Before we talk about anything that matches the title of this blog post:
On behalf of everybody working on the Home Assistant project, we hope you, your family and loved ones are safe and remain healthy during this pandemic. Our thoughts are with everyone that has been deeply affected by the current situation.
Stay strong, keep distance from each other, wash your hands and stay safe.
We made it all up to 0.107.7 the previous release, 7! patch releases.
Some have noticed and commented on the fact we do a lot more patch releases the past months, which is correct. This is not because everything was shipped in a broken state, but we are trying to ship any bug fix to you as soon as possible! Just so you don’t have to wait 3 weeks for something to get fixed.
So let’s talk about the elephant in the room: Home Assistant Core 0.108!
Martin Hjelmare & Ashton Lafferty join Nabu Casa
We want to start by announcing Martin Hjelmare has joined Nabu Casa!
Martin is a core team member for a long time, and initially started out contributing to the project by his work on the MySensors integration back in Home Assistant 0.11 (2016)! Most contributors to Home Assistant, will know Martin for his endless patience on the incredible code reviews he does.
Furthermore, Ashton Lafferty (cogneato) has been working some hours for Nabu Casa, to help out with things like support. Most of you probably know him from that already, as he is very active in helping out on our Discord server.
We are happy to announce that Ashton will now join Nabu Casa full-time as well!
Congratulations Martin and Ashton! 🎉
Integration logos & icons
We have created a new repository on GitHub containing all the brand icons and logos Home Assistant is able to integrate with. These images are, for example, used in our documentation.
In 0.108, we made a start on using the content from this repository in the Home Assistant frontend. The device information page got a layout update and the integrations page as well.
These pages will now show the icons and logos matching the integration.
 Device information page showing the Hue logo.
Looking for a way to contribute to the Home Assistant project? We still are missing a lot of images; So we are calling out for help!
Many integrations now available to set up from the UI
It is absolutely amazing to see all the upgraded integrations this release! Many contributors have gone out and added support to a lot of integrations to allow them to be configured via the Home Assistant frontend.
Not all of them were ready in time for this release; nevertheless, the list is amazing already:
- Freebox, done by @Quentame
- Monoprice, done by @OnFreund
- Roku, done by @ctalkington
- Doorbird, done by @bdraco
- Elk-M1 Control, done by @bdraco
- Logitech Harmony, done by @bdraco
- MyQ, done by @bdraco
- Network UPS Tools (NUT), done by @bdraco
- NuHeat, done by @bdraco
- Rachio, done by @bdraco
Yes, @bdraco has been on fire this release! Amazing job!
Lovelace Map history
Maybe not very useful during home quarantine, but a very cool feature for when we are allowed to get out of our homes again. @Hoytron added the ability to show the history of persons or device trackers on the Lovelace map card. You can define how many hours of history you want to show and it will draw lines between all the points in that time frame.
 Screenshot of the map card with history.
New Lovelace card: Entity
@zsarnett added a new Lovelace card, the entity card. This card looks like the sensor card, but allows you to use any entity (not just sensors).
 Screenshot of the entity card.
Area configuration page
We added an overview page for your areas. On this page you can see all the devices in the area, but also the automations, scenes and scripts that affect that area.
 Screenshot of the area config page.
Horizontal stack now handles different heights better
When creating a Horizontal stack, the cards in the stack don’t always line up nicely. This has been adjusted. Horizontal stacks now deal better with the difference in heights of the cards on the stack.
 Before and after screenshot for the Horizontal Stack improvements.
Other noteworthy changes
“Alexa, show the front door camera.” 😲 Alexa now has support for Cameras, thanks @ochlocracy!
Selecting your default Lovelace dashboard has been moved to the user profile page.
A lot of configuration pages are migrated to data tables, this means you can now search in your automations, scenes, scripts, users and areas.
Lovelace cards in panel views can now also be edited with the UI editor.
The graph from the sensor card is now also available as a footer for the entities and entity card.
The Markdown card has a new
uservariable that can be used to display the currently logged in user. -
With the ZHA Zigbee integration, Zigbee groups now dynamically create entities for lights, switches and fans that are grouped together. This enables near-simultaneous control over a large group of lights allowing them to turn on or off at the exact same time. Thank you @dmulcahey!
Cameras added using the ONVIF integration now automatically use the still images provided by the camera, instead of Home Assistant generating one. Nice work @roleoroleo!
WLED got quite a few internal upgrades, has added new Wi-Fi sensors and now has a service to control the effects of your WLED device.
Docker images for Home Assistant are now using Jemalloc, to reduce memory fragmentation and speed up memory allocation. So, less memory and generally a faster Home Assistant.
New Integrations
New Platforms
If you need help…
…don’t hesitate to use our very active forums or join us for a little chat.
Experiencing issues introduced by this release? Please report them in our issue tracker. Make sure to fill in all fields of the issue template.
