)
File “/usr/local/lib/python3.7/site-packages/bellows/zigbee/application.py”, line 231, in _cfg
assert v[0] == t.EmberStatus.SUCCESS # TODO: Better check
AssertionError
Running Homeassistant core with docker-compose on an intel nuc.
The Vera integration is no longer functioning in 105. Devices can not be updated via HA, even though their state seems to be correct. I had to downgrade to 104 to avoid divorce.
Partially in the works: https://github.com/home-assistant/home-assistant-polymer/pull/4728
Yes, I’ve seen the PR after my post. Thank you very much.
Or stick to the Home Assistant UI and display it similar as how automation entities are shown on an entity card.
Running HassOS 3.9 and trying to install Home assistant 105.1 but get this error on rasberry pi 4. :frowning:
20-02-06 20:03:19 INFO (SyncWorker_17) [hassio.docker.interface] Pull image homeassistant/raspberrypi4-homeassistant tag 0.105.1.
20-02-06 20:09:07 INFO (SyncWorker_17) [hassio.docker.interface] Stop homeassistant application
20-02-06 20:10:14 INFO (SyncWorker_17) [hassio.docker.interface] Clean homeassistant application
20-02-06 20:10:20 INFO (SyncWorker_14) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi4-homeassistant with version 0.105.1
20-02-06 20:10:45 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
20-02-06 20:12:25 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
20-02-06 20:20:34 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository
20-02-06 20:20:34 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
20-02-06 20:20:35 INFO (MainThread) [hassio.store] Load add-ons from store: 62 all - 0 new - 0 remove
20-02-06 20:22:27 WARNING (MainThread) [hassio.homeassistant] Don’t wait anymore of Home Assistant startup!
20-02-06 20:22:27 CRITICAL (MainThread) [hassio.homeassistant] HomeAssistant update fails -> rollback!
20-02-06 20:22:27 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.104.3
20-02-06 20:22:27 INFO (SyncWorker_3) [hassio.docker.interface] Update image homeassistant/raspberrypi4-homeassistant:0.105.1 to homeassistant/raspberrypi4-homeassistant:0.104.3
20-02-06 20:22:27 INFO (SyncWorker_3) [hassio.docker.interface] Pull image homeassistant/raspberrypi4-homeassistant tag 0.104.3.
20-02-06 20:22:29 INFO (SyncWorker_3) [hassio.docker.interface] Stop homeassistant application
20-02-06 20:22:30 INFO (SyncWorker_3) [hassio.docker.interface] Clean homeassistant application
20-02-06 20:22:31 INFO (SyncWorker_18) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi4-homeassistant with version 0.104.3
20-02-06 20:22:56 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
20-02-06 20:24:31 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
20-02-06 20:24:41 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
20-02-06 20:24:41 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.104.3
20-02-06 20:24:42 INFO (SyncWorker_0) [hassio.docker.interface] Cleanup images: [‘homeassistant/raspberrypi4-homeassistant:0.105.1’]
Thank you, @123, had not found that.
Relying on colour to convey something is not a great UI for the visually impaired especially if that bar can change colour depending on state.
I am getting an error when trying to update os.
And there is nothing created in logs after that.
The Alexa custom component also is spitting this issue on repeat every 10secs. It wasn’t happening after updating though. Not sure if related but only occured after rebooting while trying to set up Spotify, which is also coming up as unavailable after authorising it.
2020-02-06 23:21:36 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/components/notify/__init__.py", line 161, in async_platform_discovered
    await async_setup_platform(platform, discovery_info=info)
  File "/usr/src/homeassistant/homeassistant/components/notify/__init__.py", line 95, in async_setup_platform
    notify_service.hass = hass
AttributeError: 'bool' object has no attribute 'hass'
2020-02-06 23:21:41 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-02-06 23:21:47 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-02-06 23:21:52 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-02-06 23:21:57 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-02-06 23:22:02 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-02-06 23:22:09 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry [email protected] - amazon.co.uk for media_player
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 215, in async_setup
    hass, self
  File "/usr/src/homeassistant/homeassistant/components/media_player/__init__.py", line 330, in async_setup_entry
    return await hass.data[DOMAIN].async_setup_entry(entry)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 156, in async_setup_entry
    raise ValueError("Config entry has already been setup!")
ValueError: Config entry has already been setup!
2020-02-06 23:22:09 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry [email protected] - amazon.co.uk for alarm_control_panel
    hass, self
  File "/usr/src/homeassistant/homeassistant/components/alarm_control_panel/__init__.py", line 94, in async_setup_entry
2020-02-06 23:22:09 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry [email protected] - amazon.co.uk for switch
    hass, self
  File "/usr/src/homeassistant/homeassistant/components/switch/__init__.py", line 73, in async_setup_entry
2020-02-06 23:22:09 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry [email protected] - amazon.co.uk for sensor
    hass, self
  File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 59, in async_setup_entry
2020-02-06 23:22:35 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry [email protected] - amazon.co.uk for media_player
    hass, self
2020-02-06 23:22:35 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry [email protected] - amazon.co.uk for alarm_control_panel
    hass, self
2020-02-06 23:22:35 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry [email protected] - amazon.co.uk for switch
    hass, self
2020-02-06 23:22:35 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry [email protected] - amazon.co.uk for sensor
    hass, self
2020-02-06 23:22:41 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry [email protected] - amazon.co.uk for media_player
    hass, self
2020-02-06 23:22:41 ERROR [email protected] - amazon.co.uk for alarm_control_panel
    hass, self
2020-02-06 23:22:41 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry [email protected] - amazon.co.uk for switch
    hass, self
2020-02-06 23:22:41 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry [email protected] - amazon.co.uk for sensor
    hass, self
2020-02-06 23:22:46 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry [email protected] - amazon.co.uk for media_player
    hass, self
2020-02-06 23:22:46 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry [email protected] - amazon.co.uk for alarm_control_panel
    hass, self
2020-02-06 23:22:46 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry [email protected] - amazon.co.uk for switch
    hass, self
2020-02-06 23:22:46 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry [email protected] - amazon.co.uk for sensor
    hass, self
After setting up Spotify again in the new method, i can’t seem to change the Spotfy source iwth Home Assistant, any idea why?
choose to rollback to 104.3 as a lot of problems with my z-wave network.
