Yep - see here
Update : managed go back with the wipe and restore function
Hi
Was that answer to my version issue? If yes, I have tried with a cleared browser, but no change. That would also not explain, why the cli is reporting the wrong version as last_version.
If itâs reporting that you are still on 0.107 then your update failed.
My Homekit setup was broken. I thought I messed up but it turns out that 0.108.3 fixes my issue. I wasnât able to switch on/off groups or rooms with Siri commands anymore. Now everything is working fine again. Thanks!!!
I had to reinstall my venv environment. After that everything works.
Regarding hide_entity
option being deprecated:
- I have many, many warnings in the log like:
2020-04-11 20:47:05 WARNING (MainThread) [homeassistant.components.automation] The 'hide_entity' option (with value 'True') is deprecated, please remove it from your configuration. This option will become invalid in version 0.110
Before the end comes, could the name of the item or the configuration file location be added to the warning message to make it easier to track down?
Is this the same as
hidden: true
in the entity attributes, andHide from UI
in Customizations? I can find those and, if so, you can disregard the ask in #1. It just could use a better description in the warning for what to look for. -
Just because
hidden: true
no longer has a direct effect in the UI, why is it necessary to purge it from the attributes of all entities? It is possible to configure Lovelace with an entity state filter that references the attribute, somewhat preserving the functionality. -
Why doesnât Lovelace honor it as an implicit filter in the first place?
Should your request not be implemented before 0.110 arrives, this works from the command line in the config directory:
grep --include=\*.{yaml,py} -rnw "hide_entity"
It will search, recursively, through all files ending with .yaml
or .py
, in all sub-directories and report the file and line-number containing the matching word hide_entity
(or any other word you may wish to find).
Itâs reporting Iâm on 108.3, if you look on the picture, but itâs reporting the newest version is 107.7.
After upgrading I canât access my Supervisor panel any longer on Hass.io. It throws the following error:
Unable to load the panel source: /api/hassio/app/entrypoint.js.
Restarting the server or rebooting the host doesnât work either. Any suggestions? I already searched the forum but wasnât able to find a fix that solves the issueâŚ
Beginning with 108.x I began seeing ârequest to pairâ on my pre-WebOS LG tv pop up every 5 minutes, which does not occur on my newer WebOs LG tv. I have not enabled LG integrations. When I turn off homeassistant the message on the TV stops. Not a biggy, since I just disabled network connection to the TV, which is not needed and stops the pairing request problem.
Not sure if anyone responded, but I just had the same issue, it appears there are a few of us:
Which version are you upgrading from? Are you using Docker?
If upgrading from a version before 0.107.x, you might want to try this (duplicate instances running in Docker container):
https://github.com/home-assistant/core/issues/32992#issuecomment-604789778
I also had to restore zwave configuration file backups, possibly corrupted by the same issue.
Iâve been going crazy trying to figure out why my curtain wasnât moving. Finally thought to check these comments and saw that others are having the same issue.
Thanks for sharing this! It was the exact issue I was seeing. I ended up spending almost all of yesterday resetting up my zwave devices but I got everything up and running again.
I should also mention that the forums are full of people who have this issue after upgrading to 0.107+, with zwave or other integrations. It should be mentioned as a breaking change for docker users.
https://github.com/home-assistant/core/issues/33648#issuecomment-611703069
https://github.com/home-assistant/core/issues/33917#issuecomment-611739015
https://github.com/Swamp-Ig/pizone/issues/3#issuecomment-612316078
https://github.com/mikelawrence/senseme-hacs/issues/3#issuecomment-612309790
Anyone notice that since upgrading to 108 that the CPU utilisation slowly increases over a period of time?
Restarting Home assistant restores the CPU utilisation but then it starts creeping up again.
I rolled back yo 107.7 and CPU utilisation is stableâŚ
run the install script again. This is due to some issue with wrong permissions in pervious installer scripts.
Thanks, ill keep an eye on that for a fix.