Breaking Changes
Lovelace themes - We discovered our theme logic was wrong, when you didn’t specify a theme for a Lovelace card or view. It would default to the backend selected theme, even when your local theme was different, or your view had a different theme. To fix this we removed the options
defaultandBackend selectedfrom the Lovelace theme selection, and when there is not theme selected it will not set a theme. This will make sure the element has the same theme as it’s parent. -
Freebox - Freebox is now available as an integration from the Integrations UI! You will need to re-authorize Home Assistant to access the Freebox router. - (@Quentame - #30334) (freebox docs)
UniFi - Manual configuration has been deprecated as the UI integration now supports all of the previous available options and more. Your existing YAML configuration has previously been imported so just remove it. - (@Kane610 - #32699) (unifi docs)
Emulated Hue - The
emulated_hueandemulated_hue_hiddenattributes have been deprecated. Use the existingentitieshiddenconfiguration instead. - (@bdraco - #32718) (emulated_hue docs)Example YAML configuration:
emulated_hue: host_ip: 192.168.1.186 listen_port: 8300 advertise_ip: 10.0.0.10 advertise_port: 8080 off_maps_to_on_domains: - script - scene expose_by_default: true exposed_domains: - light entities: light.bedroom_light: name: "Bedside Lamp" light.ceiling_lights: hidden: true -
Roku - Roku is now available as an integration from the integrations UI! The
roku_scanservice has been removed in favor of discovery viassdp. - (@ctalkington - #31988) (roku docs) -
MQTT - Deprecated features from MQTT platforms are now removed. - (@emontnemery - #32909) (mqtt docs)
- For MQTT lights setup through MQTT discovery, it’s no longer possible to specify schema with
platformconfiguration variable. Instead, schema must be specified by theschemaconfiguration variable. - For MQTT
alarm_control_panel, MQTTbinary_sensorand MQTTsensorset up through MQTT discovery: The undocumented implicit setting ofstate_topicis no longer supported. Instead,state_topicmust be explicitly set. - Support for
json_attributesis removed from MQTT sensor,json_attributes_topicshould be used instead.
Harmony - Harmony is now available as an integration from the Integrations UI! The YAML configuration now requires a host/ip. - (@bdraco - #32919) (harmony docs)
remote: - platform: harmony name: Bedroom host: 10.168.1.13 -
Sonos - Sonos attributes have been cleaned up for radio streams. - (@amelchio - #33063) (sonos docs)
- Sonos entities playing radio streams used to merge the radio name, the artist and the song name into two attributes. They now have
media_artistandmedia_titleattributes that match the playing music (when available). - Radio station artwork is no longer available for Sonos entities in polling mode (i.e., on a network separate to the network Home Assistant is on).
Monoprice - Monoprice is now available as an integration from the UI! Please remove the configuration from YAML and add the Monoprice integration from the Integrations page. - (@OnFreund - #30337) (monoprice docs)
Lutron Caseta - As a result of some cleanup, the
Device IDandZone IDattributes of Lutron Caseta devices have been renamed todevice_idandzone_idto match the convention of the rest of Home Assistant. If you have any automations that reference these attributes, they will need to be updated. - (@swails - #33144) (lutron_caseta docs) -
NuHeat - NuHeat is now available as an integration from the UI! The previous service has been removed and is now handled by
set_hvac_mode(climate 1.0). - (@bdraco - #32885) (nuheat docs) -
ElkM1 - ElkM1 is now available as an integration from the UI! An auto configure mode has been introduced which avoids the need to setup the complex include and exclude filters. This functionality still exists when configuring from YAML for power users who want more control over which entities elkm1 generates. As entity IDs can now be changed, the
alarm_control_panelattributechanged_by_entity_idis nowchanged_by_keypadand will show the name of the Elk keypad instead of the entity ID. - (@bdraco - #33297) (elkm1 docs) -
HmIP - After HmIP Cloud Maintanance (17.3.2020) it’s possible to define labels for each channel of a multi device. If the labels of a multi channel device have been changed in the native Homemamtic IP Cloud App, then the entity names will change accordingly. - (@SukramJ - #32925) (homematicip_cloud docs)
Slack - The Slack integration got an overhaul and added support for async and Slack’s Block Kit. As the YAML configuration schema for this integration has changed, please be sure to read the documentation. Additionally, because it represents an unacceptable security risk, remote files (i.e., those that do not exist in a whitelisted directory local to Home Assistant) can no longer be sent to Slack via this integration. - (@bachya - #33287) (slack docs)
notify: - platform: slack api_key: !secret slack_api_key default_channel: "#home-assistant" -
Network UPS Tools (NUT) - The NUT integration is now available as an integration from the UI! (@bdraco - #33457) (nut docs) (breaking change)
The following sensors are no longer supported:
ups.timeups.dateups.modelups.mfrups.mfr.dateups.serialups.vendoridups.productidups.firmwareups.firmware.aux
Farewell to the following
These integrations have been removed. The websites for both have changed, causing the integrations to break because they relied on web scraping, which is no longer allowed (ADR-0004). - (@frenck - #33056 #33066)
All changes
Click to see all changes!This is a companion discussion topic for the original entry at https://www.home-assistant.io/blog/2020/04/08/release-108/
Please note, it can take up to 2 hours before the update is available on all systems. Please be patient while we roll out the release to all platforms.
