0.108: Logos, Area Pages, Lovelace Entity Card, Lovelace Map History
Updated to Home Assistant 0.108.2 and modbus not work :frowning: In 107 and earlier it was working OK. Please, fix.
This made me laugh.
What FM ???
We never had oneā€¦
Though my major problem now is : - I need to change ā€œthisā€ I think I set it up following onboarding and I think it used to be ā€˜hereā€™
ā€œNo, is not there, we moved it ! and youll now need to remember ā€œthisā€ new/obscure locationā€
Or ā€œyes it used to be in yaml but really you need to use this widget insteadā€
I appreciate this is a mammoth task and one of the problems is that there are many ways of doing the same thing, so there is no ā€œone size fits allā€ solution
I appreciate that a lot of our new members have no wish to get their heads round yaml and more and more will move towards ui (as Taras said) . And that as a boring stick in the mud, I should pull my finger out and embrace the new interfaces.
Me dinosaur, how bout you ?
:rofl:
Hmmmm.!
I could say that mine doubled. ( from 1% to 2%) (924 entities, 192 automations, 313 sensors) what the hell are you running ?
Keep up the good work !! :+1:
Thanks for the tip. Same problem, and you fixed it :slight_smile:
Just in case someone is struggling to install home-assistant-frontend==20200407.2, I only could do that increasing swap size. My ā€œserverā€ originally has only 512MB Mem + 246MB swap, which was not enough.
You know what? If everyone who has a problem rolls back instead of debugging and filing issues to github, how is anything ever going to get fixed?
I agree that debugging is needed but if they are rolling back and they confirm things go back to normal then that means the issue is more code related. Now if they rollback and the issue persists the user knows its something on their end. And i agree they should ALWAYS be filing issues when they encounter them, with the issue template filled out lol.
@nickrout Trueā€¦but I have to say that its a little hard to debug when you are unable to load the logs in your UI mate? Rolling back has often been my only option both in the past and again right now.
cat $CONFIG/home-assistant.log
Not sure what to do with that? I use a docker install on a QNAP NAS. I have looked in my config folder and found a text file named ā€˜home-assistant.txtā€™ Opened that in VS Code and thats the log. Never knew that cheers!
If/when I see some positive reports on modbus working in upcoming 0.108.x releases Iā€™ll keep that in mind and try again.
Mine seem to be fine.
Like David, mine are also working as expected
Apparently the problem of input_booleans, and other ā€˜helpersā€™, failing to be restored has been corrected by this PR and is included in the upcoming 0.108.3 release:
https://github.com/home-assistant/core/pull/33973
FWIW, I tested 0.108.0 of Home Assistant Core and experienced no issues with restoring the state of input_booleans and other ā€˜helpersā€™.
Where is the config saved?
When I search through the files in my config directory, I only see references to it in .storage/config_entries and .storage/entity_registry. Both files change several times a day with what appears to be state information. Thatā€™s not very helpful. I use version control for backup because it lets me make note of what I changed and why. Unfortunately, with configuration information mixed in with state info, Iā€™m left with committing unrelated changes every time I need to back out a change that I decided I donā€™t like, or tell version control to ignore those files, and then I lose critical configuration info. And yeah, Iā€™ve lost some configuration that way.
I like the UI for quickly learning how to configure something. And for components that only get configured once, itā€™s great. But knowing where the config is stored, and being able to open it in a text editor and copy/paste then make a few changes is much better (for me) for components that need several similar instances. :slight_smile: Thatā€™s the second reason Iā€™d like to know where the config is kept, and of the two files I mentioned above, Iā€™ve no idea which might be considered definitive.
Additionally, Iā€™ve occasionally made typos when setting up a component, and sometimes you canā€™t edit components; you have to delete and start over again. The ability to open a file in a text editor and fix the typo would be a third reason to have this info.
Obviously, if Iā€™ve just missed it in the docs somewhere, a quick link to the relevant doc would be most appreciated.
I dont think there is official support for hue remotes yet. Its probably using the custom one.
Deleted. WeMo working againā€¦
My Belkin Wemo still works fine.
I updated to 0.108.4 (docker) and z-wave stopped working. Iā€™m seeing a bunch of ā€œOut of frame flow! (0x00). Sending NAK.ā€ errors in OZW Logs. I tried swapping usb ports for my zwave stick and still no luck.
Has anyone else had a similar issue?
I donā€™t think so.
