re-trying asuswrt myself here, but a bit puzzled by the lack of configuration options for track_new_devices, exclude, consider_home, and interval_seconds…
cant believe these device_trackers are so neglected and immature all over tbh. Aren’t we missing some fundamentals elsewhere ?
What was interesting from the loading a new HA was that a lot of the configuration in Yaml such as that within addons such as DuckDNS and Samba and MQTT had all changed. Again I no expert in Software code but thought might help.
Bad news is 0.108.3 has a massive problem with an error that is being displayed all over the logs and doesn’t appear to have definte pattern “Event is not JSON serializable” and was the reason for having to reinstall from scratch because it crashed my SD Card.
I’m using Home Assistant (HassOS / Hassio) so what does that mean?
Do I need to re-flash HassOS and restore? Or just a full restore from a snapshot will do it?
Well I am too and still not seeing any of the errors and concerning the Bayes problem I rewrote the Bayes sensors without the use of Value Templates and works fine and now running the current latest version 0.108.4. I wasn’t happy about having to do a rebuild but as mentioned previously in this issue it appears there have been some fundamental changes to the code concerning the direction of Yaml. I may be wrong but I now have a fresh build.
I don’t understand the relation between nmap device tracker and modbus.
I have updated and I already have lots of logs (took more than 20s). Will wait but I don’t think it is solved for nmap
Since adding the scan options line mine has been stable for over 3 days. Currently running 0.108.8 as I don’t want to restart HA since I added this line.
Thanks for the suggestion, still seeing issues though: 2020-04-27 15:30:00 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:15
Had the same issue and I also tried to fix it by finding the right scan intervals.
To identify the right interval, I downloaded an nmap scanner from nmap.org and started a scan with the parameters nmap -oX - 192.168.1.0/24.
These parameters can be found on Home Assistants Nmap Tracker page. I run the scan several times and it always took more than 200 seconds to complete.
Which explains, to my understanding, the issues we are having.
In a next step, I checked the used nmap parameters and I learned that the way home-assistant is calling nmap, it runs a full scan including port scan everytime called.
By accident, I found at the bottom of the Nmap Tracker Integration page under LINUX Capabilities that the nmap_tracker can also be called with the parameter -sn (Ping Scan - disable port scan).
Running again the scan using the nmap windows client with parameter -sn takes in average less than 15s.
My nmap device tracker yaml file looks now as follows:
Currently it runs for more than 12 hours on two home-assistant instances (rpi3, Home Assistant 0.110.0) with no logged errors. I am not sure if it solves your issues too but at least it solved mine for the time beeing.
